Teflon tape work with diesel fuel? #1681985
10/04/14 03:54 PM
10/04/14 03:54 PM
NW Ohio
6pkaar Offline OP
6pkaar  Offline OP
NW Ohio
Does teflon tape work OK with diesel fuel? This would be submerged in a tank, so will have contact 100% of the time.
Re: Teflon tape work with diesel fuel? [Re: 6pkaar] #1681986
10/04/14 06:43 PM
10/04/14 06:43 PM
IL, Aurora
ademon Offline
ademon  Offline
IL, Aurora
I know they make a yellow tape that is for gas and othe applications that might work better. You probably should not use tape on fuel lines.
Re: Teflon tape work with diesel fuel? [Re: ademon] #1681987
10/04/14 07:23 PM
10/04/14 07:23 PM
NW Ohio
6pkaar Offline OP
6pkaar  Offline OP
NW Ohio
This isn't for a fuel line. I'm getting tired of running to the gas station with my 5 gallon cans to get diesel fuel for my compact tractor and zero turn mower so I'm setting up a pump for them. The suction line for the pump will have a foot valve on the bottom of it that goes in a 275 gallon tank. I just wondered if teflon tape would work there (since I have lots of that around). I have some pipe dope too, but it doesn't say anything about being compatable with petroleum products. I think the yellow is for natural gas lines.
Re: Teflon tape work with diesel fuel? [Re: 6pkaar] #1681988
10/04/14 08:07 PM
10/04/14 08:07 PM
Spring City , Pa.
SIKPUP Offline
SIKPUP  Offline
Spring City , Pa.
I would use Teflon paste and wipe off the extra... I don't think you would even have to do anything to it...being submerged all the time it wouldn't suck air.
Re: Teflon tape work with diesel fuel? [Re: SIKPUP] #1681989
10/04/14 10:03 PM
10/04/14 10:03 PM
IN
ahy Offline
ahy  Offline
IN
I believe the Teflon tape will seal... but not preferred for fuel since little threads or bits of tape can get in the fuel. Teflon pipe dope will work without the problem of debris. Just double check the label for fuel compatibility.
Re: Teflon tape work with diesel fuel? [Re: ahy] #1681990
10/05/14 01:03 PM
10/05/14 01:03 PM
Cincinnati, Ohio
Challenger 1 Offline
Cincinnati, Ohio
Exactly...
Best rule of thumb is to never use teflon tape on any thing fuel related.
Keep the teflon tape for water service, and even for nat or LP gas service the bit's of teflon tape can get into gas valves and cause trouble if not applied correctly. Pipe dope is better then too.
Use pipe dope sparingly and always keep it back one or two threads from the end and only apply it to the male threads of tapered pipe fittings.
Re: Teflon tape work with diesel fuel? [Re: 6pkaar] #1681991
10/05/14 05:24 PM
10/05/14 05:24 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
Re: Teflon tape work with diesel fuel? [Re: John_Kunkel] #1681992
10/05/14 10:11 PM
10/05/14 10:11 PM
Downtown Roebuck Ont
Twostick Offline
Still wishing...
Twostick  Offline
Still wishing...
I have always used teflon tape on any threads that needed to be sealed regardless of what I was plumbing. Used it on countless fuel fittings, gas and diesel. Zero issues ever.
If there is a concern about tape fragments I just make sure I tape back at least 3 threads from the end and pay attention to how I assemble the fittings.
Kevin
Re: Teflon tape work with diesel fuel? [Re: Twostick] #1681993
10/06/14 02:32 PM
10/06/14 02:32 PM
dogdays Offline
dogdays  Offline
As far as the tape itself, Diesel fuel will not affect it.
The warnings about little bits of tape getting in things are everywhere, to the point that it makes me wonder. Probably work just fine. A simple fuel filter should keep any particles out of the engine.
R.
Re: Teflon tape work with diesel fuel? [Re: 6pkaar] #1681994
10/06/14 02:52 PM
10/06/14 02:52 PM
Cincinnati, Ohio
Cincinnati, Ohio
teflon tape also acts as a wick and fuel will wick through teflon tape. That's why it turns yellow because the fuel is wicking/soaking through it. Pipe dope is better all the way around for fuel use.
I will say it again, teflon tape is for water sealing, imo.
