Repop/Repaired Dash VIN Tag #1679497
09/28/14 08:23 PM
09/28/14 08:23 PM
Mass
charge70 Offline OP
charge70  Offline OP
Mass
OK,here's my dilemma.My 70 Charger 500,I have the original dash VIN tag.However someone before me removed it from the dash frame and wasn't very nice about it.I've straightened it the best I can,but it still isn't that presentable.The car is being re-done very nice and I will have a tough time putting it on the car.What are my options here,does anyone re-do or repair these tags.I don't want this thread to turn into a slug fest,just helpfull replys.Thanks,John.
1970 Dodge Charger R/T S.E. 1969 Dodge Dart GTS 440 M-Code 1970 Dodge Charger 500 383/4-speed w/A.C.
Re: Repop/Repaired Dash VIN Tag [Re: charge70] #1679498
09/28/14 10:36 PM
09/28/14 10:36 PM
Spokane Washington
ScottSmith_Harms Offline
Mr Wizzard
Mr Wizzard
Spokane Washington
Use it as is
Re: Repop/Repaired Dash VIN Tag [Re: charge70] #1679499
09/28/14 11:06 PM
09/28/14 11:06 PM
CO
Redbird Offline
Redbird  Offline
CO
Of all the things that could be bought as a reproduction item for a Mopar, I would think this would be absolutely the last one anyone would consider.
Having a reproduction VIN tag would seem to be the worst of all worlds. Whatever the shape of the original it would seem to be far less of a bad can of worms than having a reproduction.
Re: Repop/Repaired Dash VIN Tag [Re: Redbird] #1679500
09/28/14 11:10 PM
09/28/14 11:10 PM
West Central Wisconsin
DeMopuar Offline
DeMopuar  Offline
If the tag is tore I would get it back into the proper shape, and use either silver solder to fill holes or whatever body filler you feel comfortable in using -- even JB Weld works well for non stressed areas to get them looking good again.
I would definitely use the original -- just doctor it up.
Good luck!!!!!!!!!!!
Re: Repop/Repaired Dash VIN Tag [Re: charge70] #1679501
09/29/14 02:08 AM
09/29/14 02:08 AM
Mass
DAYCLONA Offline
DAYCLONA  Offline
Mass
Try www.datatags.com they've done VIN tags in the past for individuals, you'll need all your documentations up front, title, registration, possibly a buildsheet and or fender tag to provide absolute proof of the car/ownership/VIN verification
Re: Repop/Repaired Dash VIN Tag [Re: charge70] #1679502
09/30/14 09:28 PM
09/30/14 09:28 PM
Indiana
Jeremy Offline
Jeremy  Offline
Indiana
I would try a Trim repair specialist and have it repaired.
