Stoopid question re: P/S leak... #1686241
10/15/14 01:15 PM
10/15/14 01:15 PM
beedees Offline OP
beedees  Offline OP
...pitman arm shaft leaking, anybody know of a mechanic-inna-bottle that works? I know-fix it right and be done with it, but right now I can't do it. Just looking for a patch Thanks
Re: Stoopid question re: P/S leak... [Re: beedees] #1686242
10/15/14 01:38 PM
10/15/14 01:38 PM
maine
LO23 Offline
LO23  Offline
maine
Lucas has stop leak, worked the one time I used it.
Re: Stoopid question re: P/S leak... [Re: beedees] #1686243
10/16/14 01:28 AM
10/16/14 01:28 AM
Granite Bay CA
Kern Dog Offline
Striving for excellence
Kern Dog  Offline
Granite Bay CA
DOT 3 brake fluid is a dirty trick, but it works.
Re: Stoopid question re: P/S leak... [Re: beedees] #1686244
10/17/14 06:42 AM
10/17/14 06:42 AM
places
79powerwagon Offline
places
The Lucas product does, in fact, actually work as advertised- for a while. You really need to weigh the cost of putting in fluid constantly to the outrageous cost of a rebuilt box, and decide what you want to do.
I never have heard of the brake fluid trick. Can you explain it further?
Re: Stoopid question re: P/S leak... [Re: 79powerwagon] #1686245
10/17/14 08:24 PM
10/17/14 08:24 PM
Granite Bay CA
Kern Dog Offline
Kern Dog  Offline
Granite Bay CA
My understanding is that the properties in brake fluid tend to swell the seals. It wouldn't help in the event of a cracked case.
Re: Stoopid question re: P/S leak... [Re: Kern Dog] #1686246
10/17/14 08:26 PM
10/17/14 08:26 PM
places
places
Thank you, that makes some sense. Probably worth the trial to see how far you can go IF you already have the resolve to replace the leaking box anyway.
Re: Stoopid question re: P/S leak... [Re: 79powerwagon] #1686247
10/17/14 09:18 PM
10/17/14 09:18 PM
IN
ahy Offline
ahy  Offline
IN
I believe the pitman shaft seal is serviceable. In vehicle (tricky) or on the bench. I've never done it but the FSM would have the steps or maybe somebody will post it.
