Re: ONE WIRE ALTERNATOR
[Re: Cab_Burge]
#1681703
10/04/14 01:32 AM
10/04/14 01:32 AM
Posts: 27,421 Balt. Md
383man
Balt. Md
CAB is right but with the one wire alt you can actually just put it on the car and just hook the stock output wire up and it will work and charge. Is always good to update your wireing and bulkhead but it will work with just the main hot output wire hooked up as thats all it needs since it self excites itself. Just leave the field wires unhooked and tape them back in the harness as you dont need them with the one wire alt. Ron
