to mini tub or not #1686301
10/15/14 09:43 PM
10/15/14 09:43 PM
omahell, ne
buconine Offline OP
buconine  Offline OP
omahell, ne
Trying to figure out the budget needed to get everything done this winter. I was talking to a friend about doing the offset shackles and he mentioned that if i'm going to move the perches i might as well mini tub it.
I was planning on running a square setup on the car and really didn't think a mini tub was necessary. You guys have been down this road so i figured i would ask for input. Plan on dr diff cobra brakes f/r with hotchkis upper control arms and leafs.
69 valiant 383/727/3:23sg Swapping a 440 in this winter as well if it makes any difference.
Re: to mini tub or not [Re: buconine] #1686302
10/15/14 11:55 PM
10/15/14 11:55 PM
NY NY
3
340duster340 Offline
NY NY
haven't had it done myself, but seems like something that cab be done at any time down the road.
fwiw, my car has been apart way to long, i am now all for the least amount of work possible to get it back on the road, so maybe i am a little biased.
Re: to mini tub or not [Re: 340duster340] #1686303
10/16/14 08:35 AM
10/16/14 08:35 AM
The Netherlands, OV
dickdale Offline
dickdale  Offline
The Netherlands, OV
what wheel specs are you going to use?
Re: to mini tub or not [Re: dickdale] #1686304
10/16/14 09:46 AM
10/16/14 09:46 AM
omahell, ne
buconine Offline OP
buconine  Offline OP
omahell, ne
I am hoping to run 285/35-18 square setup on an 18 x 9 wheel. My co-worker has several wheels off his sti that i am going to test fitment with once i get the brake swap done.
Re: to mini tub or not [Re: buconine] #1686305
10/16/14 11:59 AM
10/16/14 11:59 AM
omahell, ne
buconine Offline OP
buconine  Offline OP
omahell, ne
I have a 18x9.5 +38 and +43 with 275/35 18 tires to use for testing. If I could get 275s all the way around with just the offset kit, I'd be ok with that.
Re: to mini tub or not [Re: buconine] #1686306
10/16/14 09:52 PM
10/16/14 09:52 PM
Nebraska
72Swinger Offline
72Swinger  Offline
Nebraska
The +38 might work all the way around with a 1/2" spacer in the rear and a degree or two negative camber in the front. The +43 might be ideal in the front with little or no camber though.
Mopar to the bone!!!
Re: to mini tub or not [Re: 72Swinger] #1686307
10/16/14 10:19 PM
10/16/14 10:19 PM
Overpriced Housing Central
RobX4406 Offline
RobX4406  Offline
I doubt a 285 will fit with a stock well and spring location. An offset perch set might make it close.
The fight you may have with tire fit would be greatly reduced with a minitub and spring relocation. My 275 tire Dart is a tight fit with a 3/4 spring relocation and some lip trim/bending.
Re: to mini tub or not [Re: RobX4406] #1686308
10/18/14 07:24 PM
10/18/14 07:24 PM
omahell, ne
buconine Offline OP
buconine  Offline OP
omahell, ne
Guy forgot to bring the rest of the wheels to test but had an 18 x 9.5 +20 275/35r18 to mess with. Front fit well, cleared the fender and hit the stock upper control arm when turning as expected. The rear hit the leafs but had good clearance to the fender. Added 1 1/2" of spacers to the rear and got the wheel pretty well centered. I guessing with offset hanger kit i should be able to run +20 all around and be ok without having to tub it.
Re: to mini tub or not [Re: buconine] #1686309
10/18/14 07:26 PM
10/18/14 07:26 PM
SoCal
MuuMuu101 Offline
I got lucky at Woodward!
MuuMuu101  Offline
SoCal
Buy the wheels off him. The red and gold look good.
Re: to mini tub or not [Re: buconine] #1686310
10/18/14 07:26 PM
10/18/14 07:26 PM
omahell, ne
buconine Offline OP
buconine  Offline OP
omahell, ne
Looks pretty slick...
Re: to mini tub or not [Re: MuuMuu101] #1686311
10/18/14 07:32 PM
10/18/14 07:32 PM
omahell, ne
buconine Offline OP
buconine  Offline OP
omahell, ne
I wish, they are the race wheels off his sti. Not sure what to do for wheel style. Thinking maybe fr500 or something more classic.
Re: to mini tub or not [Re: buconine] #1686312
10/18/14 07:39 PM
10/18/14 07:39 PM
Nebraska
72Swinger Offline
72Swinger  Offline
Nebraska
Do you still have stock front rotors? Rear drums? Im shocked a +20 is fitting, must be some different juju going on with the Valiants.Also its a good idea to un-crank your torsion bars and let it set on the bumpstops THEN turn steering wheel back and forth.
Re: to mini tub or not [Re: 72Swinger] #1686313
10/18/14 09:31 PM
10/18/14 09:31 PM
omahell, ne
buconine Offline OP
buconine  Offline OP
omahell, ne
It still has stock brakes all around. I couldn't bolt the wheels on tight enough to drop the car all the way down due to different bolt pattern. I think with offset spring kit and dr diffs rear disk kit i should be able to get the rears to fit with a small spacer if necessary. If i have to use a spacer, i will have to roll the rear lips.
Re: to mini tub or not [Re: buconine] #1686314
10/19/14 02:17 AM
10/19/14 02:17 AM
SoCal
MuuMuu101 Offline
MuuMuu101  Offline
SoCal
So basically you're converting to my setup minus the offset shackles? Which rear end do you have? A or B Body?
Re: to mini tub or not [Re: MuuMuu101] #1686315
10/19/14 11:08 AM
10/19/14 11:08 AM
omahell, ne
buconine Offline OP
buconine  Offline OP
omahell, ne
Yep, doing drdiff's cobra brakes all around, a body rear.
Re: to mini tub or not [Re: MuuMuu101] #1686316
10/19/14 11:42 AM
10/19/14 11:42 AM
omahell, ne
buconine Offline OP
buconine  Offline OP
omahell, ne
Do the hotchkis leafs have a 1/2" or 5/8" front eye hole? Getting ready to order the kit from drdiff and it shows 2 different ones. Anyone ever use these leafs with the offset kit?
