epoxy primer? #1672652
09/17/14 03:19 PM
09/17/14 03:19 PM
United states wisconsin
bigblockbryan Offline OP
okay guys i stripped my car down to bare metal know hopefully in the next week or so i will spray the car in primer heres my question do i have to put primer sealer on right away.Or can it wait a few weeks because i do have to put some filler on the car in a few spots.When you work 60 hours a week theres some days i just dont get out in the shop to work on it as much as id like too.Also what the best thing to wipe the car down with before i spray my cat its pretty much 95 percent bare metal at the moment.
Re: epoxy primer? [Re: bigblockbryan] #1672653
09/17/14 03:32 PM
09/17/14 03:32 PM
Sweden
lynchroad Offline
lynchroad  Offline
Sweden
Epoxy primer before filler, in my opinion
Re: epoxy primer? [Re: lynchroad] #1672654
09/17/14 03:42 PM
09/17/14 03:42 PM
that was my plan, then should I do another layer of primer over filler so it would be epoxy primer do my filler then maybe more epoxy primer.
Re: epoxy primer? [Re: bigblockbryan] #1672655
09/17/14 05:01 PM
09/17/14 05:01 PM
Memphis
HemiRick Offline
HemiRick  Offline
Memphis
filler sticks fine to epoxy primer, epoxy prime do body work and then epoxy again to seal in bondo. Then prime paint.
Take care,
Rick
68 Coronet R/T 440 & 68 Charger 528 Hemi,and 5 Challengers! 6 cyl, 318, 360, 383, 451
Re: epoxy primer? [Re: HemiRick] #1672656
09/17/14 05:36 PM
09/17/14 05:36 PM
Cincinnati, Ohio
Challenger 1 Offline
Cincinnati, Ohio
Exactly, regular epoxy primer first, then bondo and body work. Then you mix the epoxy primer with more/slower reducer in it and seal your body work. Then 2K primer over that and you block sand with the 2K primer. Then you you seal the 2K primer with epoxy mixed as a sealer again right before color.
Re: epoxy primer? [Re: Challenger 1] #1672657
09/17/14 08:01 PM
09/17/14 08:01 PM
Lakewood, Colorado
herkamer Offline
herkamer  Offline
Lakewood, Colorado
FYI, there are direct to metal fillers.
I use the Evercoat Quantum One and will pass the 500 hr salt spray test. No need to epoxy prime first, it is fortified with epoxy.
http://www.evercoat.com/productDetail.aspx?pID=294
Time and materials are money...
Matt
69 Dart Swinger 340
83 W350, Megasquirted with 46RH
Old news: 72 Demon street/race mobile
Latest: 70 Duster backhalf car
and even more
Re: epoxy primer? [Re: herkamer] #1672658
09/17/14 09:16 PM
09/17/14 09:16 PM
KY
Telvis Offline
Telvis  Offline
KY
Epoxy primer first
That's King Weenie to you!
Re: epoxy primer? [Re: Telvis] #1672659
09/18/14 08:35 AM
09/18/14 08:35 AM
NE Ohio
mopar383 Offline
mopar383  Offline
NE Ohio
I agree epoxy first. Then filler ( I just can't call it bondo lol ) Then epoxy over that again
81 Dodge Ram My dad bought brand new... my 17 year old sons project
Jeep Wrangler Unlimited .....my wife's baby
Durango....my DD
Caravan...an awesome parts hauler
72 Dart
Re: epoxy primer? [Re: Challenger 1] #1672660
09/18/14 03:03 PM
09/18/14 03:03 PM
Seattle, WA
3
375inStroke Offline
Special needs person
375inStroke  Offline
3
Seattle, WA
One needs epoxy between filler and 2K primer?
Re: epoxy primer? [Re: 375inStroke] #1672661
09/18/14 03:15 PM
09/18/14 03:15 PM
Cincinnati, Ohio
Cincinnati, Ohio
Yes it's best.
Re: epoxy primer? [Re: bigblockbryan] #1672662
09/19/14 12:40 AM
09/19/14 12:40 AM
Heart of Ohio
4boxers4 Offline
4boxers4  Offline
Heart of Ohio
filler on metal that has been prepped is how I do it.
Persistance is omnipotent Durability Engineer, Chair and Couch division...
Re: epoxy primer? [Re: 4boxers4] #1672663
09/19/14 08:39 AM
09/19/14 08:39 AM
In The Hills
jughed Offline
jughed  Offline
In The Hills
can seam sealer be applied over epoxy primer???
Re: epoxy primer? [Re: jughed] #1672664
09/19/14 12:01 PM
09/19/14 12:01 PM
Rust Belt, SW PA
Silver70 Offline
Silver70  Offline
Rust Belt, SW PA
I always go epoxy first. I've stripped putty/regular primer off cars many times and they almost always have rust under both. Neither will seal the metal like epoxy or etch primer. It doesn't have to be expensive either, I use kirker I get labeled as summit or eastwood for under 100 for 2 sprayable gallons.
68 Road Runner, 69 Belvedere, 71 Challenger Vert
340 barracuda, 01 Ram CTD, 95 Ram, 04 Ram, 85 Daytona turbo Z
66 GTO, 06 Magnum RT AWD. 07 Ram CTD, 07 Ram
Re: epoxy primer? [Re: jughed] #1672665
09/19/14 10:14 PM
09/19/14 10:14 PM
Southeast PA
5wndwcpe Offline
5wndwcpe  Offline
Southeast PA
Yes.
1968 GTX hardtop
1968 Sport Satellite Convertible 383/4spd
1933 Plymouth coupe
2002 Ram 2500 oil burner 4x4
2015 Grand Cherokee
2013 Challenger
1957 Chrysler Saratoga
Man...I need a bigger freakin' garage.
Re: epoxy primer? [Re: 5wndwcpe] #1672666
09/20/14 12:59 AM
09/20/14 12:59 AM
ill
dennismopar73 Offline
ill
I never put a 2k primer over a catalyzed product a chemical reaction
Can and does happen
Re: epoxy primer? [Re: HemiRick] #1672667
09/20/14 01:02 AM
09/20/14 01:02 AM
Tacoma, Washington USA
Adam71Charger Offline
x2
Re: epoxy primer? [Re: Adam71Charger] #1672668
09/21/14 09:29 PM
09/21/14 09:29 PM
Delaware
GeorgeH Offline
GeorgeH  Offline
Delaware
Most epoxy primers I have used require an etch primer first as they are not DTM primers. Check the tech sheets for whichever brand you use to see if its necessary.
Re: epoxy primer? [Re: GeorgeH] #1672669
09/21/14 10:27 PM
09/21/14 10:27 PM
Canton, Ohio
Crazy68Dart Offline
Crazy68Dart  Offline
Canton, Ohio
This is completely irrelevant to this post, but what do brand new cars have on them from the factory? How many coats and of what exactly?
383, Hemi 4-Speed, AlterKtion, D60
