new 727 case
#1685134
10/13/14 09:32 AM
10/13/14 09:32 AM
Posts: 8,828 Houston, Tx
hemi68charger
Houston, Tx
Hey Gang..
I believe I found the root cause of my starter woes and now broken teeth on my new torque converter, the housing of the 727 isn't true and the starter isn't lining up properly. Is there a source for bare 727 cases? The guts of the tranny are fine..
Cheers,
TroyHouston Mopar Connection Club'69 Charger Daytona 440 - auto - 4.10 Dana (now with 426 hemi) '69 Charger 500 440 - 4speed - 3.54 Dana '70 Road Runner 383 - 4speed - a/c (now with 440)
Re: new 727 case
[Re: moparguy7074]
#1685137
10/13/14 10:37 AM
10/13/14 10:37 AM
Posts: 1,514 AZ
Mike P
AZ
I'd check the local transmission shops. When I needed a 518 case for mockup on my hot rod I went to the shop down the road and picked up a bare case, tail housing and pan for $50 and they even ran it thru their parts washer for me.
1957 Plymouth (Hemi, Dual Quads, A833 4 Speed 9 1/4 w 4.10) Sold 1937 Dodge Pickup (Hemi, 6X2 intake, 46RH, Dana 60 w 4.56) Sold 1968 Plymouth Valiant 2dr sedan (354 HEMI, 46RH w/4.30 gears) under construction
Re: new 727 case
[Re: Mike P]
#1685138
10/13/14 10:58 AM
10/13/14 10:58 AM
hemi68charger
Houston, Tx
Thanks Guys....
Just dawned on me when I wrote this post, I gave a big block 727 to a friend so he could teach himself 727 rebuilding.. I'll see if he'll "swap" me it back for the small block 727 I have here at the house.... I will also call some shops as well....... Good idea......
