What's needed for sb 727 w/ 1200 hp turbo motor? #1677910
09/28/14 03:30 AM
09/28/14 03:30 AM
San Angelo, Texas
Cevidicus Offline OP
San Angelo, Texas
How would you build a sb 727 to live behind a 1200 hp turbo g3 hemi street strip car weighing 3700-3900lbs? What kind of converter? Should include a trans brake.
Thanks for you input.
Re: What's needed for sb 727 w/ 1200 hp turbo motor? [Re: Cevidicus] #1677911
09/28/14 11:27 AM
09/28/14 11:27 AM
in front of the computer
8
80arrow Offline
80arrow  Offline
Sorry, I couldn't help myself.
Re: What's needed for sb 727 w/ 1200 hp turbo motor? [Re: 80arrow] #1677912
09/28/14 11:43 AM
09/28/14 11:43 AM
APACHE JUNCTION AZ
Joesixpack Offline
Joesixpack  Offline
APACHE JUNCTION AZ
contact John Cope at CRT...
https://www.coperacingtrans.com/
Re: What's needed for sb 727 w/ 1200 hp turbo motor? [Re: Joesixpack] #1677913
09/28/14 01:02 PM
09/28/14 01:02 PM
Hilltown Pa
1967dartgt Offline
1967dartgt  Offline
Hilltown Pa
I am trying to sell one. Built by pro trans, race prepped case, J&W sb bell, stroud trans blanket, A&A aluminum drums, fully rollerized, trans brake just updated with oring seals, bolt in sprag, moroso aluminum pan lokar locking dip stick. Trans was over 4000.00 from pro trans, just apart ready to go $1750.00. Just went 162mph in my 3200 lb car.
Brett Miller W9 cnc'd heads
STR Chassis fabraction
Re: What's needed for sb 727 w/ 1200 hp turbo motor? [Re: Cevidicus] #1677914
09/28/14 01:14 PM
09/28/14 01:14 PM
Plymouth Meeting, PA
bigtimeauto Offline
Trophy Winner
bigtimeauto  Offline
Trophy Winner
I would build it right into a turbo 400 so i could use a real converter.
BB, TT5,Procharged 3300lb Street Car 4.79/154
Re: What's needed for sb 727 w/ 1200 hp turbo motor? [Re: bigtimeauto] #1677915
09/28/14 01:18 PM
09/28/14 01:18 PM
aZLiViN
J_BODY Offline
J_BODY  Offline
aZLiViN
knew that was coming.... but you can't hardly argue with the "been there.... done that" club.
Re: What's needed for sb 727 w/ 1200 hp turbo motor? [Re: J_BODY] #1677916
09/28/14 02:16 PM
09/28/14 02:16 PM
Taxes & Virus's R-US, NY
Dragula Offline
Dragula  Offline
Was pricing some parts from A&A the other day...They offer some serious upgrades for the 727, although not cheap, but neither is a 1200hp Mopar engine.
I would price that and the T400 and see...
And if your putting the T400 in it, you could also put in a LS engine in it too....
Re: What's needed for sb 727 w/ 1200 hp turbo motor? [Re: J_BODY] #1677917
09/28/14 02:35 PM
09/28/14 02:35 PM
bigtimeauto Offline
Trophy Winner
bigtimeauto  Offline
Trophy Winner
Its real simple math:
How many fast with power adder 727 trans....0
How many fast with power adder GM trans....the rest
hmmm, half do it for the trans and the rest do it for a bigger bell housing to put a better converter in it, better availability to internals, aftermarket cases.......
Re: What's needed for sb 727 w/ 1200 hp turbo motor? [Re: bigtimeauto] #1677918
09/28/14 03:37 PM
09/28/14 03:37 PM
Lynchburg, VA
Leon441 Offline
Leon441  Offline
Lynchburg, VA
Several have been fast with 727. As Bob mentions, the stock bell does not provide room for a real converter. This requires a 1/2" thick miplate and a GM converter shell. There are parts to do this. If you buy a trans to do this figure $7,000. If you are able it can be a lot cheaper.
If you want all Mopar and have the money it can be done.
Or make a call and in a few days install a turbo 400 with Mopar bell.
Re: What's needed for sb 727 w/ 1200 hp turbo motor? [Re: Leon441] #1677919
09/28/14 05:36 PM
09/28/14 05:36 PM
Milwaukee WI
TRENDZ Offline
TRENDZ  Offline
Milwaukee WI
I was doing my own trans up to the point when I started twisting/breaking input/ output shafts. I called A&A, priced all the parts that I needed, and at that point... It was only about a $200 difference to have Rick do the trans for me. I had that trans in the car for 6 years with one failure. I twisted the pinion gear off of the rear end, and the shock load broke the output shaft bearing, snap ring and squashed the input/ output washer. Not the trans' fault.
