dana 60 axel tubes. where to get? #1677107
09/26/14 05:30 AM
09/26/14 05:30 AM
poplar bluff mo.
toplescuda Offline OP
I Whine
I Whine
poplar bluff mo.
May have a chance to get a dana 60 center section the tubes have been cut pretty short. Where would a person get tubes to replace( what is the best thickness to have car ends welded on?
1970 barracuda convert. 1 of 59
1970 pro street A.A.R. clone (panther pink)
1971 charger
2015 hellcat challenger. Redline red
2014 quad cab 4x4 ram 8 speed hemi
Re: dana 60 axel tubes. where to get? [Re: toplescuda] #1677108
09/26/14 05:51 AM
09/26/14 05:51 AM
Menomonee Falls
DemonDust Offline
DemonDust  Offline
Menomonee Falls
I just bought 1/4" DOM when I did mine, it turned out really nice.
SDG Motorsports
Hellcat Demon and Redeye Supercharger CNC Porting
https://www.sdgmotorsports.com/
Re: dana 60 axel tubes. where to get? [Re: toplescuda] #1677109
09/26/14 06:58 AM
09/26/14 06:58 AM
Rudolph, Ohio
moparguy7074 Offline
Rudolph, Ohio
Dr. Diff?
Re: dana 60 axel tubes. where to get? [Re: moparguy7074] #1677110
09/26/14 11:15 AM
09/26/14 11:15 AM
Ontario, Canada
Stanton Offline
Don't question me!
Stanton  Offline
Don't question me!
Ontario, Canada
Any good steel supply place should have DOM tubing.
Re: dana 60 axle tubes. where to get? [Re: Stanton] #1677111
09/26/14 03:10 PM
09/26/14 03:10 PM
Winston-Salem, NC
JackZ Offline
JackZ  Offline
Winston-Salem, NC
You may know this already, but depending upon what the Dana 60 housing that you have was originally made for, it may have 3" OD tubes or 3 1/8" OD tubes so you need to determine that before ordering the tubing. In either case, the tube ends will need to be machined down slightly in order to have the proper press fit into the housing.
Re: dana 60 axel tubes. where to get? [Re: toplescuda] #1677112
09/26/14 03:36 PM
09/26/14 03:36 PM
Central California
MoParFish Offline
MoParFish  Offline
Central California
I used a truck center. I torched the plug welds and pulled the tubes out of the center section then welded up and machined down new 3 inch tubes to press back into the center section. Used silicone sealer when pressing then welded plugs back in and welded tubes to center section for good measure.
My buddy has used onlinemetals.com for different pieces. May be able to find cheaper locally? Here is a link. http://www.onlinemetals.com/merchant.cfm...amp;top_cat=197
Sworn Member Central Valley MoPar Drag Pack. You can reach me at (done-et-chasing@going-rounds.gone)... :-)
[img]https://s6.postimg.org/v3mbggksx/SAC16.jpg[/img]image hosting more than 5mb
Re: dana 60 axel tubes. where to get? [Re: MoParFish] #1677113
09/26/14 03:57 PM
09/26/14 03:57 PM
Overpriced Housing Central
RobX4406 Offline
RobX4406  Offline
I use this place for materials on occasion.
http://www.speedymetals.com/pc-3561-8242-3-od-x-250-wall-dom-steel-tube.aspx
You should be able to get by with about 3 feet of tube if making it into a 68-70 B body housing.
Re: dana 60 axel tubes. where to get? [Re: RobX4406] #1677114
09/26/14 04:05 PM
09/26/14 04:05 PM
Eighty Four, PA
B G Racing Offline
B G Racing  Offline
Eighty Four, PA
Have tubing in stock,we use 3/8 DOM/CM replacement tube.
Re: dana 60 axel tubes. where to get? [Re: B G Racing] #1677115
09/26/14 06:27 PM
09/26/14 06:27 PM
poplar bluff mo.
I Whine
I Whine
poplar bluff mo.
Well I havent bought the center section yet
the not having holes for snubber dont bother me
It has a 4.10 gear. Open diff. But can put a locker or spool in later
What is dom? A d what would 3 foot(or how ever much is needed) cost
I have a buddy that has a jig for narrowing housings. So I know will be true when all welded up
1971 charger
Re: dana 60 axel tubes. where to get? [Re: toplescuda] #1677116
09/26/14 08:05 PM
09/26/14 08:05 PM
Eighty Four, PA
B G Racing Offline
B G Racing  Offline
Eighty Four, PA
Drawn on a mandrel as opposed welded seam or extruded.The best grade of tubing is DOM.The stuff we have is $25 per foot.If you find someone to pick it up I can donate what you need at no charge.Shipping cost would be astronomical.
