Page 1 of 4 1 2 3 4
I over torqed my tie rod end...what should I do? #1674630
09/20/14 09:34 PM
09/20/14 09:34 PM
Toronto, Ontario, Canada
plazomat Offline OP
plazomat  Offline OP
Bone head move...While rebuilding the front end on my 69 B, I way over torqed my inner tie rod end...probably 70-80 before I figured something was wrong..I backed off the nut and retorqed to 45lbs - the cotter pin hole is a few threads above the nut..
Should I get another rod end and start over? Remove this one and try with it again?
Run it like it is? Use a washer under the nut to bring the hole into better position?
Plaz
Re: I over torqed my tie rod end...what should I do? [Re: plazomat] #1674631
09/20/14 09:55 PM
09/20/14 09:55 PM
PA
70Duster Offline
70Duster  Offline
PA
Retorque to 45 ft-lbs, install the cotter pin and leave it alone.
Re: I over torqed my tie rod end...what should I do? [Re: 70Duster] #1674632
09/20/14 10:53 PM
09/20/14 10:53 PM
plazomat Offline OP
plazomat  Offline OP
But the cotter pin will be a few threads above the castle nut and not really do any thing?
I have seen instructions for ball joints where you add a washer under the nut to raise it up on the threaded portion so that the nut/hole/pin work together..
Anyone seen this done?
Plaz
Re: I over torqed my tie rod end...what should I do? [Re: plazomat] #1674633
09/20/14 11:26 PM
09/20/14 11:26 PM
IN
ahy Offline
ahy  Offline
IN
I have used machine washers with castle nuts. Available at ACE in a couple different thicknesses. Mix and match as needed.
Re: I over torqed my tie rod end...what should I do? [Re: ahy] #1674634
09/21/14 12:56 AM
09/21/14 12:56 AM
WI. U.S.A.
DusTed74 Offline
DusTed74  Offline
WI. U.S.A.
Like was said above. Remove the nut and install the washer. torque the nut and install the cotter pin. If it doesn't torque up then you have a problem otherwise don't give it a second thought.
Ted
Re: I over torqed my tie rod end...what should I do? [Re: DusTed74] #1674635
09/21/14 02:45 AM
09/21/14 02:45 AM
plazomat Offline OP
plazomat  Offline OP
Awesome - I will get a washer or 2 in there in the am..
Plaz
Re: I over torqed my tie rod end...what should I do? [Re: plazomat] #1674636
09/21/14 12:03 PM
09/21/14 12:03 PM
A Banana Republic near you.
JohnRR Offline
JohnRR  Offline
Something is not right , you either screwed up the taper because the arm it was going into was soft or your stretched the tie rod stud , the stud length is not to spec or the nut is not to spec , you need to find out which before just throwing a washer under it and calling it good.
Re: I over torqed my tie rod end...what should I do? [Re: JohnRR] #1674637
09/21/14 12:14 PM
09/21/14 12:14 PM
What I'd do is eyeball one of the other tie rod ends (that is correctly installed) & see what ain't right/different on the bad one & go from there
Re: I over torqed my tie rod end...what should I do? [Re: RapidRobert] #1674638
09/21/14 12:40 PM
09/21/14 12:40 PM
Ohio
jlatessa Offline
jlatessa  Offline
Ohio
Sometimes the castled nut sp? is a different height and the slots in it are either too high, or as in your case, too low.
Check if there is one more suited to your application.
Also, with the nut off, see if any of the threads on the stud have been deformed, i.e. stretched, it will usually show up where the threads end at the larger shank portion.
If not, you should be OK to go.
Just my two cents....
Joe
Re: I over torqed my tie rod end...what should I do? [Re: JohnRR] #1674639
09/21/14 01:03 PM
09/21/14 01:03 PM
Delaware
GeorgeH Offline
GeorgeH  Offline
Delaware
X2 You might have pulled the ball through the cage internally. It's just not worth taking your life in your hands over a $15 steering component.
Re: I over torqed my tie rod end...what should I do? [Re: GeorgeH] #1674640
09/21/14 01:26 PM
09/21/14 01:26 PM
Moved to N.E. Tennessee
GomangoCuda Offline
GomangoCuda  Offline
That was my first thought.
