Re: 572 Wedge, 440-1 345CNC Bracket Engine. Dyno Results
[Re: dvw]
#1674564
09/21/14 04:18 PM
09/21/14 04:18 PM
Posts: 970 Farmington Hills, Mich
Chuck@Best_Machine
TTI Headers 2.125 x 3.5
I know it wasn't tested here, but you have had previous experience with the Indy cross ram. Whats your guess if this motor were equipped with the Indy cross ram as far as peak torque and overall power numbers?
The last engine I dyno tested with the Indy X ram was my 512 with Brodix B1BS heads that I had in my Coronet it made 880hp and ran 9.0s at 3400 lbs
[Re: gregsdart]
#1674565
09/21/14 04:21 PM
09/21/14 04:21 PM
Chuck@Best_Machine
BMBBR5 Roller Cam 283 on a 115
Can you give us a little more info on that cam? LSA 115 (wider than I expected) Intake/Exhaust at 0.050" 283? Lift with the 1.6 ratio?
I bought your BMBB 3R from another racer for my 540 CID, 345CNC.
The big tubes lost quite a bit of torque for a few horsepower gain. I would say the smaller tubes are a better choice Keith
I liked the straight 2.125" headers. They made more torque and the horsepower pulled to the top of the pull (7400rpm). That surprised me with 572 CID. Perhaps the cam and 3X intake?
I am willing to bet the exhaust duration at .050 is over 300 degrees with that wide of a lsa. That would provide enough overlap in the "fifth cycle". It would also keep the other three opening and closing points close to what other cams have with less exhaust duration and narrower lsa. The exhaust opening point is the one that would move around( open earlier) if I am right.
[Re: Chuck@Best_Machine]
#1674567
09/23/14 11:19 PM
09/23/14 11:19 PM
Posts: 16,928 NC
440Jim
NC
Thanks for the cam card. Comparing it to your 3R cam I bought (used) it is 4 degrees longer duration, 3 degrees wider LSA, and the same lobe lift. That is in line with going from a 540 to 572 with your builds. And with that user's 1.6 ratio it comes out to .754/.722 valve lift.
#1674568
09/24/14 12:51 PM
09/24/14 12:51 PM
Posts: 503 Idaho
1320Dart
Idaho
If you don't mind me asking... What kind of flow numbers did the heads produce?
Greg ----------------------------------------------------------------- Cost is irrelevant, making memories is far more valuable!
[Re: 1320Dart]
#1674569
09/24/14 01:21 PM
09/24/14 01:21 PM
Posts: 1,770 Pa
Wv68charger
Pa
I opted to not have them flow tested they are OOTB -1 345s (but I did have them port matched them)
[Re: Wv68charger]
#1674570
09/24/14 01:23 PM
09/24/14 01:23 PM
Posts: 503 Idaho
1320Dart
Idaho
[Re: 340RICK]
#1674573
09/24/14 08:07 PM
09/24/14 08:07 PM
Posts: 1,770 Pa
Wv68charger
Pa
Nice build Good thing you are upgrading the chassis your going to need it
LOL Thanks Rick, That chassis needed upgraded since the last time it was touched....
It's in good hand now though
[Re: Al_Alguire]
#1674574
09/24/14 09:23 PM
09/24/14 09:23 PM
Posts: 1,770 Pa
Wv68charger
Pa
Like that LSA
Great build but come on I wanna see what it is going into
Here ya go Al
Nothing like your rides!
[Re: Wv68charger]
#1674575
09/24/14 09:42 PM
09/24/14 09:42 PM
Posts: 19,377 Las Vegas
Al_Alguire
Las Vegas
Very nice. Cannot wait to hear how she runs.
[Re: Al_Alguire]
#1674576
09/24/14 11:01 PM
09/24/14 11:01 PM
Posts: 1,770 Pa
Wv68charger
Pa
I just can't wait to get back to the track!
