Need info on swapping disc brakes onto a '64 Dodge 880 #1673515
09/18/14 05:20 AM
09/18/14 05:20 AM
Seattle, WA
3
375inStroke Offline OP
Special needs person
3
Seattle, WA
I guess this is a C-Body. Any luck on retrofitting discs onto this car. They really are pitiful. The Disc-o-Tech article says it works back to '65. What's different? This is my first C-Body, and it's really different under there.
Re: Need info on swapping disc brakes onto a '64 Dodge 880 [Re: 375inStroke] #1673516
09/18/14 10:08 AM
09/18/14 10:08 AM
Western Md.
skicker Offline
"The Champ"
skicker  Offline
"The Champ"
Western Md.
A 64 880 is a B Body. C bodies Started in the 65 model year. As far as a disc kit I used the entire knuckle assemblies off of an 87 Gran Fury on my 70 Satellite. I actually bought them for my 65 but opted to go Wilwood instead. They interchange 62-72 depending on sway bar applications. I'm not positive but I think the Diplomat Knuckles 81 and up are they same.
...FAFO...
Re: Need info on swapping disc brakes onto a '64 Dodge 880 [Re: skicker] #1673517
09/18/14 10:20 AM
09/18/14 10:20 AM
Downtown Roebuck Ont
Twostick Offline
Still wishing...
Twostick  Offline
Still wishing...
I'm sure someone will correct me if I'm wrong, but an 880 is a full size ie Chrysler platform not a B-body.
That being said, I think M-body type spindles can be coaxed into service.
IIRC Therocks has done this swap on a 62 300 which is the same basic car.
Kevin
Re: Need info on swapping disc brakes onto a '64 Dodge 880 [Re: Twostick] #1673518
09/18/14 10:30 AM
09/18/14 10:30 AM
Western Md.
skicker Offline
"The Champ"
skicker  Offline
"The Champ"
Western Md.
Twostick is right it is the larger Chrysler platform and not a B Body..my bad. I was thinking since the C body platform started in 65 that the prior years were all B Body. I forgot about the larger Chrysler cars.
...FAFO...
Re: Need info on swapping disc brakes onto a '64 Dodge 880 [Re: skicker] #1673519
09/18/14 10:35 AM
09/18/14 10:35 AM
Western Colorado High Desert
moparmarks Offline
moparmarks  Offline
A 1964 880 is a C-body. 1965 was the first year for a Plymouth C-body.
Desert Mopar Metal
Grand Jct. CO
970-261-7039
http://moparmark.com/
motormangj@gmail.com
Re: Need info on swapping disc brakes onto a '64 Dodge 880 [Re: Twostick] #1673520
09/18/14 10:38 AM
09/18/14 10:38 AM
Andrewh Offline
Andrewh  Offline
yeah, it is a full size, not a b-body.
if some one used m-body spindles on a 62 300, then it should work on the 880.
but I would wait to hear back from rocky to be sure.
that also means any of the b-body swaps should work too.
I didn't own mine long enough to try for a disc swap so I don't know what will work.
you can do a little research on part numbers for the upper and lower ball joints and see what interchanges.
Re: Need info on swapping disc brakes onto a '64 Dodge 880 [Re: moparmarks] #1673521
09/18/14 02:09 PM
09/18/14 02:09 PM
Twostick Offline
Still wishing...
Twostick  Offline
Still wishing...
Half right. 65 was the first year for a Plymouth C-body. Also the first year for Chrysler and Dodge.
Anything 64 and earlier has no letter designation as far as I know. They are just referred to as full size.
Kevin
Re: Need info on swapping disc brakes onto a '64 Dodge 880 [Re: Twostick] #1673522
09/18/14 02:25 PM
09/18/14 02:25 PM
Seattle, WA
3
3
Seattle, WA
The upper ball joints are the same as everything later that used the larger ball joint, so that's good. The lowers are different, and don't know if I should try the A-Body spindles or the taller B-Body ones. It's so different under there. The torsion adjuster is in back, not in the control arm. The upper control arm attaches to the crossmember, not the fender well. The shock is like 10" long and mounts inside a tube welded to the crossmember. There's almost no steering column. The steering box is right against the firewall. With all that, I don't see anything that would stop newer discs from bolting up. I don't know about anything unforeseen like geometry changes, bumpsteer, things like that.
Re: Need info on swapping disc brakes onto a '64 Dodge 880 [Re: 375inStroke] #1673523
09/18/14 03:06 PM
09/18/14 03:06 PM
AndyF Offline
AndyF  Offline
Disc brake swaps are a very common topic over on the C body Dry Dock forum. You should be able to find most everything known on the subject with a little bit of searching.
