Re: Dumb rim question
[Re: Pynzo]
#1682393
10/05/14 05:52 PM
10/05/14 05:52 PM
Posts: 104,346 Garden Grove, CA
OzHemi
Penguin-hating Ginger
Garden Grove, CA
Looks like unilug- both 4.5" ford \chysler and 4.75"gm. Get some better wheels front and back. Factory style steelies can be bought at Jegs and Summit under $100 each.
Better ?
Nothing wrong with dual bolt pattern centers, I buy hundreds of them from Carlise wheel...
They are stamped tha way, not drilled.
[Re: Pynzo]
#1682396
10/05/14 06:26 PM
10/05/14 06:26 PM
OzHemi
Garden Grove, CA
Better Ones that are true to the application- not some fits everything universal junk. Backspacing is important too. Unilugs suck. My
They are not uni-lug wheels. Unilug wheels have a single hole for each stud that is a slot shape basically, and use a large or oval shape washer on a mag style nut.
Dual pattern wheels have 2 seperate sets of holes for each bolt pattern. Being a stamped steel center, there is no problem at all with them.
But to each their own I suppose...but if they fit fine seems like a waste to change them unless you just wanted to for some other reason.
You could buy another pair of smoothie steelies for the front and be off and running, if you wanted at least.
