Re: CSR tranny shield question
[Re: dizuster]
#1682137
10/05/14 12:29 PM
10/05/14 12:29 PM
Posts: 10,542 BROOK PARK, OH
WILD BILL
BROOK PARK, OH
Ted, When I was upgrading everything for the new motor set up one thing I wanted was a CSR shield to have a clean look and avoid the hassle of a blanket and separate flexplate shield.
Well, I ordered one from Summit, trimmed my case, and not one of the bolt holes would line up. I even went so far as to throw the trans in the back of the van and drive down to summit and test each each of the remaining 3 they had in stock.
Not one of them would allow me to install all the bellhousing bolts.
I gave up on the thought and just installed the blanket and flexplate sheild.
ANd, to be honest, after seeing some of the pics that have been posted over the years of those shields not containing a front drum explosion I feel 1000 times better about that decision. (even though I now have a billet drum)
[Re: WILD BILL]
#1682139
10/05/14 12:40 PM
10/05/14 12:40 PM
Posts: 1,855 Staten Island N.Y.
Dap
Staten Island N.Y.
I bought the CSR shield from CRT and put it in over the summer. It is a tight fit in my duster. The shield fit the case with no trimming needed.
PRH446 10.084 @ 135.21 mph N/A through chambered mufflers,3300lbs. Stock stroke wedge
[Re: WILD BILL]
#1682140
10/05/14 12:40 PM
10/05/14 12:40 PM
Posts: 2,540 Milwaukee WI
TRENDZ
Milwaukee WI
I also had issues with bolt hole alignment. It's like they take a guess at where they should be. Because it's an sfi part, it can't be modified. I sent mine back to the manufacturer, and they ground the hole bigger, and put an oversized bushing in it. It came back(modified) and still was wrong. I fixed it myself and swore I would badmouth them every chance I get.
[Re: TRENDZ]
#1682141
10/05/14 12:45 PM
10/05/14 12:45 PM
TRENDZ
Milwaukee WI
I also found it much easier to put studs in the engine bellhousing instead of bolts.
[Re: TRENDZ]
#1682142
10/05/14 12:54 PM
10/05/14 12:54 PM
Posts: 34,927 S.E. South Dakota !
bigdad
Still Posting A Lot
Still Posting A Lot
S.E. South Dakota !
I had one in the 64, It fit the case ok but, the floor ..ahhhhh, no Now, on the Valiant we pre-planned for that If you don't want to cuss and chop up the floor, use a blankey
[Re: tboomer]
#1682144
10/05/14 02:06 PM
10/05/14 02:06 PM
WILD BILL
BROOK PARK, OH
Can you even go that fast?
[Re: tboomer]
#1682146
10/05/14 02:40 PM
10/05/14 02:40 PM
WILD BILL
BROOK PARK, OH
Without being pushed
[Re: tboomer]
#1682149
10/05/14 04:40 PM
10/05/14 04:40 PM
WILD BILL
BROOK PARK, OH
You haven't been around much..Have you Blue Boy?
I guesse not.
I don't even have a rule book that isn't a couple years old
