What to use in an 833 aside from ATF? #1675664
09/22/14 02:26 PM
09/22/14 02:26 PM
Houston, Tx
AlexP Offline OP
AlexP  Offline OP
Houston, Tx
So, I wasn't very happy with ATF the last time around in this Texas heat.
I'm stuck between the Amsoil MTL and the Penzoil Synchromesh. I'm also open to any suggestions.
How do these transmissions run with synthetic fluid?
My Build thread: Let the hemi swap begin!
1968 wanna be pro touring whatchamacallit with some fancy stuff and a new roof skin.
Re: What to use in an 833 aside from ATF? [Re: AlexP] #1675665
09/22/14 02:36 PM
09/22/14 02:36 PM
CT
GTX MATT Offline
GTX MATT  Offline
CT
Make sure you get GL4, not a GL5. Many GL5s will say it exceeds GL4, but many will be harsh on synchros. Brad Penn makes a GL4 in 80W90 that is reasonably priced on Amazon.
I wouldn't run ATF in one fwiw. Yes the FSM says you can do it, if you live in EXTREME cold, and it says to get rid of it once temps rise.
Re: What to use in an 833 aside from ATF? [Re: AlexP] #1675666
09/22/14 03:33 PM
09/22/14 03:33 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
The 833 loves synthetic fluid, my personal choice is Redline 75/90 NS.
Re: What to use in an 833 aside from ATF? [Re: John_Kunkel] #1675667
09/22/14 04:06 PM
09/22/14 04:06 PM
Houston, Tx
AlexP Offline OP
AlexP  Offline OP
Houston, Tx
I was hoping for that. I'd really like to use Amsoil.
Re: What to use in an 833 aside from ATF? [Re: John_Kunkel] #1675668
09/22/14 06:44 PM
09/22/14 06:44 PM
AZ - The "dry heat" state
71autoxr Offline
71autoxr  Offline
I agree in the az heat my 833 was brutal with atf. Swapped to redline and it is smooooth
68 AMX mopars red headed stepchild
69 Dart GT Convertible 340 4 speed
71 Challenger - looks like the avatar!
Re: What to use in an 833 aside from ATF? [Re: AlexP] #1675669
09/22/14 06:53 PM
09/22/14 06:53 PM
Washington
madscientist Offline
Washington
Skip the ATF.
Use a synthetic gear oil.
Look for a GL-6. They are out there. Expensive but worth it.
Re: What to use in an 833 aside from ATF? [Re: madscientist] #1675670
09/22/14 07:11 PM
09/22/14 07:11 PM
Texas
Daty Rogers Offline
World's Greatest Husband. I love you Robyn
Daty Rogers  Offline
Texas
I used 80-90w gear oil in Texas, worked great.
-Daty
Re: What to use in an 833 aside from ATF? [Re: Daty Rogers] #1675671
09/22/14 10:25 PM
09/22/14 10:25 PM
IN
ahy Offline
ahy  Offline
IN
Per the factory, the 833 likes heavier oil in the heat. ATF and Sycromesh are too thin. I agree the Redline "MT90" would be a good choice. Regular 90 wt would probably do OK also if you could find it in GL4.
Re: What to use in an 833 aside from ATF? [Re: ahy] #1675672
09/22/14 10:47 PM
09/22/14 10:47 PM
mopar346 Offline
Let me tell ya about fat chicks!
mopar346  Offline
Why not just use gear oil like they came. I have run it in them for years with no ill effect and I just did 4400 miles in the AAR with gear oil.
Careful, your character's showing!
Re: What to use in an 833 aside from ATF? [Re: mopar346] #1675673
09/23/14 12:42 AM
09/23/14 12:42 AM
Rittman Ohio
fourgearsavoy Offline
Rittman Ohio
I've been rowing gears for over 30 years and I only use 90 wt. Gear oil in my boxes with syncronizers and Redline shock proof synthetic in my race non synchronized boxes. In some cold weather climates straight 30 weight non detergent oil will work
Gus
64 Plymouth Savoy
Dana 60
Re: What to use in an 833 aside from ATF? [Re: fourgearsavoy] #1675674
09/23/14 10:10 AM
09/23/14 10:10 AM
Connecticut
Ron_M Offline
Ron_M  Offline
Connecticut
Plenty of past threads on this topic.
I use Passon Performance Gear lube. (570-401-8949) Just stocked up and 5QTs was around $60.00 shipped to my door.
I tried the Synchromesh and did not like it.
Common sense is a flower that does not grow in everybody's garden
Re: What to use in an 833 aside from ATF? [Re: AlexP] #1675675
09/23/14 10:19 AM
09/23/14 10:19 AM
Abilene, Texas
fastmark Offline
fastmark  Offline
Abilene, Texas
I tried the Amsoil and I did not like it and removed it. It leaked more and it clunked going into gears.
Re: What to use in an 833 aside from ATF? [Re: fourgearsavoy] #1675676
09/23/14 10:46 AM
09/23/14 10:46 AM
Blair County,PA
62maxwgn Offline
62maxwgn  Offline
Blair County,PA
Gus
Never used anything else and never had a problem.On another note,do you think vendors as mentioned above actually make gear oil ? It's a relabeled product from a major source like a good amount of what you buy these days.
Re: What to use in an 833 aside from ATF? [Re: Ron_M] #1675677
09/23/14 11:14 AM
09/23/14 11:14 AM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
Castrol Syncromesh in a friends car just recently. It's the only GL-4 stuff I could find locally, in his price range , no issues.
