Re: Engine Balance question -440 External balance
[Re: Uberpube]
#1672488
09/20/14 01:43 PM
09/20/14 01:43 PM
Posts: 2,504 God's Country Maryland
GODSCOUNTRY340
The second shop is correct. Without knowing the original bob- weight used for the balance there's no way they can correctly balance it without taking it apart to get the actual weights.
[Re: RUNCHARGER]
#1672489
09/20/14 02:40 PM
09/20/14 02:40 PM
Posts: 8,020 Pangaea
B5 Bee
Pangaea
Get a B&M flexplate and have the machine shop balance it the same as the flywheel, then use a neutral balance convertor.
Sheldon
I agree. There should be enough material in the B&M plate to drill enough holes to achieve the same off balance as the flywheel.
[Re: B5 Bee]
#1672490
09/21/14 09:56 AM
09/21/14 09:56 AM
Posts: 523 Right here
HP2
Right here
I have a solution for this, I had exactly the same problem with a 360 in my 70 Cuda. You can find the thread if you click my username. Put the flywheel up in a wheel balancing machine and you will find out how much and where it has been balanced. Weld the same weight on the opposite side (180 degrees) on your zero balanced converter and you will be fine. It is important that you have about the same distance from the center, so measure the converter first so you know what distance you should use when you put the weights on when you zero balance your flywheel. Good luck Wow - hope you understand!
70 W100 Power Wagon. 318 4-spd 70 Sport Fury 440 2dr HT 71 Duster 340 71 Charger Super Bee - 383/727 72 Charger "Sabotage" - 440/727 - Street/Strip 78 Warlock in beautiful patina
[Re: B5 Bee]
#1672491
09/21/14 01:02 PM
09/21/14 01:02 PM
Posts: 4,313 Prospect, PA
BSB67
Prospect, PA
Sheldon
[Re: Twostick]
#1672493
09/22/14 12:52 AM
09/22/14 12:52 AM
B5 Bee
Pangaea
Does this thing still have the the 6 pak rods in it?
Any chance the shop was just correcting the flywheel to zero?
Kevin
Ext bal isn't for six pack rods, it's a '77 cast crank motor. I assume the pistons are lighter than OEM and the shop removed weight from the flywheel to make up for it.
The wheel balancer idea won't work. It only will tell you the degree angle and how much weight to add, you also need to know how far from the crank centerline to place it.
