Positive Ground? #167684
12/14/08 09:43 PM
12/14/08 09:43 PM
Anonymous OP
Anonymous OP
I did a search but didn't find anything that answered the following question:
What years, if any, did D/D/C/P vehicles have electrical systems with a positive ground?
Thanks in advance for the help, guys. (I have a 12 pack wager with a buddy!)
~Matt
Re: Positive Ground? #167685
12/14/08 09:46 PM
12/14/08 09:46 PM
Omaha, Nebraska
Scott Carl Offline
Scott Carl  Offline
Omaha, Nebraska
Without researching I'm guessing, but I don't believe any Mopar or other American made car had positive ground. Thinking it was strictly European.
Edit: Uh oh, I googled. I may be wrong
Re: Positive Ground? [Re: Scott Carl] #167686
12/14/08 09:50 PM
12/14/08 09:50 PM
Texas
GoodysGotaCuda Offline
5.7L Hemi, 6spd
5.7L Hemi, 6spd
Texas
believe old old Fords did
1972 Barracuda - 5.7L Hemi, T56 Magnum 6spd - https://www.facebook.com/GoodysGotaHemi
2020 RAM 1500
[img]https://i.imgur.com/v9yezP9.jpg[/img]
Re: Positive Ground? [Re: GoodysGotaCuda] #167687
12/14/08 09:52 PM
12/14/08 09:52 PM
up yours
Supercuda Offline
About to go away
Supercuda  Offline
About to go away
up yours
Too bad he didn't ask about Frods.
When Chrysler had 6V crs they were all positive gtound.
I believe, not 100% sure though, that the switch to negative ground happened in coincidence with the switch to 12V.
Don't be the exception.
Re: Positive Ground? [Re: GoodysGotaCuda] #167688
12/14/08 09:56 PM
12/14/08 09:56 PM
Upper Midwest
MoparforLife Offline
Upper Midwest
1956 was the turning point for Ford to neg. ground. 1955 & down pos ground.
Clean it, if it's Dirty. Oil it, if it Squeaks. But: Don't fix it, if it Works!
Re: Positive Ground? [Re: MoparforLife] #167689
12/14/08 09:59 PM
12/14/08 09:59 PM
Anonymous OP
Anonymous OP
Hey Guys,
Thanks a LOT for the quick replies.
(my buddy owes ME a 12 pack!)
Re: Positive Ground? [Re: Scott Carl] #167690
12/14/08 10:04 PM
12/14/08 10:04 PM
lewiston, ID
cornucopia Offline
cornucopia  Offline
lewiston, ID
international trucks in 1951/52 had a positive ground with, as I recal, a 6 or 9 volt system. we had one as a trash truck when I worked in the small engine shop back in the 80s...we would junp it with a 12 volt battery and man would it turn over QUICK!
the 1967 'White' backhoe we had at my previous cemetery was a positive ground also...
Re: Positive Ground? #167691
12/15/08 12:01 AM
12/15/08 12:01 AM
Mansfield, TEXAS
JOES4FORTY Offline
JOES4FORTY  Offline
Mansfield, TEXAS
Those old American LaFrance Fire Engines had positive ground on them. Dangerous to jump start and charge with a charger if you didn't know that.
The GTS Registry!
MOPARTS MEMBER IN PRINT
1969 Dart GTS LS23P9B (First day of production car money pit)
Re: Positive Ground? [Re: JOES4FORTY] #167692
12/15/08 12:59 AM
12/15/08 12:59 AM
Not2farfromNashville, TN
Rug_Trucker Offline
Rug_Trucker  Offline
Cars from Oz! Them and their unslanted six!
"The only thing to do for triumph of evil is for good men to do nothing"
"NUNQUAM NON PARATUS!"
Re: Positive Ground? #167693
12/15/08 01:14 AM
12/15/08 01:14 AM
Coram, NY
Pool Fixer Offline
Pool Fixer  Offline
Coram, NY
My dad's 51 hudson hornet is pos ground too.
Re: Positive Ground? [Re: Pool Fixer] #167694
12/15/08 01:34 AM
12/15/08 01:34 AM
Anonymous OP
Anonymous OP
Many old 6V cars were pos. ground. Back when "we" used generators, many regulators were sold as pos or neg. ground. The only real difference in regulators is the contact structure--to prevent arcing. Some replacement aftermarket regulators had contacts that could be used either way
When you replaced a generator, you "flashed" it to magnitise it correctly for whatever polarity. I believe some weird trucks (dunnooo, White?) were 12V pos ground. In the two-way radio market, some older radios were built for either pos. or neg, and you can still buy a pos to neg inverter/ converter.
It's too darn bad that when the car makers went 12, they didn't keep going to at least 24V. Smaller wire--less amperage--solves a LOT of wiring / voltage drop problems.
Many log trucks/ highway tractors used to use a 12/24V solenoid--24V for startup. They are a wiring nightmare.
Re: Positive Ground? #167695
12/15/08 02:11 AM
12/15/08 02:11 AM
Marysville, O-H-I-O
70Cuda383 Offline
70Cuda383  Offline
Marysville, O-H-I-O
just about every 6V car I've seen used a positive ground.
I also have personal experience that Packard used a 12V positive ground from somewhere in the early 50s to 1955. they made the switch to negative ground in 1956.
I had to be VERY AWARE of what I was doing, when hooking the battery charger up from car to car, when you have 1955 Packard carribean convertible sitting next to a 1956 Packard carribean convertible, and they look damn near identical!
**Photobucket sucks**
Re: Positive Ground? #167696
12/15/08 02:28 PM
12/15/08 02:28 PM
Southern, Ca.
69DartGT Offline
moparts member
69DartGT  Offline
moparts member
Southern, Ca.
I have an old Motor's Manual and it show's 53-56 as postive grounds. BTW they were 6 volt..
