Re: Dakota cruise control problem
[Re: bobby66]
#1677691
09/27/14 05:15 PM
09/27/14 05:15 PM
Guitar Jones
Does the speedo change when it does that?
'92 D250 Club Cab CTD, 47RH conversion, pump tweaks, injectors, rear disc and hydroboost conversion. '74 W200 Crew Cab 360, NV4500, D44, D60 and NP205 divorced transfer case. Rear disc and hydroboost coming soon! 2019 1500 Long Horn Crew Cab 4WD, 5.7 Hemi.
[Re: stumpy]
#1677693
09/27/14 08:35 PM
09/27/14 08:35 PM
Posts: 3,805 Arlington, Texas
bobby66
Arlington, Texas
Have you tried holding that speed steadily without the cruise on to make sure that it is a cruise problem and not a trans shifting in and out of od or lock up?
If I just hold a steady speed with my right foot there is no problem. Only on the cruise. Speedo needle not jumping when it happens.
[Re: stumpy]
#1677697
10/03/14 05:05 PM
10/03/14 05:05 PM
Posts: 12,419 Kalispell Mt.
HotRodDave
Kalispell Mt.
Thats why I was graphing it on the scanner, seemed to have a nice clean reading with no blips or dips.
[Re: stumpy]
#1677698
10/04/14 01:08 AM
10/04/14 01:08 AM
bobby66
Arlington, Texas
Could the speed sensor be dirty?
Where is it located? I mostly work on printing presses.
