Re: torker 383 vs TM6 vs perf rpm [Re: Chris2581] #1680422
10/03/14 02:14 AM
10/03/14 02:14 AM
K
KOS Offline OP
KOS  Offline OP
K
thx i kinda figured that.....
Re: torker 383 vs TM6 vs perf rpm [Re: Chris2581] #1680423
10/03/14 04:16 PM
10/03/14 04:16 PM
Tucson, Az.
RATKLR Offline
RATKLR  Offline
Tucson, Az.
I had the same experience testing the Torker, TM-6, and M1. The ET's and MPH were all so close, you couldn't say which worked better.
Chrysler Power Magazine did a similar test about 20 years ago when they were running a B engine in their Dart. They tested a Weiand single plane also, but it was slower than the Edelbrocks. The TM-6 was the fastest in their application. The kicker though was the TM-6 they used was modified at the plenum. The corners were rounded to blend the upper plenum into the runners.
A couple years ago I took my stock TM-6 and ported the plenum into the runners at the top only. I use a 1" spacer, and with that small amount work the car was over a tenth faster in the 1/4.
I'm sure the Torker would respond the same way with about 2 hours of work. I also think if you modify it before trying it, the car will go faster than with the Performer RPM.
Re: torker 383 vs TM6 vs perf rpm [Re: RATKLR] #1680424
10/03/14 04:19 PM
10/03/14 04:19 PM
Mass.
8
80fbody Offline
80fbody  Offline
Mass.
I thought I just saw a low deck M1 for sale around here or FABO for a good deal.
EDIT: Charger453 has it posted in the race section.
Re: torker 383 vs TM6 vs perf rpm [Re: 80fbody] #1680425
10/03/14 04:48 PM
10/03/14 04:48 PM
K
KOS Offline OP
KOS  Offline OP
K
interesting ive read elsewhere that porting the TM6 was worth quite a bit also but it had been welded up etc...as far as teh M1 i seen it for sale im kinda steering towards an eddy intake right now if i could find one fully ported properly id be laughing.
