Re: Gear Vendors overdrive, gear splitting?
[Re: Hemi ragtop]
#1685887
10/14/14 10:39 PM
10/14/14 10:39 PM
Posts: 28,067 Irving, TX
feets
Senior Management
Senior Management
Irving, TX
Very few people split gears with the GV. Those that do are usually driving heavy vehicles (motorhomes, loaded trucks) and dealing with long grades.
It's an option with passenger cars but it's not needed.
When was the last time you wished you had a gear somewhere between second and third?
[Re: feets]
#1685888
10/15/14 11:16 AM
10/15/14 11:16 AM
Posts: 5,902 Athens, Greece
Pyper70
Athens, Greece
It's hard to split when racing or not pulling anything. There is a momentary lag between footswitch and gear change. As said, Mainly for towing.
Family owned 1969 Charger R/T DualQuad 440/727/GVO/3.55s
[Re: Hemi ragtop]
#1685889
10/15/14 01:53 PM
10/15/14 01:53 PM
Posts: 8,828 Houston, Tx
hemi68charger
Houston, Tx
I have a GV in my Daytona. When driving on the highway, I just let it turn on when it wants to ( 45 mph )... I don't split gears... With the 4.10's I have in the car, it is useless to. I am usually in 3rd gear way before 45mph. When I'm driving around regular streets, I usually leave the GV off......
TroyHouston Mopar Connection Club'69 Charger Daytona 440 - auto - 4.10 Dana (now with 426 hemi) '69 Charger 500 440 - 4speed - 3.54 Dana '70 Road Runner 383 - 4speed - a/c (now with 440)
[Re: Hemi ragtop]
#1685890
10/15/14 03:27 PM
10/15/14 03:27 PM
Posts: 3,277 West Coast, USA
jbc426
West Coast, USA
I am about to install a GV overdrive in my 66 HEMI Coronet convertible. Among other things, I am changing the torque converter from the 9-1/2" that stalls at 4,000 rpm, to an 11" 2,800 high effiecency converter. My question is, has anyone here used the "gear splitting" feature with a 727 and stock 66 console shifter?
It's hard to time it. After a lot of practice, you may be one of the few that can do it consistently, but good luck.
Then if you don't get the shorty 727 that mates to the Gear Vendor's unit, it is really long and you end up with a funky driveline angle. Some people can do the job right, but the RPM drop in overdrive is almost insignificant, and you will still need to massage the transmission tunnel.
I drove Mr Angry's B-body with a Gear Vendors unit in it, and found it abrupt and difficult to time the gear splitting, you only have slit seconds to nail it just right. I ended up using it in 3rd only. Even then, the RPM barely dropped, but it did help.
1970 Plymouth 'Cuda #'s 440-6(block in storage)currently 493" 6 pack, Shaker, 5 speed Passon, 4.10's 1968 Plymouth Barracuda Convertible 408 Magnum EFI with 4 speed automatic overdrive, 3800 stall lock-up converter and 4.30's (closest thing to an automatic 5 speed going)
[Re: Dodgem]
#1685894
10/16/14 09:51 PM
10/16/14 09:51 PM
Posts: 3,428 Dandridge TN
Dabee
Dandridge TN
Da beast II has one on his 512 Super bee with 3.54 gears and found best when flogging 1st 2nd od 3rd (living it in OD) I drove it and that seems to work real good. Maybe he will jump in I'll send him a heads up tomorrow!
Yep, what Dodgem said when flogging it. Normal driving I shift to over drive after I'm in third. I drive it like a four speed. I should add that I have a manual reverse valve body. I also disconnected the controller and direct wired the foot switch to the solenoid.
