Re: how high can a/have you seen a 440 wind up?
[Re: cdoublejj]
#1681791
10/04/14 10:17 AM
10/04/14 10:17 AM
Posts: 1,444 NEW JERSEY
dynamite
NEW JERSEY
I've heard regularly into the 7 K range, but my tub runs out if steam over 6 K,and yes this " picture " is shopped
[Re: scatpacktom]
#1681795
10/04/14 10:46 AM
10/04/14 10:46 AM
Posts: 1,646 Ringtown, Pa.
Dartsport540
Ringtown, Pa.
I shift at 6100, and go thru the traps at 6700 to 6800... I tried shifting at RPM's up to 7000, it didn't go any faster. So, there is no sense turning it any harder than needed......
548 cu. in., Bill Mitchell Aluminum Block, CRT 727 auto trans, Alston Chassis. 8.981et at 149.46 mph. 1.204et - 60 foot, So Far....
[Re: 68LAR]
#1681797
10/04/14 11:33 AM
10/04/14 11:33 AM
Posts: 21,065 Niles , Ohio
therocks
Niles , Ohio
Shift at about 68.Its been higher but I dont like going much more.Rocky
Chrysler Firepower
[Re: Cab_Burge]
#1681799
10/04/14 04:52 PM
10/04/14 04:52 PM
Posts: 1,468 N.Y.
sixpacksteve
N.Y.
a stock 440 is about done making power at 5300 my 505 stroker has been 7300 rpm
Hell Hath No Fury Like Mine
[Re: cdoublejj]
#1681801
10/04/14 10:05 PM
10/04/14 10:05 PM
Posts: 15,323 Omaha Ne
TJP
Omaha Ne
how high can a 440 wind up? or how have you seen one go?
A lot of variables to answer the question Stock bottom end of modified????
[Re: cdoublejj]
#1681802
10/04/14 10:43 PM
10/04/14 10:43 PM
Posts: 3,696 jersey
Spaceman Spiff
jersey
Till just before a pushrod breaks through a rocker and comes out the valve cover....or you drive over the crank. But up to that point, you're fine...
526 cubes of angry wedge, pushbutton shifted, 9 passenger killer!
[Re: moparx]
#1681805
10/05/14 11:59 AM
10/05/14 11:59 AM
Posts: 5,108 Chicago Blackhawks
hemicar1971
Chicago Blackhawks
More information is needed to answer the question you have asked. You can Rev a motor beyond its maximum HP range and it will drop off in HP but still gain in RPM. My Race Hemi 430 CI was shifted at 9000 RPM, through the traps at 9900 RPM, making power. Good equipment is a must and good heads and cam and exhaust and intake is also a must. A 440 needs the same things, still a stock 440 motor is good to 5500 to 6400 RPM for making power depending on what 440 motor. The 440 bottom end has the same basic mathematics as a Hemi so you choice via you parts how high it can Rev.
1971 HEMI E BODY REGISTRY
[Re: cudaman1969]
#1681808
10/05/14 04:14 PM
10/05/14 04:14 PM
Posts: 4,794 Castlegar, BC, Canada
That AMC Guy
Once at the track, my buddy missed the 2-3 shift in his Charger. He claims he pegged the tach (8k). I'm not sure what was louder: the noise the engine made or the profanity he yelled, because we heard both. Several weeks later we learned exactly how much damage was done.
Bloody Mary, Full of Vodka, Blessed art thou among cocktails....
