finally a new best time... well needed!! #1675494
09/22/14 12:40 AM
09/22/14 12:40 AM
WI, USA
67dodge67 Offline OP
mopar addict
mopar addict
WI, USA
Hello all,
It's been quite a while since I've been on here because of that thing called "life" but last week Tuesday, I got down to the local track, Great Lakes Dragway and made history. 67 Coronet, 470, 4.10 dana, blah blah and got a new best.... 11.23 @ 121mph. I had a buddy of mine join me and take A LOT of video of my runs, showing how the car reacts and what could be done to tune it for a quicker time. I've posted Q's here in the past and have had a lot of responses, some of which were very helpful. I've got a few things to do to hit that 10.99 mark, and hope to do so when next year comes around. I'd like to say thanks to everyone here who have chimed in on my Q's that I've asked (yah, I'm a slow learner at times) and wish the best for everyone here.
Here's a still shot of me off the line... not the 11.23 run, but still pretty cool!
Regards, Dave
Re: finally a new best time... well needed!! [Re: 67dodge67] #1675495
09/22/14 07:16 AM
09/22/14 07:16 AM
Balt. Md
3
383man Offline
383man  Offline
Balt. Md
Congrats on the new best in that cool Coronet. Good luck getting that 10.99 slip as I know its a good feeling to break that 11.00 mark as I first ran 10's at a T & T and then last year when I ran in a NSS race I remember when I put my dail on my window that it was the first time I had ever got to put a 10 something dail on my window. That was a very good feeling. I am sure it wont be to long before you hit that magic 10 second mark. Ron
Re: finally a new best time... well needed!! [Re: 383man] #1675496
09/22/14 08:01 AM
09/22/14 08:01 AM
Hampton,Va
Q
QuickDart 502 Offline
Q
Hampton,Va
Great job!
Re: finally a new best time... well needed!! [Re: 67dodge67] #1675497
09/22/14 08:26 AM
09/22/14 08:26 AM
gregsdart Offline
gregsdart  Offline
Congrats! It is always fun to hit a new best.
Re: finally a new best time... well needed!! [Re: 67dodge67] #1675498
09/22/14 12:26 PM
09/22/14 12:26 PM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
NICE.............New best`s are a blast and w/more work, youll meet that goal. See if you can mount those rear shocks more verticle it defnately helped my junk but no track passes yet but hooked on the street very well.
Re: finally a new best time... well needed!! [Re: Thumperdart] #1675499
09/22/14 12:31 PM
09/22/14 12:31 PM
PA.
pittsburghracer Offline
"Little"John
"Little"John
PA.
Congratulations. Nothing better than running a new best UNLESS its running a new best while winning a pocket full of money.
1970 Duster
Edelbrock headed 408
5.984@112.52
422 Indy headed small block
5.982@112.56 mph
9.42@138.27
Re: finally a new best time... well needed!! [Re: 67dodge67] #1675500
09/22/14 02:02 PM
09/22/14 02:02 PM
Whats the time slip show on all the incrementals? Maybe we can give you some pointer on what is good and what is not so good
Re: finally a new best time... well needed!! [Re: Cab_Burge] #1675501
09/22/14 06:08 PM
09/22/14 06:08 PM
A Red State
SNK-EYZ Offline
SNK-EYZ  Offline
A Red State
Conratulations!
Re: finally a new best time... well needed!! [Re: SNK-EYZ] #1675502
09/22/14 06:25 PM
09/22/14 06:25 PM
Las Vegas NV
moparmanjames Offline
Las Vegas NV
Nice!
Re: finally a new best time... well needed!! [Re: moparmanjames] #1675503
09/22/14 07:43 PM
09/22/14 07:43 PM
Sydney,Australia
tex013 Offline
tex013  Offline
Sydney,Australia
nice run , you have the MPH for 10's now all you need is bring it together
Tex
New best ET 10.259@129.65 .
New best MPH 130.32
Finally fitted a solid cam,
stepped it up a bit more
3690lbs through the mufflers
Power by Tex's Automotive
Re: finally a new best time... well needed!! [Re: Cab_Burge] #1675504
09/23/14 12:46 AM
09/23/14 12:46 AM
WI, USA
mopar addict
mopar addict
WI, USA
Don't have a working scanner here so here's the time slip info: r/t .138 60' 1.642 330 4.596 1/8th 7.228, mph 98.46 1000' 9.428 1/4 11.23 mph 121
Something I forgot to include in my initial post, I put on a 150 shot of NOS which I am still getting used to... here's the deal, I have a momentary button mounted on my dash, right next to where my thumb would hit perfectly to press it while holding onto the steering wheel (should take a pic of it to explain this further). I am convinced that if I put the microswitch on the throttle so I have a better control of it vs using a thumb, I'll be in the 10's. Having not used nitrous before, I did some test hits with it... first couple runs to get the feel of it, I didn't hit the button until I was in "drive" the best was a 11.50 at xx mph. Said the hell with it, lets try to hit that button right after shifting into 2nd (hope that makes sense). Got lucky with that after a couple more runs and finally hit that 11.23 and called it a night (need to upgrade my front brakes!). I talked to a bud of mine who said ya gotta spray that bi...ch right out of the hole and the 10 sec time WILL happen.
