CSR tranny shield question #1682134
10/05/14 11:23 AM
10/05/14 11:23 AM
tboomer Online work OP
tboomer  Online Work OP
I am thinking ahead to next season. One item I would like to put on the 64 is a CSR tranny shield to replace the blanket that is currently on it. Anyone have clearance problems putting one on an early B body? Thanks!! Ted
Re: CSR tranny shield question [Re: tboomer] #1682135
10/05/14 11:37 AM
10/05/14 11:37 AM
Oakland, MI
dizuster Offline
dizuster  Offline
Oakland, MI
I just put one on my 62 this winter to replace my blanket.
Cut the ears off both sides of the trans case, and I had to hammer the floor up in a couple places.
No cutting required though for me.
Cools MUCH better then the blanket did.
Re: CSR tranny shield question [Re: tboomer] #1682136
10/05/14 12:27 PM
10/05/14 12:27 PM
aZLiViN
J_BODY Offline
J_BODY  Offline
aZLiViN
If you're not running 9's Id continue to use the blanket.... I don't have an early B, but something I'd highly consider is to get your hole saw out and cut holes in the floor board to access the bell housing bolts. We ran the Lofgren blanket for years on both cars..... if a blanket is causing your trans to heat up, you have much bigger probs in my book...
In my conversation pertaining to my A body in which the shield wouldn't fit with the 727, Big Dad mentioned that he too had to cut the floor in his old B car to get the sheild to fit.
Re: CSR tranny shield question [Re: dizuster] #1682137
10/05/14 12:29 PM
10/05/14 12:29 PM
BROOK PARK, OH
WILD BILL Offline
WILD BILL  Offline
BROOK PARK, OH
Ted, When I was upgrading everything for the new motor set up one thing I wanted was a CSR shield to have a clean look and avoid the hassle of a blanket and separate flexplate shield.
Well, I ordered one from Summit, trimmed my case, and not one of the bolt holes would line up. I even went so far as to throw the trans in the back of the van and drive down to summit and test each each of the remaining 3 they had in stock.
Not one of them would allow me to install all the bellhousing bolts.
I gave up on the thought and just installed the blanket and flexplate sheild.
ANd, to be honest, after seeing some of the pics that have been posted over the years of those shields not containing a front drum explosion I feel 1000 times better about that decision. (even though I now have a billet drum)
Re: CSR tranny shield question [Re: WILD BILL] #1682138
10/05/14 12:34 PM
10/05/14 12:34 PM
aZLiViN
J_BODY Offline
J_BODY  Offline
aZLiViN
That's why I prefer the blanket Bill.... it absorbs the shock of the explosion. At the point of the violence it's probably better to try and slow stuff down than to contain it. FWIW the shield I purchased from John Cope all the bell bolts fit.... a couple looked to be "off" but I was able to get the bolts in and started.
see? no clearance probs.
Re: CSR tranny shield question [Re: WILD BILL] #1682139
10/05/14 12:40 PM
10/05/14 12:40 PM
Staten Island N.Y.
Dap Offline
Dap  Offline
Staten Island N.Y.
I bought the CSR shield from CRT and put it in over the summer. It is a tight fit in my duster. The shield fit the case with no trimming needed.
PRH446
10.084 @ 135.21 mph N/A through chambered mufflers,3300lbs. Stock stroke wedge
Re: CSR tranny shield question [Re: WILD BILL] #1682140
10/05/14 12:40 PM
10/05/14 12:40 PM
Milwaukee WI
TRENDZ Offline
TRENDZ  Offline
Milwaukee WI
I also had issues with bolt hole alignment. It's like they take a guess at where they should be. Because it's an sfi part, it can't be modified. I sent mine back to the manufacturer, and they ground the hole bigger, and put an oversized bushing in it. It came back(modified) and still was wrong. I fixed it myself and swore I would badmouth them every chance I get.
Re: CSR tranny shield question [Re: TRENDZ] #1682141
10/05/14 12:45 PM
10/05/14 12:45 PM
Milwaukee WI
TRENDZ Offline
TRENDZ  Offline
Milwaukee WI
I also found it much easier to put studs in the engine bellhousing instead of bolts.
Re: CSR tranny shield question [Re: TRENDZ] #1682142
10/05/14 12:54 PM
10/05/14 12:54 PM
S.E. South Dakota !
bigdad Offline
Still Posting A Lot
bigdad  Offline
Still Posting A Lot
S.E. South Dakota !
I had one in the 64, It fit the case ok but, the floor ..ahhhhh, no
Now, on the Valiant we pre-planned for that
If you don't want to cuss and chop up the floor, use a blankey
Re: CSR tranny shield question [Re: bigdad] #1682143
10/05/14 12:59 PM
10/05/14 12:59 PM
I have the blanket on it now. But it is not SFI. No tranny cooling problems as it has a good cooler on it. What are the rules for 9.99 and quicker?
Re: CSR tranny shield question [Re: tboomer] #1682144
10/05/14 02:06 PM
10/05/14 02:06 PM
BROOK PARK, OH
WILD BILL Offline
WILD BILL  Offline
BROOK PARK, OH
Can you even go that fast?
Re: CSR tranny shield question [Re: WILD BILL] #1682145
10/05/14 02:10 PM
10/05/14 02:10 PM
Maybe...
Re: CSR tranny shield question [Re: tboomer] #1682146
10/05/14 02:40 PM
10/05/14 02:40 PM
BROOK PARK, OH
WILD BILL Offline
WILD BILL  Offline
BROOK PARK, OH
Without being pushed
Re: CSR tranny shield question [Re: WILD BILL] #1682147
10/05/14 02:41 PM
10/05/14 02:41 PM
You haven't been around much..Have you Blue Boy?
Re: CSR tranny shield question [Re: tboomer] #1682148
10/05/14 03:01 PM
10/05/14 03:01 PM
s.w.fl
bonefish Offline
bonefish  Offline
s.w.fl
my sheild didnt fit either.i had to install it without one bushing to get it in.in all my years ive never had tech check my sheild.
Re: CSR tranny shield question [Re: tboomer] #1682149
10/05/14 04:40 PM
10/05/14 04:40 PM
BROOK PARK, OH
WILD BILL Offline
WILD BILL  Offline
BROOK PARK, OH
I guesse not.
I don't even have a rule book that isn't a couple years old
Re: CSR tranny shield question [Re: tboomer] #1682150
10/05/14 06:47 PM
10/05/14 06:47 PM
somwhere
smokinwoody Offline
smokinwoody  Offline
somwhere
Ted..I have one and used it in the Duster...I set the engine back 6" in the 63 Dodge in which I had to cut the trans tunnel...
what I may do is, when I'm ready, is order the JW Bell and cut the factory Bell off..this way there's more protection should a converter let go and I'll probably use a blanket unless there's a scatter shield out there that fits around the trans part..
food for thought
Re: CSR tranny shield question [Re: smokinwoody] #1682151
10/05/14 11:07 PM
10/05/14 11:07 PM
Balt. Md
3
383man Offline
383man  Offline
Balt. Md
My brother runs the shield on his 64 and he told me all he did was cut the ears on the trans for a good fit. I dont know what brand but I will ask him tomorrow.
I put a blanket on my 63 last year and I was hoping to go to the shield next year as I thought it would be better if it did ever explode. Is the shield much better then the blanket ? And will the blanket help much at all if the trans goes boom ? Ron
