Steering box,, 69 B Body #1676290
09/23/14 09:40 PM
09/23/14 09:40 PM
WV
JohnH Offline OP
JohnH  Offline OP
WV
On a 69 Charger there is no road feel when driving the car. Can you put a later steering box on the car to get a resistance feel of driving? Or any thing else can I do?
Re: Steering box,, 69 B Body [Re: JohnH] #1676291
09/23/14 10:04 PM
09/23/14 10:04 PM
s.w.fl
bonefish Offline
bonefish  Offline
s.w.fl
mabey a close ratio box,i think firm feel makes a 16:1.or try some stiffer shocks.
Re: Steering box,, 69 B Body [Re: JohnH] #1676292
09/23/14 11:33 PM
09/23/14 11:33 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
If you put on a later box, depending on your definition of FEEL it may not be any different, but you'll need to get a pitmarm for a 73 B body as the output of the 73 and later box is larger.
Re: Steering box,, 69 B Body [Re: JohnRR] #1676293
09/24/14 01:09 AM
09/24/14 01:09 AM
Farmland, IN
Ludington1 Offline
Ludington1  Offline
Farmland, IN
I have a Firm Feel Stage 2 in my 69 R/T and like it a lot.
Re: Steering box,, 69 B Body [Re: Ludington1] #1676294
09/24/14 05:14 PM
09/24/14 05:14 PM
Seattle, WA
3
375inStroke Offline
Special needs person
375inStroke  Offline
3
Seattle, WA
I find these cars impossible to drive with stock wheel alignment specs. I add more caster, and some negative camber, and road feel returns, along with the steering wheel wanting to return to center.
Re: Steering box,, 69 B Body [Re: 375inStroke] #1676295
09/24/14 06:16 PM
09/24/14 06:16 PM
Calgary, Alberta Canada
a12rag Offline
a12rag  Offline
Used Firm Feel Stage 3 box in my 70 Sport Satellite, along with thier tubular upper control arms. Feels more like a rack & pinion steering system . . . Upper control arms help with more alignment spec movement room . . .
Cheers
Mark
