Re: Dakota cruise control problem
[Re: bobby66]
#1677691
09/27/14 05:15 PM
09/27/14 05:15 PM
Posts: 20,679 in a cattle trailer down by th...
Guitar Jones
Does the speedo change when it does that?
[Re: stumpy]
#1677693
09/27/14 08:35 PM
09/27/14 08:35 PM
Posts: 3,824 Arlington, Texas
bobby66
Arlington, Texas
Have you tried holding that speed steadily without the cruise on to make sure that it is a cruise problem and not a trans shifting in and out of od or lock up?
If I just hold a steady speed with my right foot there is no problem. Only on the cruise. Speedo needle not jumping when it happens. ![](/ubbthreads/images/graemlins/Twocents.gif)
[Re: stumpy]
#1677697
10/03/14 05:05 PM
10/03/14 05:05 PM
Posts: 12,424 Kalispell Mt.
HotRodDave
Kalispell Mt.
Thats why I was graphing it on the scanner, seemed to have a nice clean reading with no blips or dips.
[Re: stumpy]
#1677698
10/04/14 01:08 AM
10/04/14 01:08 AM
bobby66
Arlington, Texas
Could the speed sensor be dirty?
Where is it located? I mostly work on printing presses. ![](/ubbthreads/images/graemlins/runaway.gif)
