Am I screwed or is it fixable? #1672193
09/16/14 01:50 PM
09/16/14 01:50 PM
Goodyear Arizona
midnite360 Offline OP
Goodyear Arizona
I am rebuilding the front end in my 77 D100. The cam bolts on the Upper Control Arms where about welded in place they were so stuck. I ended up tearing up the metel around the Cam bolt which would be for the caster adjustments I am assuming. Is there an after market fix for this..? Or will I be ok to bolt everything up and having to live with suspension alighments being a nightmare?
Re: Am I screwed or is it fixable? [Re: midnite360] #1672194
09/16/14 11:44 PM
09/16/14 11:44 PM
Southeast Pa.
SALEM1912 Offline
SALEM1912  Offline
Southeast Pa.
Are you talking about the ears that the cams would rub against to get the arm to move in and out? If so a good alignment shop could work around this problem to get the truck in align.
Re: Am I screwed or is it fixable? [Re: midnite360] #1672195
09/17/14 01:31 AM
09/17/14 01:31 AM
Freeport IL USA
poorboy Offline
poorboy  Offline
Freeport IL USA
As long as the "ear" is structurally sound, you should be OK.
If your real concerned, the little cam stops are not that hard to fabricate and weld into place. Gene
Re: Am I screwed or is it fixable? [Re: poorboy] #1672196
09/17/14 03:55 PM
09/17/14 03:55 PM
Goodyear Arizona
Goodyear Arizona
Thanks guys, I will let it roll and find a good alignment shop. If it doesn't workout I will fan up the cam stops, ears, or what ever the tern is for them... The mounts themselves are structurally sound... Just the stops are broken into off.
Re: Am I screwed or is it fixable? [Re: midnite360] #1672197
09/17/14 04:01 PM
09/17/14 04:01 PM
Back home in PA
BulletBob Offline
BulletBob  Offline
Back home in PA
Make them as straight as possible & run a bead or two with a welder on the back sides
That's how my buddy who used to roundy round our style of trucks used to do as part of chassis prep
Helps keep the wheels lined better after a wreck