Re: Need info on swapping disc brakes onto a '64 Dodge 880 [Re: AndyF] #1673524
09/18/14 05:50 PM
09/18/14 05:50 PM
Seattle, WA
3
3
Seattle, WA
The Dry Dock gives conversion info going back to '65, and doesn't say why. I'll dig through further, though. Thanks. I appreciate all help.
Re: Need info on swapping disc brakes onto a '64 Dodge 880 [Re: 375inStroke] #1673525
09/18/14 06:03 PM
09/18/14 06:03 PM
Twostick Offline
Still wishing...
Twostick  Offline
Still wishing...
Because nothing before 65 is a C-body. Wrong forum for an 880.
Kevin
Re: Need info on swapping disc brakes onto a '64 Dodge 880 [Re: Twostick] #1673526
09/18/14 09:33 PM
09/18/14 09:33 PM
moparmarks Offline
moparmarks  Offline
Kevin
I thought the letter designation started in 62???
Desert Mopar Metal
Grand Jct. CO
970-261-7039
Re: Need info on swapping disc brakes onto a '64 Dodge 880 [Re: moparmarks] #1673527
09/18/14 10:49 PM
09/18/14 10:49 PM
Twostick Offline
Still wishing...
Twostick  Offline
Still wishing...
For A and B-bodies perhaps but C-body didn't start until 65.
Kevin
Re: Need info on swapping disc brakes onto a '64 Dodge 880 [Re: Twostick] #1673528
09/18/14 11:06 PM
09/18/14 11:06 PM
Freeport IL USA
poorboy Offline
poorboy  Offline
Freeport IL USA
My son's 57 full size Dodge has an aftermarket disc brake kit that uses the original spindle and adds a plate & a spacer for the bearings like they do with the older cars. We haven't done the complete swap yet, but the car's original spindles are pretty tall, I doubt an M body spindle has enough height. Gene
Re: Need info on swapping disc brakes onto a '64 Dodge 880 [Re: poorboy] #1673529
09/18/14 11:53 PM
09/18/14 11:53 PM
moparx Offline
moparx  Offline
although the 880 is considered to be a full size car[ C body or not], it uses the B body upper ball joint [ moog # k772 ] the lower ball joint is the screw in moog # k719. this is the same taper as the B body lower joint. therefore, use the standard conversion spindle of your choice, but you will have to use your lower spindle arm or the lower spindle arm from a late B or R body [diplomat, st. regis, etc.] the steering stop from said later lower arm may, or may not need trimmed or tweeked.
Re: Need info on swapping disc brakes onto a '64 Dodge 880 [Re: 375inStroke] #1673530
09/19/14 02:22 AM
09/19/14 02:22 AM
Canada
demon Offline
demon  Offline
Canada
All 1960-64 full size Mopars can have Aspen/ Volare or 5th Ave, Diplomat disc brakes swapped on.
Go to The Forward Look forum for more info on the full size early cars
Re: Need info on swapping disc brakes onto a '64 Dodge 880 [Re: demon] #1673531
09/19/14 11:58 AM
09/19/14 11:58 AM
Niles , Ohio
therocks Offline
therocks  Offline
Niles , Ohio
It depends though.My kids 62 300 takes B body joints.The same 62 New Yorker takes the larger C body type.Went thru it.Rocky
Chrysler Firepower
Re: Need info on swapping disc brakes onto a '64 Dodge 880 [Re: therocks] #1673532
09/19/14 02:40 PM
09/19/14 02:40 PM
NEW JERSEY
dynamite Offline
dynamite  Offline
NEW JERSEY
Just make it easy for yourself ..DR Diff has kits in stock..don't know for that C body but for my 64 B body everything needed was $ 440.00
Re: Need info on swapping disc brakes onto a '64 Dodge 880 [Re: therocks] #1673533
09/20/14 09:44 AM
09/20/14 09:44 AM
moparx Offline
moparx  Offline
rocky is correct. the 62-64 300,s take a moog k772 upper joint and a k 719 lower joint. both of these are threaded joints with the B body taper. the 60-62 newyorker takes a k772 upper & a k727 lower joint which are also threaded, but are the C body taper.
Re: Need info on swapping disc brakes onto a '64 Dodge 880 [Re: moparx] #1673534
09/20/14 11:55 AM
09/20/14 11:55 AM
Niles , Ohio
therocks Offline
therocks  Offline
Niles , Ohio
I know we went thru it when we ordered the joints for the 62 300.They sent the big ones.Had to send them back and get the smaller ones.Rocky
Chrysler Firepower
