Re: what is the difference 65 vs 66 torsion bar crossmember [Re: moparmarks] #1683497
10/09/14 10:38 PM
10/09/14 10:38 PM
Andrewh Online content OP
Andrewh  Online Content OP
but the engine sits farther forward too.
so my thought was if the torsion bar crossmember stayed in the same "spot" the sleeves should be longer to take up the movement.
eh.
thanks either way. probably won't matter to me for a while, but at least I know they are different and am not guessing.
Re: what is the difference 65 vs 66 torsion bar crossmember [Re: Andrewh] #1683498
10/09/14 11:26 PM
10/09/14 11:26 PM
Western Md.
skicker Offline
"The Champ"
skicker  Offline
"The Champ"
Western Md.
K frame is located in the same place. Motor is forward ie trany mount is forward ie trany mount cross member is forward ie tosion bar sleeves are further back. BTW all this crap only works if the torsion bars are the same length and I can't remember...
I have to volley back to you Mark, you'll know this one. 65-66 torsion bars the same length?
...FAFO...
Re: what is the difference 65 vs 66 torsion bar crossmember [Re: skicker] #1683499
10/10/14 12:05 AM
10/10/14 12:05 AM
Western Colorado High Desert
moparmarks Offline
moparmarks  Offline
Yep 62-72 B takes the same length bars.
Desert Mopar Metal
Grand Jct. CO
970-261-7039
http://moparmark.com/
motormangj@gmail.com
Re: what is the difference 65 vs 66 torsion bar crossmember [Re: moparmarks] #1683500
10/10/14 12:12 AM
10/10/14 12:12 AM
Western Md.
skicker Offline
"The Champ"
skicker  Offline
"The Champ"
Western Md.
I guess that's all ironed out.
So whats next?
...FAFO...
Re: what is the difference 65 vs 66 torsion bar crossmember [Re: skicker] #1683501
10/10/14 10:25 AM
10/10/14 10:25 AM
lol, like I said above, it means I can't use the repro one's for 66 and up. so caps it is.
Re: what is the difference 65 vs 66 torsion bar crossmember [Re: Andrewh] #1683502
10/10/14 10:40 AM
10/10/14 10:40 AM
moparmarks Offline
moparmarks  Offline
I have a 62-5 cross member but its going to a while before I drill out that car. How soon did you need it?
Desert Mopar Metal
Grand Jct. CO
970-261-7039
Re: what is the difference 65 vs 66 torsion bar crossmember [Re: moparmarks] #1683503
10/10/14 01:39 PM
10/10/14 01:39 PM
I don't plan on doing anything till mid to late next year if at all.
I have a longer list of bolt on things I have to fix first.
but thanks.
