518 transmission question #1675230
09/21/14 04:43 PM
09/21/14 04:43 PM
Minnesota
Hemi_Joel Offline OP
Minnesota
my 93 1 ton dodge has a turned up cummins diesel and the automatic overdrive transmission. I had the transmission beefed up and rebuilt 80,000 miles ago, and it has performed flawlessly. The truck is always heavily loaded with a big camper in the bed, and usually towing a trailer, always on out of town trips. I am wondering, after 80,000 miles is there anything that I need to do to maintain this transmission and keep it going reliably? Like band ajustment or something? I do change the fluid and filter very regularly. I do not want anymore breakdowns 1000 miles from home like i had last february when the flexplate broke.
I am rather ignorant when it comes to automatics. Thanks, Joel
RS23J71
RS27J77
RP23J71
RO23J71
WM21J8A
Re: 518 transmission question [Re: Hemi_Joel] #1675231
09/21/14 04:50 PM
09/21/14 04:50 PM
MR_P_BODY Offline
MR_P_BODY  Offline
Since you change the fluid and filter.. just check
the band adjustment.. only other thing you might want
to check is that the conv bolts are tight
Re: 518 transmission question [Re: MR_P_BODY] #1675232
09/22/14 01:03 AM
09/22/14 01:03 AM
Oologah, Oklahoma
Big Squeeze Offline
Big Squeeze  Offline
Oologah, Oklahoma
There is no guarantee it won't break down 1,000 miles from home...all you can do is keep the fluid clean...if it's red, it's a waste to change it IMHO...once the bands are adjusted, I never check them again...that adjustment will only move if it's been slipping and you'll feel that...
If you can't handle the truth, you're living a lie.......
Re: 518 transmission question [Re: Big Squeeze] #1675233
09/22/14 03:26 PM
09/22/14 03:26 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
Even in the mildest service, friction material will wear and the band adjustment will need to be checked/reset periodically.
Pull the pan on a trans with clean red fluid and you'll usually find the powdery residue left from clutch/band wear.
Re: 518 transmission question [Re: John_Kunkel] #1675234
09/22/14 03:32 PM
09/22/14 03:32 PM
A Banana Republic near you.
JohnRR Offline
JohnRR  Offline
The front band is STOPPING a spinning drum , it's going to wear. the rear band is 99.9% of the time grabbing a drum that is not spinning.
Re: 518 transmission question [Re: JohnRR] #1675235
09/22/14 11:58 PM
09/22/14 11:58 PM
Oologah, Oklahoma
Big Squeeze Offline
Big Squeeze  Offline
Oologah, Oklahoma
and peeing in the ocean raises the tide too.....
It takes a TON of driving for the band to be worn enough to require adjustment......
Clutches stop drums from spinning too..........and there's normal wear and tear from them too.........may as well pull the trans and reset clutch clearances every service too.......
Re: 518 transmission question [Re: Big Squeeze] #1675236
09/23/14 03:50 PM
09/23/14 03:50 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
Mopar should have listened to you and eliminated the threaded adjuster...coulda just set the band on initial assembly ala the TH400 and let it go.
Re: 518 transmission question [Re: John_Kunkel] #1675237
09/23/14 03:55 PM
09/23/14 03:55 PM
Minnesota
Minnesota
Thanks for all the replies. I don't suppose it will hurt to check it while it is on the hoist.
RS23J71
RS27J77
RP23J71
RO23J71
WM21J8A
Re: 518 transmission question [Re: Hemi_Joel] #1675238
09/23/14 10:19 PM
09/23/14 10:19 PM
Kissimmee Fl.
dusturbd340W5 Offline
Kissimmee Fl.
the lining on a new band is maybe 1/16" thick if you get enough wear that adjusting it makes much difference you have bigger issues.
70 duster full chassis super pro 416 CNC Indybrock heads 727 w/brake
best so far 1.212 60 6.219 in 1/8 at 110.88 9.768 at 137.81 1/4
Re: 518 transmission question [Re: dusturbd340W5] #1675239
09/23/14 10:53 PM
09/23/14 10:53 PM
MR_P_BODY Offline
MR_P_BODY  Offline
It might not make a difference but it would be back
in spec... thats a large diameter band and if you do
the 3.1416 X the diameter that can be a turn or so
on the adjuster..
what does it ever hurt to set the band.. hell it even
helps the shift timing
Re: 518 transmission question [Re: Hemi_Joel] #1675240
09/23/14 11:04 PM
09/23/14 11:04 PM
NC
440Jim Offline
440Jim  Offline
NC
With that use, the front band adjustment just makes sense. You are doing a good job with fluid and filter changes, and I assume cleaning the gunk in the bottom of the pan when it is off to change the filter. The trans fluid temperature is important also, but without a temperature gauge, I can't make any guesses.
