Re: What to use in an 833 aside from ATF?
[Re: AlexP]
#1675665
09/22/14 02:36 PM
09/22/14 02:36 PM
Posts: 5,162 CT
GTX MATT
CT
Make sure you get GL4, not a GL5. Many GL5s will say it exceeds GL4, but many will be harsh on synchros. Brad Penn makes a GL4 in 80W90 that is reasonably priced on Amazon.
I wouldn't run ATF in one fwiw. Yes the FSM says you can do it, if you live in EXTREME cold, and it says to get rid of it once temps rise.
[Re: AlexP]
#1675666
09/22/14 03:33 PM
09/22/14 03:33 PM
Posts: 25,812 Rio Linda, CA
John_Kunkel
Rio Linda, CA
The 833 loves synthetic fluid, my personal choice is Redline 75/90 NS.
[Re: John_Kunkel]
#1675667
09/22/14 04:06 PM
09/22/14 04:06 PM
Posts: 10,645 Houston, Tx
AlexP
Houston, Tx
I was hoping for that. I'd really like to use Amsoil.
[Re: fourgearsavoy]
#1675674
09/23/14 10:10 AM
09/23/14 10:10 AM
Posts: 2,415 Connecticut
Ron_M
Connecticut
Plenty of past threads on this topic.
I use Passon Performance Gear lube. (570-401-8949) Just stocked up and 5QTs was around $60.00 shipped to my door.
I tried the Synchromesh and did not like it.
Common sense is a flower that does not grow in everybody's garden
[Re: AlexP]
#1675675
09/23/14 10:19 AM
09/23/14 10:19 AM
Posts: 6,404 Abilene, Texas
fastmark
Abilene, Texas
I tried the Amsoil and I did not like it and removed it. It leaked more and it clunked going into gears.
[Re: fourgearsavoy]
#1675676
09/23/14 10:46 AM
09/23/14 10:46 AM
Posts: 9,436 Blair County,PA
62maxwgn
Blair County,PA
Why not just use gear oil like they came. I have run it in them for years with no ill effect and I just did 4400 miles in the AAR with gear oil.
I've been rowing gears for over 30 years and I only use 90 wt. Gear oil in my boxes with syncronizers and Redline shock proof synthetic in my race non synchronized boxes. In some cold weather climates straight 30 weight non detergent oil will work Gus
Never used anything else and never had a problem.On another note,do you think vendors as mentioned above actually make gear oil ? It's a relabeled product from a major source like a good amount of what you buy these days.
