Re: 7 1/4 rear question
[Re: Slipknot440]
#1684830
10/12/14 04:20 PM
10/12/14 04:20 PM
Posts: 1,482 Lake Orion, MI
goldduster318
Lake Orion, MI
All of those engines have too much power for a 7 1/4. You need at the very least an 8 1/4 axle.
A friend of mine had the later c-clip version in a 93 Dakota 2.5 I4 and broke it. Also had another friend who had an 88 Diplomat with a stock 318 and broke it. Everything about that axle is WEAK
'70 Duster 470hp 340/T56 Magnum/8 3/4 3.23 Sure-Grip
[Re: Slipknot440]
#1684832
10/12/14 08:26 PM
10/12/14 08:26 PM
RapidRobert
Randys has 4:10 gears for it (lowest available) & good spiders (a weak point) but as said it'd be money wasted. I would locate an A body 8&3/4 which'd be SBP (& $$$) or a truck/E body 8&3/4 which'd be reasonable (& BBP) & have Moser shorten the housing/axles
[Re: Slipknot440]
#1684836
10/16/14 03:51 PM
10/16/14 03:51 PM
Posts: 12,419 Kalispell Mt.
HotRodDave
Kalispell Mt.
I used to drag race a 66 dart with mostly stock 360 and 7.25 rears and they usually only lasted a few weeks and yes it was the spiders pretty much every time. I never found a posi in one till I had moved on from that gig.