We sell fuel nozzles, OPW fuel nozzles and the instructions say not to use teflon tape if you don't want them to malfunction and leak because a lot of people don't know how to use teflon tape.
Read it for yourself. web page
Re: Teflon tape work with diesel fuel? [Re: 6pkaar] #1681995
10/06/14 06:02 PM
10/06/14 06:02 PM
Stinnett, Tx
rumblebee4232 Offline
Stinnett, Tx
If I am reading this correctly you are wanting to use this on fittings that are being used for a pickup for a pump in a storage tank and will remain submerged.. If that is correct why are you even concerned with any kind of sealant?? You dont say what material you are using for suction line but if it is pipe all you need is some lubricant on the threads and screw it together and if it is staying submerged even that is optional( really are you worried about the fuel in the tank leaking into the suction line??)
Re: Teflon tape work with diesel fuel? [Re: rumblebee4232] #1681996
10/06/14 06:24 PM
10/06/14 06:24 PM
Cincinnati, Ohio
Cincinnati, Ohio
I sell, install and use 12v and 120 AC pumps in 275,300,550, and 1000 gallon tanks on a regular basis.
There's no need for a foot valve, I use 1" black iron or galvanized pipe for suction pipe keeping the suction pipe 3-4" off the bottom of the tank so it don't pickup water and sediment off the bottom of the tank.
FYI Never use the telescoping suction pipe that comes with all fuel pumps that is universal for all diameter tanks. Because it will vibrate all the way down until it's touching the bottom of the tank. The pump will still work fine because the telescoping pickup had holes in the side of the pickup pipe, but then you are sucking right off the bottom of the tank which is really bad. And there's no way to lock a telescoping pickup pipe to keep it off the bottom. Use custom cut ridge pipe.
I had a license from the state of Ohio to install and remove UG fuel tanks and have been in the business since the 80s. I did a upgrade in 1993 where we got all new pumps, liners and piping that I did myself.
Here's one of our 6 new UG tanks for our new bulk plant that we got in 2009.
And one of the old ones coming out, these are not gas station tanks, they are much larger.
Back of my truck right now.
Look like a 275 gallon tank, it's actually 2 135 gallon tanks I keep hi and low gasoline in for my mower and hot rods and bring it home in my own personal tanker truck above.
Re: Teflon tape work with diesel fuel? [Re: rumblebee4232] #1681997
10/07/14 12:41 AM
10/07/14 12:41 AM
NW Ohio
6pkaar Offline OP
6pkaar  Offline OP
NW Ohio
Read the post again.... This is for a foot valve. If the threads leak the fuel will run back into the tank and the pump would lose it's prime. Challenger 1, I'm using the same fuel oil tank you've got, except the tank is in the basement of my building (kind of like it wiuld have the same lift as if the tank were burried)k and will have about 20' of suction line to the tank. One reason I figured a foot valve would be a good idea is I'm using an old 1950's Bennett pump i restored, pump is original and still works, but 60 years old and probably would have more issues with leak down than your pump, Figured a foot valve couldn't hurt. I've already got the valve, pipe cut and threaded so pickup is about 3" off the bottom of the tank. Are their any negatives puting a foot valve in? It will be much easier puting one in now rather than later if the pump won't hold it's prime. And OK, I've got the message to get some pipe dope that's compatible and leave the tape in the drawer.
Re: Teflon tape work with diesel fuel? [Re: 6pkaar] #1681998
10/07/14 10:18 AM
10/07/14 10:18 AM
Cincinnati, Ohio
Cincinnati, Ohio
I'm on the fence as far as the foot valve goes, might be a good idea? 20' is reasonable, I have installed a bennett suction dispenser retail pump and connected to a 550 above ground tank with Kero in it. There's about 15-20' of suction pipe with no foot valve. Sure the tank is above ground but there is still 48" of lift required to get the fuel out of the tank. We have been retailing kero out of it for 20 years or so with no prime problems.
Just as long as the foot valve does not rust and start to stick would be my only worry with it, just one more thing to go wrong. Good luck with it!
Re: Teflon tape work with diesel fuel? [Re: Challenger 1] #1681999
10/07/14 11:41 PM
10/07/14 11:41 PM
NW Ohio
6pkaar Offline OP
6pkaar  Offline OP
NW Ohio
It's solid brass, so rust won't be an issue.
