Odd Cuda rear valance? #1676186
09/23/14 05:30 PM
09/23/14 05:30 PM
St.Louis, MO
694406 Offline OP
694406  Offline OP
St.Louis, MO
I've had this piece in my rafters for years. It's a Cuda but with round cut outs. Can anyone shed some light on this?
Thanks!
www.Musclemagnet.com
1969 Cuda 383 Q5
1969 Cuda 340 4-spd Notch
1969 Cuda 383 4-spd Notch
1969 GTS Black on White 340 4-spd
1971 Cuda 383 V2, X9 Billboards, White Top!
Re: Odd Cuda rear valance? [Re: 694406] #1676187
09/23/14 05:38 PM
09/23/14 05:38 PM
So Cal
autoxcuda Online content
autoxcuda  Online Content
So Cal
Dual exhaust car without tip. Turn downs.
For mandatory noise reduction cars in California (440-6, Hemi, other?). Maybe other areas required that too? Also a 383 N code 70/71 Barracuda would get that too. No tip options on those cars I believe.
Maybe 340 72-74 Barracuda (non 'Cuda) got turn downs too? Not familiar with those cars.
Re: Odd Cuda rear valance? [Re: autoxcuda] #1676188
09/23/14 05:44 PM
09/23/14 05:44 PM
Cambridge, Ontario, Canada
CUDAJAS Offline
CUDAJAS  Offline
I have that on my 74.
Original single exhaust car I believe.
Also AAR cuda's had those rear valances. Not really all that odd.
Jason
Re: Odd Cuda rear valance? [Re: CUDAJAS] #1676189
09/23/14 06:01 PM
09/23/14 06:01 PM
So Cal
So Cal
Depth of the cutouts seem to be different on repros?
Do the cutouts look more shallow installed on a car?
Re: Odd Cuda rear valance? [Re: CUDAJAS] #1676190
09/23/14 06:08 PM
09/23/14 06:08 PM
St.Louis, MO
694406 Offline OP
694406  Offline OP
St.Louis, MO
Jason
AARs had solid valances with no cutouts.
1969 Cuda 383 Q5
Re: Odd Cuda rear valance? [Re: autoxcuda] #1676191
09/23/14 06:50 PM
09/23/14 06:50 PM
St. Louis, Mo
3
318 Stroker Offline
318 Stroker  Offline
St. Louis, Mo
I'd say more than the depth is different. The entire profile of the bottom edge seems to be way off.
Re: Odd Cuda rear valance? [Re: 694406] #1676192
09/23/14 07:27 PM
09/23/14 07:27 PM
mopar346 Offline
Let me tell ya about fat chicks!
mopar346  Offline
Jason
My original had slight cut outs and from what I have researched that was normal. Batalson sold me an NOS one that he said to be correct for the AAR and it has the same slight cut outs. I'll see if I can find a picture from back int he day.
Careful, your character's showing!
Re: Odd Cuda rear valance? [Re: mopar346] #1676193
09/23/14 07:52 PM
09/23/14 07:52 PM
So Cal
So Cal
Jason
That's what's confusing. Why have slight dual cutouts and then deep dual cutouts?
It would seem to make more sense to have just one passenger side small cutout for single exhaust. Unless it was just done for visual balance. But one side would have a tail pipe and the other side not.
Re: Odd Cuda rear valance? [Re: autoxcuda] #1676194
09/23/14 08:00 PM
09/23/14 08:00 PM
Western Colorado High Desert
moparmarks Offline
moparmarks  Offline
70/1 N code cars can have the tips along with 340 cars but not on Calf. cars.
Desert Mopar Metal
Grand Jct. CO
970-261-7039
http://moparmark.com/
motormangj@gmail.com
Re: Odd Cuda rear valance? [Re: moparmarks] #1676195
09/23/14 08:11 PM
09/23/14 08:11 PM
So Cal
So Cal
But what about NON 'Cuda models. I'm talking flat hooded Barracuda and Gran Coupes could get the 330 horsepower (blue painted) low performance 4 barrel with automatic. Seems like 4speeds got the orange 335hp motor.
Actually I think 383 and 340 'Cudas did have tips in California. Maybe someone could varify. I've seen a lot of original cars out here that did have tips. It's the larger Hemi, 440-6v, and 44-4v cars that needed the noise reduction package (U,V,R codes).
6bblgt did a whole spread sheet on this topic for 70 cars. It's pretty complicated deal.
