Page 3 of 3 1 2 3
Re: fast 60 ft, slow mph HELP [Re: sshemi] #1680643
10/08/14 11:25 AM
10/08/14 11:25 AM
sweden
sshemi Offline
sshemi  Offline
sweden
The 130 mph is just an estimate.
To busy keeping it on the road to look at the speedo at whatever the speed is..
Re: fast 60 ft, slow mph HELP [Re: dvw] #1680644
10/08/14 11:26 AM
10/08/14 11:26 AM
Muncie
Racebuddy Offline OP
Muncie
Doug, too much advanced timing???
That is my guess!! the problem is going back to that gear drive and having to sort thru all that again. I was ready to set my hair on fire the first time.
Thinking about a new cam and starting from there
Re: fast 60 ft, slow mph HELP [Re: Racebuddy] #1680645
10/08/14 08:19 PM
10/08/14 08:19 PM
robin hood country
deaks Offline
deaks  Offline
robin hood country
You've got the 60ft of a 9.60 car and the speed of a 10.70 car from there on.
I would do a comp test and check to see where your cam timing is first, if it's way over advanced then retard it and see what happens. You may lose a little on the 60ft but you will make more than that back on the big end.
Mick
69 Dart GTS 440 mopar .590 cam, Edelbrock heads, 3200#
best et 6.45, 106.78, 10.14, 132.88 mph, 1.47 60ft
best 60ft 1.36
Re: fast 60 ft, slow mph HELP [Re: deaks] #1680646
10/08/14 09:15 PM
10/08/14 09:15 PM
North, Alabama
D-50 Offline
D-50  Offline
North, Alabama
I have the same problem. I have a 1.33 60 ft. and run 108 mph most of the time and ran 109 once. According to the calculator on Wallace Racing web sight I should be running 112 mph and 2.5 tenths faster.
1.33 60 ft,6.21 at 110.59 in the 1/8, pump gas small block,2950lbs,drag radials,mufflers and driven to track ...
Re: fast 60 ft, slow mph HELP [Re: Racebuddy] #1680647
10/09/14 12:32 AM
10/09/14 12:32 AM
MI, usa
dvw Offline
dvw  Offline
MI, usa
A cylinder pressure test might point in the correct direction. If the cam is in was early the cranking pressure will be high, top end power will be shifted to lower rpm. Thus big torque, resulting in quick 60 ft. More torque would slip the converter more tightening the rpm drop between gears.
Doug
Re: fast 60 ft, slow mph HELP [Re: dvw] #1680648
10/09/14 01:08 AM
10/09/14 01:08 AM
Las Vegas NV
moparmanjames Offline
Las Vegas NV
A friend of mine had the same issue, I found out when I pulled the timing cover that he was off a whole tooth advanced on his timing chain lol. It pulled like a freight train down low but dropped off big time down track.
Re: fast 60 ft, slow mph HELP [Re: D-50] #1680649
10/09/14 01:29 AM
10/09/14 01:29 AM
Portage,michigan
B3422W5 Offline
B3422W5  Offline
Portage,michigan
To me it's saying you have the chassis sorted out really well, vehicle weight is light, and you are ET ing good without a bunch of horsepower probably 575- 590 horse?
Do you run a lot of gear?
Ever run it in the 1/4
Best so far, 10.40 @127 1/4
1.41 best 60 foot
6.60 at 103.90 1/8
Re: fast 60 ft, slow mph HELP [Re: B3422W5] #1680650
10/09/14 09:05 PM
10/09/14 09:05 PM
North, Alabama
D-50 Offline
D-50  Offline
North, Alabama
There is no 1/4 mile tracks around here. I was running a untuned 950 carb on it when I ran those ET's. I have put the 1050 Dom. on it that it was dynoed with (662 hp)and went to track one time and it would not do nothing but spin really bad (6.80's). I have never had traction problems before so maybe I will get to track 1 more time before end of season and get a new best.
Page 3 of 3 1 2 3