When I have the pan off, I like to adjust the front band by using a 5/16" allen wrench as a "feeler gauge" between the front servo and the lever. Pull the lever by hand firmly and set the adjustment. It is more consistant than "torque to 72 in-lbs and back off", but can only be done with the pan off.
Re: 518 transmission question [Re: Hemi_Joel] #1675241
09/23/14 11:28 PM
09/23/14 11:28 PM
Way North Idaho
1KoolBee Offline
1KoolBee  Offline
Way North Idaho
It's basically a 727 with OD and converter lockup. Same basic maintenance schedule as a '63 imperial, but the band adjustments may be a little different. Be careful towing in OD, that Cummins can easily kill the OD unit as it will happily drag a 10K load up a decent grade in OD. The only difference between a v6 OD unit and a diesel is a few clutches and an extra planetary pinion. The torque wants to shove the guts out the back of the case and will actually stretch the case. Don't ask me how I know......
'68 Bee 383/TF/Factory Air...high school sweetheart
'67 GTX Clone project,500 six pack,Hemi4-speed,Dana
05 Dodge Viper, 505 V-10, 6-speed Tremec
Re: 518 transmission question [Re: 1KoolBee] #1675242
09/24/14 12:32 AM
09/24/14 12:32 AM
Minnesota
Minnesota
the guy who built the transmission for me did modifications to the overdrive so that it will live under heavy load.I'm driving all over the country in overdrive at 20000 pounds, so he must have done a good job. The truck has a transmission cooler with a fan on mounted under the bed + the cooler inside the radiator. The truck has a tranns temp. Guage. it never gets above 180, unless the engine coolant temperature gets above that, then it seems to heat the transmission fluid up to engine temperature.
Re: 518 transmission question [Re: Hemi_Joel] #1675243
09/24/14 12:37 AM
09/24/14 12:37 AM
Way North Idaho
1KoolBee Offline
1KoolBee  Offline
Way North Idaho
Sounds like you did it right, unlike some of us who have to learn the hard way!
Re: 518 transmission question [Re: MR_P_BODY] #1675244
09/24/14 01:54 AM
09/24/14 01:54 AM
Kissimmee Fl.
Kissimmee Fl.
on the adjuster..
It doesn't hurt anything at all and it is easy to do so its no big deal to check it.
It was standard practice to adjust all bands when we serviced a unit but 99% of the time they where never out enough to even show up.
I guess what I am trying to get at is I have adjusted probably 1000 bands on all kinds of different units over 27 years in the business and have rarely found one to be out of adjustment enough to make any difference in the way the unit worked.
If the unit was built correctly and adjusted correctly to begin with and it is functioning as it should I doubt you will see any difference after a band adjustment.
now if the band was never adjusted correctly to begin with when the unit was built or there is another problem than that is a different story.
Re: 518 transmission question [Re: Big Squeeze] #1675245
09/24/14 10:41 AM
09/24/14 10:41 AM
JohnRR Offline
JohnRR  Offline
If you say so ...
Re: 518 transmission question [Re: JohnRR] #1675246
09/24/14 02:26 PM
09/24/14 02:26 PM
fredericksburg,va
cudaman1969 Offline
cudaman1969  Offline
fredericksburg,va
My 06 3500 diesel smoked the trans at 40,000 miles, took out band and half the front clutches. Seems it was a pressure problem but it has a 5.0 lever( alot of servo movement not much band movement) and i adjust every 15,000 now, should have switched to a 3.9 also added GM valve on the valve body to help that pressure problem. I would say at 80,000 miles pulling a heavy load get a new trans ready, clutches and band just about used up, like brake pads.
Re: 518 transmission question [Re: cudaman1969] #1675247
09/24/14 10:29 PM
09/24/14 10:29 PM
moparx Offline
moparx  Offline
please explain the "gm valve" mod.
Re: 518 transmission question [Re: moparx] #1675248
09/24/14 11:15 PM
09/24/14 11:15 PM
Benton, IL.
DaveRS23 Offline
Special needs idiot
DaveRS23  Offline
Special needs idiot
Benton, IL.
We used to buy 2000ish Dodge trucks at the auctions with no second gear. As long as they hadn't driven it so long like that, that 3rd gear was hurt, I would just drop the pan and put the strut plate back in place, adjust the band and go.
I have run into a dozen or so like that over the years. Most had right around 100k.
Master, again and still
Re: 518 transmission question [Re: DaveRS23] #1675249
09/25/14 12:51 AM
09/25/14 12:51 AM
Missouri U.S.A.
71yelladustr Offline
Missouri U.S.A.
Seen quite a few also with the band strut popped out. Most of them chip a piece of the cup portion that mates to the adjuster and need replaced. As for the "GM sensor mod", he is talking about replacing the junk factory governor pressure solenoid found in RE type transmissions with a larger less problematic solenoid similar to what is found in GM transmissions.
392 gen III hemi on E-85 727 trans Dana 60
10.02@134
