a518 kickdown???? #1683700
10/09/14 06:43 AM
10/09/14 06:43 AM
mn
moparguy93 Offline OP
mn
I have a a518 and I recently put a transgo full manual shift kit in it. The question I have is do I have to hook up the kick down or not?? Some people say to yes and some say no.. so what should I doooo?
Re: a518 kickdown???? [Re: moparguy93] #1683701
10/09/14 09:11 AM
10/09/14 09:11 AM
louisiana,usa
O
olemopar Offline
olemopar  Offline
O
louisiana,usa
If you did not modify the throttle valve you will have to hook it up for pressure on acceleration
Re: a518 kickdown???? [Re: olemopar] #1683702
10/09/14 11:20 AM
10/09/14 11:20 AM
Guitar Jones Offline
IIRC that kit gives you instructions to either tie the throttle pressure lever back or block the valve or internal lever to push the throttle pressure valve all the way in.
Re: a518 kickdown???? [Re: moparguy93] #1683703
10/09/14 02:39 PM
10/09/14 02:39 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
The linkage is optional, if you install it the part throttle shifts will be less firm than if you tie the lever full back. With the lever tied full back the part throttle shifts will be real firm.
