A body front disc brakes
#1681918
10/04/14 02:43 PM
10/04/14 02:43 PM
Posts: 5,207 Menomonee Falls
DemonDust
Menomonee Falls
I've been looking a lot into the front brakes on my duster. I have determined I have 9" drums by measuring the spindle. Now I'm a bit worried that if the car starts to pull the wheels that the spindle may break since it's so small.
Wilwood does make a disc brake kit for this but the spindle still worries me.
What can I do to beef up the front spindle without spending a lot of cash on a spindle? I have been told that something like a Dodge diplomat spindle would work, but then do I need different A arms?
Or am I worrying too much about the small spindle?
The other thing is I don't want to mess with my steering too much anymore, since I have it all dialed in. If I mess with it too much and need an alignment I no longer have access to a dealership and able to mess around on their rack for hours playing with geometry.
Re: A body front disc brakes
[Re: DemonDust]
#1681920
10/04/14 02:57 PM
10/04/14 02:57 PM
Posts: 11,713 Portage,michigan
B3422W5
Portage,michigan
The 67-72 a body's all had small ball joint as far as I know. Just that some are disk, some drum. I did wheel stands with my old car for years, ( raced it a lot) with no issuers ever. 70 Duster wth disk brake spindles. I ended up using aerospace disk brakes, as I believe Willwood doesn't offer a kit for those, just the drum type like you have. At any rate, aerospace demanded i send them my spindles( because people often don't have what they think they have,and they mount the correct caliper brackets for you) I liked the brakes and recommend this avenue of approach. Measure twice, cut once
69 Dart GTS A4 Silver All steel, flat factory hood, 3360race weight 418 BPE factory replacement headed stroker, 565 lift solid cam Best so far, 10.40 @127 1/4 1.41 best 60 foot 6.60 at 103.90 1/8
[Re: B3422W5]
#1681921
10/04/14 04:26 PM
10/04/14 04:26 PM
DemonDust
Menomonee Falls
Thanks for the reassurance guys! I will definitely look into the aerospace stuff. I know it's very good quality. Don, do they charge extra to install the brackets or is that part of the package and good customer service?
[Re: DemonDust]
#1681924
10/04/14 05:40 PM
10/04/14 05:40 PM
B3422W5
Portage,michigan
I honestly can't remember. It's been quite a while. Give them a holler. You might not have a choice. They told me so many guys send stuff back because they send the kit based on customer info, they just have you send the spindles your using,they see what you have, and set them up.
[Re: B3422W5]
#1681925
10/04/14 07:51 PM
10/04/14 07:51 PM
Posts: 145 NJ
cb1289
NJ
I recently purchased Aerospace fronts and they have a ordering worksheet with many different Mopar spindle configurations listed. You match your spindle type with the diagram and give it back to them. Pretty easy process.
62 Dodge Dart Wagon
65 Plymouth Satellite
[Re: cb1289]
#1681926
10/05/14 12:34 AM
10/05/14 12:34 AM
Posts: 1,855 Staten Island N.Y.
Dap
Staten Island N.Y.
I think Demongup (Adam) has a strange front brake set up with the 9" drum spindles set up for the big ball joints for sale.
PRH446 10.084 @ 135.21 mph N/A through chambered mufflers,3300lbs. Stock stroke wedge
[Re: Cab_Burge]
#1681928
10/05/14 01:21 AM
10/05/14 01:21 AM
DemonDust
Menomonee Falls
I know of one older Mopar sponsored SB 4 speed Duster that was very fast(high nines at 149 MPH ) that had nine inch spindles, he did a lot of wheeleis and never broke a spindle BTW, stay away from any auto parts named Aerospace, Aeromotive yes, Aerospace NO
Could you elaborate on why?
[Re: DemonDust]
#1681929
10/05/14 02:04 AM
10/05/14 02:04 AM
B3422W5
Portage,michigan
Aerospace brakes are nice. Ran them for years on a 9 sec car, new owner still has them. Really nice stuff. If Cab is talking about these brakes, and bad mouthing them.... He flat doesn't know what he is talking about. Period.
[Re: B3422W5]
#1681930
10/05/14 04:10 AM
10/05/14 04:10 AM
Posts: 43,204 Bend,OR USA
Cab_Burge
Your right, I have not used any of Aerospace products on the advice of several local shops that have use them and had problems on the all products they used, fuel sustems, brakes, vacume pumps and so on I've used Holley, MSD, BM, Turbo Action, Pro Trans, B&M Strange, Winters, Wilwood, Magnafuel, Comp Cams, Bullet Cams, Ultra Dyne, A1 trans and converters and a lot of the other parts companies out there, no complaints on any of those companys The next question is do you know the difference between good parts and excellent parts I've learned many thngs in racing the hard way, when someone I trust tells me that so and so parts are junk I'm not going to buy and test them to find out about them for myself unless a lot of other people that I know and trust tell me different
[Re: DemonDust]
#1681932
10/05/14 09:43 AM
10/05/14 09:43 AM
Posts: 6,531 Jacksonville, FL
Chris2581
Jacksonville, FL
The 9" drum spindles don't break....it's the lower ball joint bolts that snap.
[Re: Cab_Burge]
#1681933
10/05/14 10:31 AM
10/05/14 10:31 AM
B3422W5
Portage,michigan
Your credibility just went right out the window..... Lol... You have MSD on your list of " good guys".... just had to replace a bad 6 week old box the other day. Had a 6al go bad intermittently( took 2 months to figure out) during a points season few years ago But those aerospace brakes never let me down one time, nor anybody else I am aware of on the board here.
[Re: rebel]
#1681936
10/05/14 09:04 PM
10/05/14 09:04 PM
Posts: 104,346 Garden Grove, CA
OzHemi
Penguin-hating Ginger
Garden Grove, CA
as my Dart got faster & i went past 140mph i found i needed better brakes or buy a chute. so i bought these Bendix conversion brake kit. bigger rotors 2 pot calipers & twice the size pads & now i pull up real good. was a good buy of e-bay too.
Are those from UPC/mrspares ?
They look sorta familiar