I ran a spragless converter, A&A brake. The car was 3700 lbs, 3.50 rear gear, 31"W" tires. It 60ft in the mid 1.20s. Car ran 8.80 @155. The car was mostly street driven, and had an aluminum front drum.
The weight and rear gear are hard on the trans. It handled it without complaints.
Re: What's needed for sb 727 w/ 1200 hp turbo motor? [Re: TRENDZ] #1677920
09/28/14 06:02 PM
09/28/14 06:02 PM
Nebraska
72Swinger Offline
72Swinger  Offline
Nebraska
I think a 3.20-3.50 rearend gear would be good with a glide. Seems turbo setups LOVE LOAD.
Mopar to the bone!!!
Re: What's needed for sb 727 w/ 1200 hp turbo motor? [Re: Dragula] #1677921
09/28/14 06:38 PM
09/28/14 06:38 PM
North Central, Indiana
Roughbird72 Offline
Roughbird72  Offline
Ouch !!!
In all honesty the 727 wasn't really designed to handle that much HP/Torque, which is why a few use the Rossler TH400.
72 Plymouth Roadrunner 11.08@123.25
Re: What's needed for sb 727 w/ 1200 hp turbo motor? [Re: Dragula] #1677922
09/28/14 10:07 PM
09/28/14 10:07 PM
Canada
WO23Coronet Offline
WO23Coronet  Offline
Canada
Yah, a 2000 HP junkyard 4.8 with Chinese turbos
Re: What's needed for sb 727 w/ 1200 hp turbo motor? [Re: TRENDZ] #1677923
09/28/14 10:31 PM
09/28/14 10:31 PM
State College, Pennsylvania
fatman Offline
fatman  Offline
Hey TRENDZ, Who's converter ? My 4060lbs car is slower after adding 80 ft/lbs 120 hp. and two attempts at tightening a PTC 9.5"
Re: What's needed for sb 727 w/ 1200 hp turbo motor? [Re: Cevidicus] #1677924
09/29/14 01:23 AM
09/29/14 01:23 AM
MI, usa
dvw Offline
dvw  Offline
MI, usa
Talk to some guys that run that much power, especially on radials. None of them will recommend very much starting line ratio. A 2 speed will work well at your power level. Even a 3.55 with a 2.45 1st gear will be WAY to much.
Doug
Re: What's needed for sb 727 w/ 1200 hp turbo motor? [Re: dvw] #1677925
09/29/14 01:46 AM
09/29/14 01:46 AM
AB
E
Efidart Offline
Efidart  Offline
E
AB
Had a 727 when I was running 8.3's at 3600 lbs, wouldn't hold on the brake spooling when I tried to launch under lots of boost and was on borrowed time at that hp level. Sold it before it came apart while it was still worth money and went to an extreme automatics TH400.
Best money ever spent.
TT Predator headed 572 7 Second Street Car.
Fastest Mopar Drag Week 2015
Fastest Mopar & Dodge Drag Week 2017
Pro Street Power Adder Champion Drag Week 2017
Re: What's needed for sb 727 w/ 1200 hp turbo motor? [Re: Efidart] #1677926
09/29/14 08:59 PM
09/29/14 08:59 PM
geezer acres rest home
dakotawilly Offline
dakotawilly  Offline
Go lenco go fast
thumb:
SFI 25.5 depends,no leak,even at 213 mph....
Re: What's needed for sb 727 w/ 1200 hp turbo motor? [Re: fatman] #1677927
09/29/14 11:00 PM
09/29/14 11:00 PM
Milwaukee WI
TRENDZ Offline
TRENDZ  Offline
Milwaukee WI
My converter was done by Frank Lupo at Dynamic. It had a custom stator and "mechanical diode" instead of a sprag. It worked great for me, but my car had a pretty unique staging/ engine control strategy that was easy on both the engine and trans while on the brake. I wanted to try a tighter converter, so I ordered a PTC. It was in the car for a day. It did not work well for me. It felt like I could drive right through it if I wanted to. I put the dynamic back in and never tried anything else. but don't let me talk you out of the TH400 like EFI DART was talking about. He's got his act together, and has for quite awhile.
Re: What's needed for sb 727 w/ 1200 hp turbo motor? [Re: TRENDZ] #1677928
09/30/14 12:15 AM
09/30/14 12:15 AM
North Alabama
Monte_Smith Offline
Monte_Smith  Offline
North Alabama
As already mentioned, the 727 is likely a poor choice for this combo. The 400 would be much better AND cheaper
Monte
Re: What's needed for sb 727 w/ 1200 hp turbo motor? [Re: Monte_Smith] #1677929
09/30/14 12:59 AM
09/30/14 12:59 AM
San Angelo, Texas
San Angelo, Texas
Ok. So what's needed to make a t400 work? Trans tunnel mods? Cross member fab?
Thanks for all the input thusfar.