Re: dana 60 axel tubes. where to get? [Re: B G Racing] #1677117
09/26/14 08:29 PM
09/26/14 08:29 PM
Oakland, MI
dizuster Offline
dizuster  Offline
Oakland, MI
I don't know what you'd need to pay for it, but but my buddy just bought a truck axle with a 4.10 in it off craigslist for $80. So they are out there. Might be easier to cut a wide truck axle, then add tubes to just a housing.
DVW (my Dad) and I did the same thing with the Dana that's in my turbo car. Used gear/bearings, slapped a Dr. Diff spool in it with a new yoke an Dr. Diff axles. $80 Strange Ford ends for explorer brakes, and away we went.
I only have about $600 into the whole thing (not including brakes because I already had them.)
Re: dana 60 axle tubes. where to get? [Re: JackZ] #1677118
09/26/14 08:41 PM
09/26/14 08:41 PM
fredericksburg,va
cudaman1969 Online sleepy
cudaman1969  Online Sleepy
fredericksburg,va
Look at the truck rear again, the tubes are machined to fit at 3 inches, in other words all housings are same size. Us 1/4 dom or 3/16 moly.
Re: dana 60 axle tubes. where to get? [Re: cudaman1969] #1677119
09/26/14 09:07 PM
09/26/14 09:07 PM
poplar bluff mo.
I Whine
I Whine
poplar bluff mo.
He was wanting 95 for the center
1971 charger
Re: dana 60 axel tubes. where to get? [Re: B G Racing] #1677120
09/26/14 09:11 PM
09/26/14 09:11 PM
poplar bluff mo.
I Whine
I Whine
poplar bluff mo.
Bob your a stand up guy. You go out of your way to help. Not many people do that
1971 charger
Re: dana 60 axle tubes. where to get? [Re: toplescuda] #1677121
09/27/14 02:49 AM
09/27/14 02:49 AM
A Red State
SNK-EYZ Offline
SNK-EYZ  Offline
A Red State
That's no deal at all.
You can buy a complete truck Dana 60 from Clay for about $125.
Then you only need to cut the axles tubes to the length you need them at to weld the new ends on.
Re: dana 60 axle tubes. where to get? [Re: SNK-EYZ] #1677122
09/27/14 03:44 AM
09/27/14 03:44 AM
Central Ohio, USA
Bigbeep Offline
Bigbeep  Offline
Central Ohio, USA
I just bought a dana Thursday evening. It was narrowed for a Vega in the past and is pretty narrow. It is a car housing and has a strange spool in it. I was thinking of re-tubing it also. Kind of neat seeing this thread the very next day. Beep
Re: dana 60 axle tubes. where to get? [Re: SNK-EYZ] #1677123
09/27/14 08:27 AM
09/27/14 08:27 AM
poplar bluff mo.
I Whine
I Whine
poplar bluff mo.
Il have to check with clay
I know he gets 250 for 8 3/4 with no center.
Hes bout 100 miles from me so have to factor in his price in that also
Did find a guy here in town (not my buddy) that also narrows rearends on jig. Said 250 to cut down and weld on my supply ed ends. Dont know if thats a good deal or not
1971 charger
Re: dana 60 axle tubes. where to get? [Re: toplescuda] #1677124
09/27/14 08:55 AM
09/27/14 08:55 AM
Eighty Four, PA
B G Racing Offline
B G Racing  Offline
Eighty Four, PA
Ralph,let me know if you need new billet ends,we have them also.We have quite a few complete shortened Danas,what length do you need?
Re: dana 60 axle tubes. where to get? [Re: B G Racing] #1677125
09/27/14 11:08 PM
09/27/14 11:08 PM
A Red State
SNK-EYZ Offline
SNK-EYZ  Offline
A Red State
There are a couple truck Dana 60's on c/l near you.
$100 http://jonesboro.craigslist.org/pts/4669077488.html
$100 Poplar Bluff http://semo.craigslist.org/pts/4641564225.html
$200 Poplar Bluff http://semo.craigslist.org/pts/4661746222.html
$150 High Ridge MO http://stlouis.craigslist.org/pts/4665539046.html
I've got one of the Jeep Dana 60 housings with the 2.75 axle tubs that you can have for free.
The smaller axle tubes makes the harder to deal with for narrowing.
That's why I never used it (so far).
Re: dana 60 axle tubes. where to get? [Re: SNK-EYZ] #1677126
09/28/14 08:27 AM
09/28/14 08:27 AM
poplar bluff mo.
I Whine
I Whine
poplar bluff mo.
Thanks. Yeah the one in jonesboro I been trying on. The one for 100 bucks here in bouff is actually a 70 as iv looked at it in person.
I told him what it was but he felt would easier to get rid of if listed as a 60
1971 charger
