Quick ratio pitman arms and E bodies #1684854
10/12/14 06:43 PM
10/12/14 06:43 PM
Rescue CA.
joes68340s Offline OP
Rescue CA.
TTI headers there is some confusion on my part. Can quick ratio pitman arm work with tti headers on E bodies.
Re: Quick ratio pitman arms and E bodies [Re: joes68340s] #1684855
10/12/14 06:48 PM
10/12/14 06:48 PM
SoCal
MuuMuu101 Offline
I got lucky at Woodward!
MuuMuu101  Offline
SoCal
Which engine?
Re: Quick ratio pitman arms and E bodies [Re: MuuMuu101] #1684856
10/12/14 07:08 PM
10/12/14 07:08 PM
Rescue CA.
Rescue CA.
!970 340 Cuda.
Re: Quick ratio pitman arms and E bodies [Re: joes68340s] #1684857
10/12/14 07:37 PM
10/12/14 07:37 PM
NorCal
RylisPro Offline
RylisPro  Offline
NorCal
I have Doug's D453 headers and fast ratio arms on my 340 ebody
73 `Cuda
Instagram: @rylispro
YouTube: RylisPro
www.rylispro.com
925-214-9192
Re: Quick ratio pitman arms and E bodies [Re: RylisPro] #1684858
10/14/14 02:51 AM
10/14/14 02:51 AM
Kings Beach, CA
tahoechallenge Offline
Kings Beach, CA
I use the fast ratio pitman and idler arms on my 340 powered Challenger with TTi's with no problems. I did remove the grease fitting from the idler. It rubbed the header a little.
Re: Quick ratio pitman arms and E bodies [Re: tahoechallenge] #1684859
10/14/14 05:18 PM
10/14/14 05:18 PM
Rescue CA.
Rescue CA.
Thanks for replys
Re: Quick ratio pitman arms and E bodies [Re: tahoechallenge] #1684860
10/14/14 05:52 PM
10/14/14 05:52 PM
central CT
cudazappa Offline
cudazappa  Offline
central CT
I had a worn engine mount with my doug's small block headers and fast ratio and encountered the same problem. Changed the mounts and I'm fine now.
1971 Challenger
Re: Quick ratio pitman arms and E bodies [Re: cudazappa] #1684861
10/14/14 06:59 PM
10/14/14 06:59 PM
Mesa, Arizona
dart4forte Online boogie
dart4forte  Online Boogie
Mesa, Arizona
Must be a common problem on all B bodies. I have a 71 RR and had the same problem. Had to remove the grease zerk.
Re: Quick ratio pitman arms and E bodies [Re: dart4forte] #1684862
10/16/14 06:42 AM
10/16/14 06:42 AM
the frozen wastes...
Pale_Roader Offline
Swears too much
Pale_Roader  Offline
Swears too much
Hmmm... ANOTHER point for the smallblock over the bigblock... I'm never going to decide...
Re: Quick ratio pitman arms and E bodies [Re: Pale_Roader] #1684863
10/16/14 09:20 AM
10/16/14 09:20 AM
Ontario,Canada
brads70 Offline
brads70  Offline
Ontario,Canada
I'm using headman headers and FF quick ratio arms with my 451" no problems. Well not exactly true header fitment was an issue.
Re: Quick ratio pitman arms and E bodies [Re: Pale_Roader] #1684864
10/18/14 09:22 AM
10/18/14 09:22 AM
MD
RTSE4ME Offline
RTSE4ME  Offline
MD
FF quick ratio arms with 2" TTI headers on my 505" RB. Plenty of clearance.
