Re: epoxy primer?
[Re: bigblockbryan]
#1672655
09/17/14 05:01 PM
09/17/14 05:01 PM
Posts: 4,848 Memphis
HemiRick
Memphis
filler sticks fine to epoxy primer, epoxy prime do body work and then epoxy again to seal in bondo. Then prime paint.
Take care, Rick 68 Coronet R/T 440 & 68 Charger 528 Hemi,and 5 Challengers! 6 cyl, 318, 360, 383, 451
Re: epoxy primer?
[Re: HemiRick]
#1672656
09/17/14 05:36 PM
09/17/14 05:36 PM
Challenger 1
Cincinnati, Ohio
Exactly, regular epoxy primer first, then bondo and body work. Then you mix the epoxy primer with more/slower reducer in it and seal your body work. Then 2K primer over that and you block sand with the 2K primer. Then you you seal the 2K primer with epoxy mixed as a sealer again right before color.
Re: epoxy primer?
[Re: Challenger 1]
#1672657
09/17/14 08:01 PM
09/17/14 08:01 PM
Posts: 1,305 Lakewood, Colorado
herkamer
Lakewood, Colorado
FYI, there are direct to metal fillers. I use the Evercoat Quantum One and will pass the 500 hr salt spray test. No need to epoxy prime first, it is fortified with epoxy. http://www.evercoat.com/productDetail.aspx?pID=294Time and materials are money...
Matt 69 Dart Swinger 340 83 W350, Megasquirted with 46RH Old news: 72 Demon street/race mobile Latest: 70 Duster backhalf car and even more
Re: epoxy primer?
[Re: Telvis]
#1672659
09/18/14 08:35 AM
09/18/14 08:35 AM
Posts: 2,469 NE Ohio
mopar383
NE Ohio
I agree epoxy first. Then filler ( I just can't call it bondo lol ) Then epoxy over that again
81 Dodge Ram My dad bought brand new... my 17 year old sons project Jeep Wrangler Unlimited .....my wife's baby Durango....my DD Caravan...an awesome parts hauler 72 Dart
Re: epoxy primer?
[Re: Challenger 1]
#1672660
09/18/14 03:03 PM
09/18/14 03:03 PM
Posts: 1,545 Seattle, WA
375inStroke
Special needs person
Seattle, WA
One needs epoxy between filler and 2K primer?
Re: epoxy primer?
[Re: 375inStroke]
#1672661
09/18/14 03:15 PM
09/18/14 03:15 PM
Challenger 1
Cincinnati, Ohio
Yes it's best.
Re: epoxy primer?
[Re: bigblockbryan]
#1672662
09/19/14 12:40 AM
09/19/14 12:40 AM
Posts: 957 Heart of Ohio
4boxers4
Heart of Ohio
filler on metal that has been prepped is how I do it.
Persistance is omnipotent
Durability Engineer, Chair and Couch division...
Re: epoxy primer?
[Re: jughed]
#1672664
09/19/14 12:01 PM
09/19/14 12:01 PM
Posts: 18,582 Rust Belt, SW PA
Silver70
Rust Belt, SW PA
I always go epoxy first. I've stripped putty/regular primer off cars many times and they almost always have rust under both. Neither will seal the metal like epoxy or etch primer. It doesn't have to be expensive either, I use kirker I get labeled as summit or eastwood for under 100 for 2 sprayable gallons.
68 Road Runner, 69 Belvedere, 71 Challenger Vert 340 barracuda, 01 Ram CTD, 95 Ram, 04 Ram, 85 Daytona turbo Z 66 GTO, 06 Magnum RT AWD. 07 Ram CTD, 07 Ram
Re: epoxy primer?
[Re: GeorgeH]
#1672669
09/21/14 10:27 PM
09/21/14 10:27 PM
Posts: 1,212 Canton, Ohio
Crazy68Dart
Canton, Ohio
This is completely irrelevant to this post, but what do brand new cars have on them from the factory? How many coats and of what exactly?
383, Hemi 4-Speed, AlterKtion, D60
