Re: to mini tub or not
[Re: buconine]
#1686306
10/16/14 09:52 PM
10/16/14 09:52 PM
Posts: 4,302 Nebraska
72Swinger
Nebraska
The +38 might work all the way around with a 1/2" spacer in the rear and a degree or two negative camber in the front. The +43 might be ideal in the front with little or no camber though.
Mopar to the bone!!!
[Re: buconine]
#1686309
10/18/14 07:26 PM
10/18/14 07:26 PM
Posts: 12,375 SoCal
MuuMuu101
I got lucky at Woodward!
SoCal
Guy forgot to bring the rest of the wheels to test but had an 18 x 9.5 +20 275/35r18 to mess with. Front fit well, cleared the fender and hit the stock upper control arm when turning as expected. The rear hit the leafs but had good clearance to the fender. Added 1 1/2" of spacers to the rear and got the wheel pretty well centered. I guessing with offset hanger kit i should be able to run +20 all around and be ok without having to tub it.
Buy the wheels off him. The red and gold look good.
[Re: buconine]
#1686312
10/18/14 07:39 PM
10/18/14 07:39 PM
72Swinger
Nebraska
Do you still have stock front rotors? Rear drums? Im shocked a +20 is fitting, must be some different juju going on with the Valiants.Also its a good idea to un-crank your torsion bars and let it set on the bumpstops THEN turn steering wheel back and forth.
[Re: buconine]
#1686314
10/19/14 02:17 AM
10/19/14 02:17 AM
Posts: 12,375 SoCal
MuuMuu101
SoCal
It still has stock brakes all around. I couldn't bolt the wheels on tight enough to drop the car all the way down due to different bolt pattern. I think with offset spring kit and dr diffs rear disk kit i should be able to get the rears to fit with a small spacer if necessary. If i have to use a spacer, i will have to roll the rear lips.
So basically you're converting to my setup minus the offset shackles? Which rear end do you have? A or B Body?