So, after I get that set up, I'll see how she reacts. I do know I might want to play with the rear shocks, they are QA-1's, single adjustable, set at the halfway mark (50/50 I guess it would be) Thought about moving the setting up one on the positive side for a stronger plant. I do have Caltracs, but no mono leaf, they are the old xtra heavy duty leafs BUT, my 60' isn't all that bad. They are set to what Caltrac recommends according to their info sheet. M/T slicks, 15x28x11.5 set at 19psi. Perfect patch.
That's a lot of info, hope to hear some suggestions in the near future. Again, thanks to everyone on here
Re: finally a new best time... well needed!! [Re: tex013] #1675505
09/23/14 12:48 AM
09/23/14 12:48 AM
WI, USA
mopar addict
mopar addict
WI, USA
Thanks everyone! Hoping to hit that 10.99 mark by the end of the season!! Cheers!!
Re: finally a new best time... well needed!! [Re: 67dodge67] #1675506
09/23/14 01:17 AM
09/23/14 01:17 AM
WI, USA
mopar addict
mopar addict
WI, USA
still shot of a roll up into the box...
Re: finally a new best time... well needed!! [Re: 67dodge67] #1675507
09/23/14 01:18 AM
09/23/14 01:18 AM
WI, USA
mopar addict
mopar addict
WI, USA
nite time in the garage.... ha, I feel like a proud papa...
Re: finally a new best time... well needed!! [Re: 67dodge67] #1675508
09/23/14 01:31 AM
09/23/14 01:31 AM
Puyallup, WA
StealthWedge67 Offline
Puyallup, WA
Nice work, I went a new best this year as well and I know it feels good, Congrats!
Judging from your incrementals, your 10 second slip lies in figuring out the 1st 60 feet. For your ET, MPH and all other incrementals, the 60 ft. is off by a pretty wide margin. 4.10's with the tall tires may be to blame, but probably also make for a pretty livable street ride. For reference, my car is faster to 60' @ 1.633, running 11.80's. Every incremental from their on seems to get better though.
Gorgeous car, by the way!!
Re: finally a new best time... well needed!! [Re: 67dodge67] #1675509
09/23/14 01:58 AM
09/23/14 01:58 AM
I have a 1966 Dodge deluxe two door sedan that I'm putting together as a street car, ex 6 cyl 3 speed car, going to a 440(464 C.I. ) with a 833 O.D. trans with a Dana 60 with 3:54 gears and small rear tires, probally 255x60x15. I hope I like it
Re: finally a new best time... well needed!! [Re: 67dodge67] #1675510
09/23/14 01:59 AM
09/23/14 01:59 AM
Janesville, WI
SpareParts Offline
SpareParts  Offline
Janesville, WI
I think the 60' could be a little bit better personally. Tuesday isn't the best night to go to GLD, give it a shot on a Thursday night and usually the track is working better.
What's the suspension/shock setup? I'd possibly be willing to come meet ya at the track and watch things, I know another member may be there firday night with a dart
Re: finally a new best time... well needed!! [Re: SpareParts] #1675511
09/23/14 02:48 AM
09/23/14 02:48 AM
Union grove,wi
cj391 Offline
cj391  Offline
Union grove,wi
Friday night is the plan for me, ugly white dart with a black hood.
Re: finally a new best time... well needed!! [Re: cj391] #1675512
09/23/14 10:46 AM
09/23/14 10:46 AM
robin hood country
deaks Offline
deaks  Offline
robin hood country
Well done, always nice to have a new best. Your 60 ft definitely needs looking at, what does it run on the motor ?
I used to have a 67 R/T, lovely cars.
Mick
69 Dart GTS 440 mopar .590 cam, Edelbrock heads, 3200#
best et 6.45, 106.78, 10.14, 132.88 mph, 1.47 60ft
best 60ft 1.36
Re: finally a new best time... well needed!! [Re: SpareParts] #1675513
09/23/14 10:58 PM
09/23/14 10:58 PM
WI, USA
mopar addict
mopar addict
WI, USA
I have been there on Thursday nights... to be honest, I haven't really seen a significant difference. Infact, I did see those guys do additional spray/glue on the track at the line when I'd pull up... haha, they know me there. 90/10's in the front, stock suspension otherwise (I am seriously considering the 6 cyl torsion bars from Firm Feel). Rear are the xtra heavy duty leafs, Caltracs, QA-1 single adjustables set at 50-50. Guys back in the day were using those leafs and doing verrrrrry well so I'm not sold on mono leafs yet.
Unfortunately, my work schedule doesn't allow me to go to the track on the weekends, unless I ask off. Working in sales with liquor means the weekends are INSANE busy.
I do have a list of to-do's and realize some things to consider are the nitrous set up I have; see my earlier post, and tune the suspension. I know that 10.99 is just around the corner, it's just a matter of time
Thanks again to all who have chimed in!! I greatly appreciate it!!