71 Challenger 383 R/T did have tips in California. I own one and it had original tips and hangers. I assume 71 'Cudas were the same
I know of a California 71 N Code 383 HiPo orange motor Challenger (non R/T) with no tips. I don't know if they were and option in 71. Or they might come standard with 340 JH (non R/T) cars standard like they did in 70 Challenger 340 A66 cars??
70-71 'Cuda were the only way to get tips through the valence. The 340 motor was not offered in non 'Cuda models in 70/71. But there are reported 70 Barracuda 340's out there.
Very confusing subject.
Re: Odd Cuda rear valance? [Re: mopar346] #1676196
09/23/14 08:42 PM
09/23/14 08:42 PM
mopar346 Offline
mopar346  Offline
You can see them here if you look close. It actually had regular duals on it in the 80s.
Re: Odd Cuda rear valance? [Re: mopar346] #1676197
09/23/14 09:12 PM
09/23/14 09:12 PM
moparmarks Offline
moparmarks  Offline
Sorry Steve I was thinking Cuda and didn't catch that you were talking about Barracudas.
Desert Mopar Metal
Grand Jct. CO
970-261-7039
Re: Odd Cuda rear valance? [Re: 694406] #1676198
09/23/14 09:15 PM
09/23/14 09:15 PM
South, FL
cudaized Offline
cudaized  Offline
South, FL
Thanks!
That is a 1970 version of the non Chrome Exhaust tip rear valance. The lower edge gives it away in pictures. Holding it in your hand gives it away. It is heavier then the 71-74 version.
If you turn if over and look at the rear side. You will not see the two vertical braces, as are found in 71-74 and the reproduction version.
Re: Odd Cuda rear valance? [Re: autoxcuda] #1676199
09/23/14 09:19 PM
09/23/14 09:19 PM
South, FL
cudaized Offline
cudaized  Offline
South, FL
The BS23 models got the N41 and the N42 Chrome Exhaust Tips, even in CA.
The exception were the hemi and 440-6 cars. The noise package only applied to the R and V codes sold and registered new in CA.
Re: Odd Cuda rear valance? [Re: cudaized] #1676200
09/23/14 09:25 PM
09/23/14 09:25 PM
poplar bluff mo.
toplescuda Offline
I Whine
toplescuda  Offline
I Whine
poplar bluff mo.
My 70 383 2bbl barracuda has that valance. It didnt come with chrome tips and is a single exhaust car
1970 barracuda convert. 1 of 59
1970 pro street A.A.R. clone (panther pink)
1971 charger
2015 hellcat challenger. Redline red
2014 quad cab 4x4 ram 8 speed hemi
Re: Odd Cuda rear valance? [Re: cudaized] #1676201
09/23/14 09:29 PM
09/23/14 09:29 PM
South, FL
cudaized Offline
cudaized  Offline
South, FL
70 vs 71 Non-N42 Chrome Exhaust Tips rear valances.
The depth looks deeper in the 1970 valance. However, it is the same height. Reference the recess area for the lower mounting screw hole. The top of the round exhaust cutout are the same height.
Take a look at the bottom of the 71 valance. The bottom has been modified (by the factory) for the 71-74 models.
Apparently, in 1970, there was something about the rear leaf springs hitting/bending the bottom of the 1970 valance. So the factory modified it. Kind of like the hemi fenders...make it work.
1970 `cuda340 convertible 4-speed Rallye Red with Red interior
cudaized.com
1970-71 Plymouth and Dodge E-Body Convertible Registry
ebodyconvertibleregistry.com
Re: Odd Cuda rear valance? [Re: cudaized] #1676202
09/23/14 10:31 PM
09/23/14 10:31 PM
So Cal
So Cal
Ok. So U code single 4 bbl cars did not have to have noise reduction (no tips)?
Read in another thread U code was also no tips.
Re: Odd Cuda rear valance? [Re: cudaized] #1676203
09/23/14 10:33 PM
09/23/14 10:33 PM
St.Louis, MO
694406 Offline OP
694406  Offline OP
St.Louis, MO
Awesome info and thanks!
1969 Cuda 383 Q5
Re: Odd Cuda rear valance? [Re: 694406] #1676204
09/23/14 10:42 PM
09/23/14 10:42 PM
So Cal
So Cal
Thank you. I never knew there were two different valences.
I see AAR's with shallow ones, but are those just replacements?
Re: Odd Cuda rear valance? [Re: autoxcuda] #1676205
09/23/14 10:48 PM
09/23/14 10:48 PM
South, FL
cudaized Offline
cudaized  Offline
South, FL
No Sir. They were not required to. Did it happen? Possibly.
