Yippee ! Lucky me, time to rebuild the front suspension #1683781
10/09/14 09:41 AM
10/09/14 09:41 AM
S.E. South Dakota !
bigdad Offline OP
Still Posting A Lot
bigdad  Offline OP
Still Posting A Lot
S.E. South Dakota !
On the 2005 Magnum
It appears that at 80,000 miles the front suspension parts are all worn out
Seems that with a problem this widespread a re-call should of been made to cure it
Any tips, suggestions I may need
Looks like parts are going to be around $500
The lips of fools bring them strife, and their mouths invite a beating.Proverbs 18:6
Re: Yippee ! Lucky me, time to rebuild the front suspension [Re: bigdad] #1683782
10/09/14 10:39 AM
10/09/14 10:39 AM
Central Ohio
BMChrysler68 Offline
Smarter than the average bear? I think not.
Central Ohio
You'll need to disconnect the spindle from the upper control arm to change the struts. Use a small tie rod end puller to break the ball joint taper instead of a pickle fork. You'll avoid tearing the boot up that way.
You'll also need to do tie rod ends, sway bar end links, sway bar bushings and tension struts. The tension struts have their own ball joint and there's really no way around using a pickle fork unless you have the clearance to give the stud and good whack from underneath. Just do your best to avoid tearing up the boot on the LCA ball joint. they're pretty close to one another.
If you're going wild and replacing control arms while you're in there, ignore everything I've said and have fun.
1968 Plymouth Fury III
2dr FT, 383-4v, 4 speed
1972 AMC Ambassador SST wagon
360-4v, automatic
2014 Challenger R/T Classic 6-speed