Re: I over torqed my tie rod end...what should I do? [Re: JohnRR] #1674641
09/21/14 01:35 PM
09/21/14 01:35 PM
Omaha Ne
TJP Offline
TJP  Offline
Omaha Ne
X 3 or 4
Re: I over torqed my tie rod end...what should I do? [Re: TJP] #1674642
09/21/14 02:09 PM
09/21/14 02:09 PM
Rust Belt, SW PA
Silver70 Offline
Silver70  Offline
Rust Belt, SW PA
I bought tie rod ends from rockauto, 4 bucks a piece... like mentioned, not worth the risk, life or the car.
68 Road Runner, 69 Belvedere, 71 Challenger Vert
340 barracuda, 01 Ram CTD, 95 Ram, 04 Ram, 85 Daytona turbo Z
66 GTO, 06 Magnum RT AWD. 07 Ram CTD, 07 Ram
Re: I over torqed my tie rod end...what should I do? [Re: jlatessa] #1674643
09/21/14 02:19 PM
09/21/14 02:19 PM
Ohio
carteravs Online content
carteravs  Online Content
Ohio
You're right, the "tall" nuts are used with ends that have a dog point
on the end of the stud. The "short" nuts fit ends that are threaded all the way to the end of the stud.
Re: I over torqed my tie rod end...what should I do? [Re: JohnRR] #1674644
09/21/14 02:41 PM
09/21/14 02:41 PM
God's Country Maryland
GODSCOUNTRY340 Offline
100% correct, you've hurt something. Either you've pulled the ball almost out of the joint or stretched the shaft, REPLACE THAT TIEROD.
Re: I over torqed my tie rod end...what should I do? [Re: GODSCOUNTRY340] #1674645
09/21/14 05:36 PM
09/21/14 05:36 PM
Niles , Ohio
therocks Online content
therocks  Online Content
Niles , Ohio
I think you could tighten it to 500 ftlbs and not pull the ball out of the socket.It stops when the taper gets so far.Only thing you might do is stretch the threads a bit.That ball will not pull out.You are pulling the tapers thats it
Rocky
Chrysler Firepower
Re: I over torqed my tie rod end...what should I do? [Re: therocks] #1674646
09/21/14 07:34 PM
09/21/14 07:34 PM
Phoenix - surface of the sun
nomore65BelvJim Offline
Rocky
Gotta agree with Rocky. 70-80 ftlbs isnt going to pull the ball out of the socket. My bet is you have the wrong castle nut. If you stretched it that much it would likely have broken or at least be deformed enough that you could see it.
Compare the stud length and castle nut to the others you installed.
Re: I over torqed my tie rod end...what should I do? [Re: nomore65BelvJim] #1674647
09/21/14 08:44 PM
09/21/14 08:44 PM
plazomat Offline OP
plazomat  Offline OP
Hey I agree that no amount is worth my life or my kids life - so I asked here for opinions. I fugured since lots of people use impacts not torque wrenches to install these - 70-80 lbs I aint the first to do..
If it wasn't for the nut/hole/cotter issue not sure I would have given it another thought.
I will order another joint - I will remove the nut maybe even the joint to check the taper on the arm and use this as a learning moment - I hope i did not FUBAR it..
Plaz
Re: I over torqed my tie rod end...what should I do? [Re: nomore65BelvJim] #1674648
09/21/14 08:45 PM
09/21/14 08:45 PM
Niles , Ohio
Niles , Ohio
Jim I think some of this stuff is way over thought.I can tell these guys never worked in a garage at flat rate.Zip them in with your impact.Just dont go wild doing it.That was on daily drivers that saw more miles in a month than most of these will see in 2 years. Rocky
Chrysler Firepower
Re: I over torqed my tie rod end...what should I do? [Re: therocks] #1674649
09/21/14 09:24 PM
09/21/14 09:24 PM
BDW Online content
BDW  Online Content
Wise words, you think the factory designed something that would fail when torqued to 80lbs when only 40lbs is spec.
Add the washer and be done with it, don't waste money on another part you don't need.
Page 1 of 4 1 2 3 4
