pulling dist. drive gear #1680818
10/01/14 10:24 PM
10/01/14 10:24 PM
Ia
4spdana Offline OP
4spdana  Offline OP
Ia
need to pre-lube engine, can,t get dist. drive gear out.
it's in a 426 Hemi with the Milodon dual swinging pick-up.
........what works best?
tried screw driver... a snap ring pliers
Re: pulling dist. drive gear [Re: 4spdana] #1680819
10/01/14 10:55 PM
10/01/14 10:55 PM
Rittman Ohio
fourgearsavoy Offline
Rittman Ohio
Sometimes turning the engine and pulling with retaining ring pliers works
Gus
64 Plymouth Savoy
Dana 60
Re: pulling dist. drive gear [Re: fourgearsavoy] #1680820
10/01/14 11:02 PM
10/01/14 11:02 PM
mopar346 Offline
Let me tell ya about fat chicks!
mopar346  Offline
I've also used a screwdriver to walk it above the cam gear and then a 90* pick to lift it up further and out.
Careful, your character's showing!
Re: pulling dist. drive gear [Re: mopar346] #1680821
10/02/14 12:33 AM
10/02/14 12:33 AM
Make a hangmans' noose out of real thin wire, thin like parts tag wire & drop it down & hook it under the gear then get the gear loose & starting to come up with (2) L pics or heavier coat hangar wire with an L bend in the end(s) then with it free hold it up a hair with the parts tag wire & remove the (2) L wires & pull it up thru the tight opening the rest of the way with the parts tag wire
Re: pulling dist. drive gear [Re: 4spdana] #1680822
10/02/14 10:56 AM
10/02/14 10:56 AM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
Do you have a long pair of needle nose pliers , or a pair of needle nose visegrips ? Remember to turn it in the opposite direction of normal rotation while pulling up.
Re: pulling dist. drive gear [Re: JohnRR] #1680823
10/02/14 01:35 PM
10/02/14 01:35 PM
crlush Offline
crlush  Offline
Ive use 2 of the same screwdrivers (I have craftsman) after you spin it out of the threads stick them in the slot next to each other then squeeze the handles together and pull up. Works every time for me
Re: pulling dist. drive gear [Re: crlush] #1680824
10/02/14 01:41 PM
10/02/14 01:41 PM
CT
GTX MATT Online content
GTX MATT  Online Content
CT
Turn it with a screw driver first to drive it over the cam, then take a pair of regular pliers, open them up to the wider setting (handles closer together), stick one half in the drive slot and the other on the outside. Squeeze and pull. Works like a charm.
Re: pulling dist. drive gear [Re: 4spdana] #1680825
10/02/14 02:47 PM
10/02/14 02:47 PM
AndyF Offline
AndyF  Offline
I have some long reach pliers that will reach the gear. My pair came from SnapOn but you might be able to find similiar pliers from Sears or other tool vendor.
Re: pulling dist. drive gear [Re: 4spdana] #1680826
10/02/14 03:35 PM
10/02/14 03:35 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
Turn the crank backwards.
Re: pulling dist. drive gear [Re: crlush] #1680827
10/02/14 04:43 PM
10/02/14 04:43 PM
Western Md.
skicker Offline
"The Champ"
skicker  Offline
"The Champ"
Western Md.
That's what I do...
...FAFO...
Re: pulling dist. drive gear [Re: skicker] #1680828
10/02/14 10:33 PM
10/02/14 10:33 PM
Kentucky
E
ewolfe Offline
ewolfe  Offline
E
Kentucky
Screwdriver to turn above the cam then I use a big ass magnet. This is super easy and works most every time.
Re: pulling dist. drive gear [Re: ewolfe] #1680829
10/03/14 08:34 AM
10/03/14 08:34 AM
Tennessee
Hemi ragtop Offline
Hemi ragtop  Offline
Tennessee
I bought a set of surgical forcips from a tooling vendor at a car show, about 8" long. They work for me.
Re: pulling dist. drive gear [Re: Hemi ragtop] #1680830
10/03/14 11:28 AM
10/03/14 11:28 AM
Powell, Ohio ( Originally Pitt...
1970Dart3406 Offline
How do you get the small block one out?
Re: pulling dist. drive gear [Re: ewolfe] #1680831
10/03/14 11:55 AM
10/03/14 11:55 AM
s.w.fl
bonefish Offline
bonefish  Offline
s.w.fl
thats how i do it.
Re: pulling dist. drive gear [Re: 4spdana] #1680832
10/03/14 07:07 PM
10/03/14 07:07 PM
Marlboro, NY, USA
Rick_Ehrenberg Offline
Marlboro, NY, USA
I've used virtually every method described, all work OK. The only problem can be on a new build where the bushing wasn't burnished to size with the factory too, then the gear can be almost stuck.
Rick
Re: pulling dist. drive gear [Re: AndyF] #1680833
10/03/14 09:46 PM
10/03/14 09:46 PM
Leucadia, Ca.
V
vdriver Offline
vdriver  Offline
V
Leucadia, Ca.
Re: pulling dist. drive gear [Re: vdriver] #1680834
10/09/14 12:51 AM
10/09/14 12:51 AM
Ia
4spdana Offline OP
4spdana  Offline OP
Ia
i do have the special burnishing tool.....it's like it's stuck in the oil pump
