Page 15 of 16 1 2 13 14 15 16
Re: please share your gen 3 Hemi build [Re: sixpackgut] #1675090
10/17/14 10:30 PM
10/17/14 10:30 PM
San Angelo, Texas
Cevidicus Offline
Cevidicus  Offline
San Angelo, Texas
Anybody have a part number for a 6.4 crank and a 6.4 short block?
Re: please share your gen 3 Hemi build [Re: Cevidicus] #1675091
10/17/14 11:07 PM
10/17/14 11:07 PM
Nebraska
72Swinger Offline
72Swinger  Offline
Nebraska
Mopar to the bone!!!
Re: please share your gen 3 Hemi build [Re: Cevidicus] #1675092
10/18/14 11:52 AM
10/18/14 11:52 AM
Ontario Canada
MattW Offline
MattW  Offline
Ontario Canada
Short block 68086564AB orRL086564AB
Crankshaft 5038339A
Re: please share your gen 3 Hemi build [Re: MattW] #1675093
10/18/14 11:55 AM
10/18/14 11:55 AM
Toronto
mshred Offline
mshred  Offline
Toronto
Crankshaft 5038339A
The 6.4 crankshaft is forged, correct?
Does anybody know if the 6.4 crank has the same oiling issues as a 5.7 crank does? Wondering if it is a good alternative to aftermarket forged crank for a stroker 5.7 motor.
Re: please share your gen 3 Hemi build [Re: mshred] #1675094
10/18/14 02:42 PM
10/18/14 02:42 PM
Ontario Canada
MattW Offline
MattW  Offline
Ontario Canada
Crankshaft 5038339A
AFAIK the oiling is the same.
The crank is forged. Matt
Re: please share your gen 3 Hemi build [Re: MattW] #1675095
10/18/14 03:56 PM
10/18/14 03:56 PM
Smyrna, South Carolina
STEFF Offline
STEFF  Offline
Just curious why anyone wants to run a stock crank when the aftermarket cranks are a better piece and not that much more expensive...
Re: please share your gen 3 Hemi build [Re: STEFF] #1675096
10/18/14 04:12 PM
10/18/14 04:12 PM
Ontario Canada
MattW Offline
MattW  Offline
Ontario Canada
But I bought mine for half the price that they are now.
Re: please share your gen 3 Hemi build [Re: MattW] #1675097
10/18/14 05:00 PM
10/18/14 05:00 PM
Houston Tx
Uhcoog1 Offline
Uhcoog1  Offline
Houston Tx
I think the idea that the cranks are causing oiling issues is mostly BS.
Stanton Racing (drag pak builder) told me the drag pak cars need 11.5 quarts between the pan and accusump. And there are at least a half dozen guys running stock 6.1 cranks shifting at 8200-8600 rpm and all have been fine for 2+ years.
Also- for those planning builds- the VVT motor cranks require machining if you want to run them in a non-VVT motor.
-'02 Dodge Viper Ex-World Challenge racecar
-'73 Duster, 6.1 based 392 hilborn hemi, tko600, full floater rear 9", Hellwig custom bars, viper brakes, built for road course
Re: please share your gen 3 Hemi build [Re: Uhcoog1] #1675098
10/18/14 06:24 PM
10/18/14 06:24 PM
Canada
onig Offline
onig  Offline
Canada
What makes a VVT crank different from a non VVT?
What machining steps are required?
69 Dart
Re: please share your gen 3 Hemi build [Re: STEFF] #1675099
10/18/14 06:31 PM
10/18/14 06:31 PM
Toronto
mshred Offline
mshred  Offline
Toronto
I agree 100% with you Stef as the Molnar stuff is only like $100 more...But you never know when you might catch a good deal on a 6.4 crank, and I just thought I would ask since I was unsure if the oiling issues was restricted to 5.7s only, or also 6.1's and 6.4's also.
Re: please share your gen 3 Hemi build [Re: onig] #1675100
10/18/14 07:05 PM
10/18/14 07:05 PM
STEFF Offline
STEFF  Offline
Timing gear is positioned further forward on the VVT crank. Would need to machine the crank snout to work in non VVT motor.
