7 1/4 rear question #1684829
10/12/14 04:01 PM
10/12/14 04:01 PM
Dalton, MA
Slipknot440 Offline OP
Dalton, MA
My 71 swinger has a 7 1/4 rear with 2.76 gears. How much HP/tq is too much for this rear. Was looking at a few 360s, 340hp-401hp, 340 tq-440 tq.
Re: 7 1/4 rear question [Re: Slipknot440] #1684830
10/12/14 04:20 PM
10/12/14 04:20 PM
Lake Orion, MI
goldduster318 Offline
Lake Orion, MI
All of those engines have too much power for a 7 1/4. You need at the very least an 8 1/4 axle.
A friend of mine had the later c-clip version in a 93 Dakota 2.5 I4 and broke it. Also had another friend who had an 88 Diplomat with a stock 318 and broke it. Everything about that axle is WEAK
'70 Duster 470hp 340/T56 Magnum/8 3/4 3.23 Sure-Grip
Re: 7 1/4 rear question [Re: goldduster318] #1684831
10/12/14 07:23 PM
10/12/14 07:23 PM
Canada
WO23Coronet Offline
WO23Coronet  Offline
Canada
Between my parents, myself and my brother we had 5 different cars with 7 1/4's back in the 90's and everyone of them blew up, all with weak 318 lean burns in M bodies
Re: 7 1/4 rear question [Re: Slipknot440] #1684832
10/12/14 08:26 PM
10/12/14 08:26 PM
Randys has 4:10 gears for it (lowest available) & good spiders (a weak point) but as said it'd be money wasted. I would locate an A body 8&3/4 which'd be SBP (& $$$) or a truck/E body 8&3/4 which'd be reasonable (& BBP) & have Moser shorten the housing/axles
Re: 7 1/4 rear question [Re: RapidRobert] #1684833
10/12/14 09:06 PM
10/12/14 09:06 PM
Pangaea
B5 Bee Offline
B5 Bee  Offline
Pangaea
A Sure Grip unit will help distribute the load on the spiders so they will take more abuse but they are not available new and are hard to come by used.
Bottom line is they are not worth putting any money into. Baby what you have till you can swing an 8.75.
I'd go with what RR said, a core unit from a late B, a C or a truck, narrow it and buy some good LBP axles.
Re: 7 1/4 rear question [Re: B5 Bee] #1684834
10/13/14 04:59 AM
10/13/14 04:59 AM
Freeport IL USA
poorboy Offline
poorboy  Offline
Freeport IL USA
And all that said, which I agree with, but I owned a 65 Barracuda that originally had a 273 4 speed, followed by a hot 318 4 speed that I drove very hard, still had its original 3:23 gear open 7 1/4 when I sent it down the road.
I believe the single wheel smoke show wiped out more 7 1/4 spider gears that any other cause. Most 7 1/4"s I've seen broken were usually spider gear failure related. Gene
Re: 7 1/4 rear question [Re: poorboy] #1684835
10/15/14 09:17 PM
10/15/14 09:17 PM
Dalton, MA
Dalton, MA
Just making sure. I know a guy that has an 8 3/4 or 2 i,ll have to talk him out of
Re: 7 1/4 rear question [Re: Slipknot440] #1684836
10/16/14 03:51 PM
10/16/14 03:51 PM
Kalispell Mt.
HotRodDave Offline
HotRodDave  Offline
Kalispell Mt.
I used to drag race a 66 dart with mostly stock 360 and 7.25 rears and they usually only lasted a few weeks and yes it was the spiders pretty much every time. I never found a posi in one till I had moved on from that gig.
