Holley adjustments issues #1676653
09/25/14 01:11 AM
09/25/14 01:11 AM
Watertown, WI
MikeyT Offline OP
MikeyT  Offline OP
Watertown, WI
Hi all,
I am putting a 750 double pumper on my 440 and I am having issues. I have a large amount of gas squirting out the top of the carb.. I swear it is squirting out of the float adjustment bolt on top, floats are good and just a trickle out of the sight holes so I think floats are adjusted right...
Am I missing something ?Do you have to really crank on those top bolts to stop it leaking, I don't want to do damage
Thanks in advance.
Mikey
1969 Dodge Dart Swinger
Re: Holley adjustments issues [Re: MikeyT] #1676654
09/25/14 01:16 AM
09/25/14 01:16 AM
there's a thin gasket on either side of the hex nut (1 gasket on the bottom between hex nut and carb body/1 gasket on top between hex nut and the lock screw)
Re: Holley adjustments issues [Re: RapidRobert] #1676655
09/25/14 01:19 AM
09/25/14 01:19 AM
Watertown, WI
MikeyT Offline OP
MikeyT  Offline OP
Watertown, WI
Thanks Robert,
Do they dry out or go bad?
Mikey
Re: Holley adjustments issues [Re: MikeyT] #1676656
09/25/14 01:28 AM
09/25/14 01:28 AM
I think they deteriorate over time like happens to other gaskets on occaision plus on these adjusting the float level is gonna disturb em will which will add up over time
Re: Holley adjustments issues [Re: RapidRobert] #1676657
09/25/14 01:35 AM
09/25/14 01:35 AM
Watertown, WI
MikeyT Offline OP
MikeyT  Offline OP
Watertown, WI
Ok cool,,,well this is going to be fun to hunt down!
Mikey
Re: Holley adjustments issues [Re: MikeyT] #1676658
09/25/14 02:05 AM
09/25/14 02:05 AM
Oregon City, OR
Baxter61 Offline
Baxter61  Offline
Oregon City, OR
Want some nylon ones? PM me your address and I'll mail you some to try
Re: Holley adjustments issues [Re: Baxter61] #1676659
09/25/14 02:56 AM
09/25/14 02:56 AM
Watertown, WI
MikeyT Offline OP
MikeyT  Offline OP
Watertown, WI
Thank you, Baxter61 I appreciate that!!
Re: Holley adjustments issues [Re: MikeyT] #1676660
09/25/14 07:51 AM
09/25/14 07:51 AM
MICHIGAN
BB65Barracuda Offline
MICHIGAN
Have you ever removed the float bowls?
I had a holly 750 that I bought used and had the same problem. It turned out the plating on the inside of the carb was peeling off the inside of the carb, I think the term holly used was diechrome plating?
Anyways I contacted holly and even though the carb was 20yrs old they sent me a Brand new carb, no charge.
It would pay to pull the bowls if you haven't and check it out.
1957 Power wagon wm300 original 10.000 mile truck, 1964 dodge Polara Convertible numbers matching
Re: Holley adjustments issues [Re: BB65Barracuda] #1676661
09/25/14 08:49 AM
09/25/14 08:49 AM
scratchnfotraction Offline
make sure the o-ring on the needle/seat is not out of its bore. to high/to low can let fuel past o-ring and blow out adjusting screw/nut.
you get the new felt/paper washers in a rebuild kit or upgrade to the nylon washers.
I had a bowl gasket split/cut/break and leak fuel on the top side of bowl.
when was the last time it got a fresh kit in it?
50 bux well spent. I found my PV blown/transfer tube O-rings flat.
and new gaskets sealed the leaks up. no wonder it was pig rich at idle.
if you use the felt/paper gasket it helps to coat them with vasline to keep them soft/non-stick. helps the O-rings seal/slide in the bore with out sticking over time.
Re: Holley adjustments issues [Re: scratchnfotraction] #1676662
09/25/14 12:18 PM
09/25/14 12:18 PM
X2 what Scratchn said: lube the O rings on the needle/seat assy before install & in fact I suspect that is where your leak is coming from rather than the 2 flat gaskets on the hex nut
Re: Holley adjustments issues [Re: RapidRobert] #1676663
09/25/14 02:53 PM
09/25/14 02:53 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
Along with the other things mentioned, if a gorilla tightens the slotted screw on top of the hex adjuster the threads in the bowl can be stripped out.
Re: Holley adjustments issues [Re: John_Kunkel] #1676664
09/25/14 03:32 PM
09/25/14 03:32 PM
Western Md.
skicker Offline
"The Champ"
skicker  Offline
"The Champ"
Western Md.
Just an FYI its real easy to do. I swear the hard nylon gaskets make it a little worse. They seem to need tightened more than the ones made from gasket material.
...FAFO...