Re: please share your gen 3 Hemi build [Re: onig] #1675101
10/18/14 07:14 PM
10/18/14 07:14 PM
Ontario Canada
MattW Offline
MattW  Offline
Ontario Canada
Lets see if I can explain this correctly.
The VVT crank needs the snout where the crank timing gear rest against to be machined so the gear sits in the same factory location on an NON VVT block.
Simple process.
The cam in a VVT block is longer.
Steff posted some pics when he built his 6.4.
Matt
Re: please share your gen 3 Hemi build [Re: 72Swinger] #1675102
10/18/14 09:07 PM
10/18/14 09:07 PM
Portersville, Pa
1badx Offline
1badx  Offline
Portersville, Pa
Mike at that boost level what valvesprings and lifter setup are you using?
Stock 6.1 lifters and whatever springs PWR recommended for the cam.
Re: please share your gen 3 Hemi build [Re: MattW] #1675103
10/18/14 09:14 PM
10/18/14 09:14 PM
Portersville, Pa
1badx Offline
1badx  Offline
Portersville, Pa
Stock 6.1 cranks generally go for about $150, are forged and can easily handle most power needs. Buy a set of good rods, pistons and studs and you will have a stout combo. On the flip side the price for aftermarket rotating assemblies is very affordable.
Re: please share your gen 3 Hemi build [Re: Uhcoog1] #1675104
10/19/14 10:22 AM
10/19/14 10:22 AM
MN
hemidup Offline
hemidup  Offline
MN
Stanton mass produced the Drag Pak engines.For whatever reason he ground down the 6.1 rod journals to except Chevy SB rods. Whomever he chose to grind the crankshafts down must have been "someone" with little or no knowledge how to properly grind a crankshaft. After disassembling the Stanton fresh built 5.7 the first red flag rose when I noticed was that some of the supposedly zero deck pistons where either sticking out of the hole or in the hole which tells me that "someone" didn't know how to index a crankshaft properly. And the worse cluster mess up was that one piston was .006" above deck on the pin side and .005" in the hole on the other side??? .011" difference from pin to pin on a 3.917 bore. How hard on the rod bearings would that much deflection on the rod journal cause? I brought this up to Stanton himself but I'm not inclined to tell you what his suggestions were cause he'd probably plead the 5th so I made the decision to scrap the crank and grind a new one that I had on hand. So that brings up the question as to how many Drag Pak owners used their Stanton built motors as is and blame oiling issues as the reason they windowed a block? Anyways, just to be safe a Molnar crankshaft was purchased to replace the OEM 6.1.
Jerry Williams.
Re: please share your gen 3 Hemi build [Re: STEFF] #1675105
10/19/14 11:04 AM
10/19/14 11:04 AM
Canada
onig Offline
onig  Offline
Canada
Does this also apply to 5.7 and 6.1?
69 Dart
Re: please share your gen 3 Hemi build [Re: onig] #1675106
10/19/14 11:07 AM
10/19/14 11:07 AM
Ontario Canada
MattW Offline
MattW  Offline
Ontario Canada
No.
The only ones affected were the 6.4 and the 5.7 eagle head motors. 09 and up for the 5.7.
I think the 6.4 came out in 2011.
Re: please share your gen 3 Hemi build [Re: MattW] #1675107
10/19/14 11:15 AM
10/19/14 11:15 AM
Canada
onig Offline
onig  Offline
Canada
6.1 engines did not come with VVT?
69 Dart
Re: please share your gen 3 Hemi build [Re: MattW] #1675108
10/19/14 02:33 PM
10/19/14 02:33 PM
Canada
onig Offline
onig  Offline
Canada
Simple process.
Matt
I saw the pics that you posted on the other thread. That shows what you mean. Picture is worth a thousand words.
Thanks Matt!
Onig
69 Dart
Re: please share your gen 3 Hemi build [Re: onig] #1675109
10/19/14 03:04 PM
10/19/14 03:04 PM
Nebraska
72Swinger Offline
72Swinger  Offline
Nebraska
Never!
