new 727 case #1685134
10/13/14 09:32 AM
10/13/14 09:32 AM
Houston, Tx
hemi68charger Offline OP
Houston, Tx
Hey Gang..
I believe I found the root cause of my starter woes and now broken teeth on my new torque converter, the housing of the 727 isn't true and the starter isn't lining up properly. Is there a source for bare 727 cases? The guts of the tranny are fine..
Cheers,
Troy
Houston Mopar Connection Club
Re: new 727 case [Re: hemi68charger] #1685135
10/13/14 09:49 AM
10/13/14 09:49 AM
tboomer Offline
tboomer  Offline
John Cope at CRT may be able to help you. He is a sponsor here.
Re: new 727 case [Re: hemi68charger] #1685136
10/13/14 10:09 AM
10/13/14 10:09 AM
Rudolph, Ohio
moparguy7074 Offline
Rudolph, Ohio
Scrapyard?
Re: new 727 case [Re: moparguy7074] #1685137
10/13/14 10:37 AM
10/13/14 10:37 AM
AZ
Mike P Online content
Mike P  Online Content
AZ
I'd check the local transmission shops. When I needed a 518 case for mockup on my hot rod I went to the shop down the road and picked up a bare case, tail housing and pan for $50 and they even ran it thru their parts washer for me.
1957 Plymouth (Hemi, Dual Quads, A833 4 Speed 9 1/4 w 4.10) Sold
1937 Dodge Pickup (Hemi, 6X2 intake, 46RH, Dana 60 w 4.56) Sold
1968 Plymouth Valiant 2dr sedan (354 HEMI, 46RH w/4.30 gears)
Re: new 727 case [Re: Mike P] #1685138
10/13/14 10:58 AM
10/13/14 10:58 AM
Houston, Tx
Houston, Tx
Thanks Guys....
Just dawned on me when I wrote this post, I gave a big block 727 to a friend so he could teach himself 727 rebuilding.. I'll see if he'll "swap" me it back for the small block 727 I have here at the house.... I will also call some shops as well....... Good idea......
Troy
Re: new 727 case [Re: hemi68charger] #1685139
10/13/14 04:20 PM
10/13/14 04:20 PM
Ontario, Canada
Dodgem Offline
Dodgem  Offline
Ontario, Canada
When I had that issue it was the starter being held at an angle by the block. some new starters mini have this issue.
