Engine Balance question -440 External balance #1672483
09/17/14 12:56 AM
09/17/14 12:56 AM
Southern Alberta
Uberpube Offline OP
Uberpube  Offline OP
Southern Alberta
I have a good running 440 I screwed together years ago, its a 77 block, with l2266f .030 pistons. So when I first got that motor I used it with a stock 440 truck flywheel, then I rebuilt it, and the machine shop balanced it with the flywheel, and they drilled the flywheel in a couple of spots to correct the balance with the l2266f pistons.
So now I want to move that motor to my 77 Ramcharger, that is automatic, is there a way to match some converter weights to what was done to the flywheel?
Re: Engine Balance question -440 External balance [Re: Uberpube] #1672484
09/17/14 04:03 AM
09/17/14 04:03 AM
Tom65 Offline
Tom65  Offline
don't quote me but I think the fluid in the converter will be the balance. I would call a good trans shop like monster transmision.
Re: Engine Balance question -440 External balance [Re: Tom65] #1672485
09/17/14 04:14 AM
09/17/14 04:14 AM
SE PA
Yellow Fever Offline
SE PA
Is the machine shop still there? Maybe they can spin the flywheel up and see how much weight and where would be needed either on a flex plate so you can use a neutral convertor or right on the convertor?
Re: Engine Balance question -440 External balance [Re: Yellow Fever] #1672486
09/17/14 12:36 PM
09/17/14 12:36 PM
Chilliwack B.C. Canada
RUNCHARGER Offline
RUNCHARGER  Offline
Get a B&M flexplate and have the machine shop balance it the same as the flywheel, then use a neutral balance convertor.
Sheldon
Re: Engine Balance question -440 External balance [Re: RUNCHARGER] #1672487
09/19/14 12:43 AM
09/19/14 12:43 AM
Southern Alberta
Uberpube Offline OP
Uberpube  Offline OP
Southern Alberta
The machine shop that did the work originally is long gone.. I stopped into an another shop and asked if they could balance the flexplate, they are saying they need to knock the motor apart and rebalance the whole thing. If thats the case, I probably wouldnt put it back together with the l2266f's. I'll try another shop tomorrow.
Re: Engine Balance question -440 External balance [Re: Uberpube] #1672488
09/20/14 01:43 PM
09/20/14 01:43 PM
God's Country Maryland
GODSCOUNTRY340 Offline
The second shop is correct. Without knowing the original bob- weight used for the balance there's no way they can correctly balance it without taking it apart to get the actual weights.
Re: Engine Balance question -440 External balance [Re: RUNCHARGER] #1672489
09/20/14 02:40 PM
09/20/14 02:40 PM
Pangaea
B5 Bee Offline
B5 Bee  Offline
Pangaea
Sheldon
I agree.
There should be enough material in the B&M plate to drill enough holes to achieve the same off balance as the flywheel.
Re: Engine Balance question -440 External balance [Re: B5 Bee] #1672490
09/21/14 09:56 AM
09/21/14 09:56 AM
Right here
HP2 Offline
HP2  Offline
Right here
I have a solution for this, I had exactly the same problem with a 360 in my 70 Cuda. You can find the thread if you click my username.
Put the flywheel up in a wheel balancing machine and you will find out how much and where it has been balanced. Weld the same weight on the opposite side (180 degrees) on your zero balanced converter and you will be fine.
It is important that you have about the same distance from the center, so measure the converter first so you know what distance you should use when you put the weights on when you zero balance your flywheel. Good luck
Wow - hope you understand!
70 W100 Power Wagon. 318 4-spd
70 Sport Fury 440 2dr HT
71 Duster 340
71 Charger Super Bee - 383/727
72 Charger "Sabotage" - 440/727 - Street/Strip
78 Warlock in beautiful patina
Re: Engine Balance question -440 External balance [Re: B5 Bee] #1672491
09/21/14 01:02 PM
09/21/14 01:02 PM
Prospect, PA
BSB67 Offline
BSB67  Offline
Prospect, PA
Sheldon
I agree.
Re: Engine Balance question -440 External balance [Re: BSB67] #1672492
09/21/14 11:32 PM
09/21/14 11:32 PM
Downtown Roebuck Ont
Twostick Offline
Still wishing...
Twostick  Offline
Still wishing...
Does this thing still have the the 6 pak rods in it?
Any chance the shop was just correcting the flywheel to zero?
Kevin
Re: Engine Balance question -440 External balance [Re: Twostick] #1672493
09/22/14 12:52 AM
09/22/14 12:52 AM
Pangaea
B5 Bee Offline
B5 Bee  Offline
Pangaea
Kevin
Ext bal isn't for six pack rods, it's a '77 cast crank motor.
I assume the pistons are lighter than OEM and the shop removed weight from the flywheel to make up for it.
The wheel balancer idea won't work. It only will tell you the degree angle and how much weight to add, you also need to know how far from the crank centerline to place it.
