Page 1 of 3 1 2 3
Crankshaft Grinding #1672065
09/16/14 10:35 AM
09/16/14 10:35 AM
ILL
MLR426 Offline OP
MLR426  Offline OP
ILL
Who is grinding crankshafts in your area auto, diesel or industrial ??
MLR426
Re: Crankshaft Grinding [Re: MLR426] #1672066
09/16/14 11:42 AM
09/16/14 11:42 AM
IL
E
EchoSixMike Offline
EchoSixMike  Offline
E
IL
I know a place south Chicago suburbs, where are you in IL? S/F....Ken M
Re: Crankshaft Grinding [Re: EchoSixMike] #1672067
09/16/14 12:29 PM
09/16/14 12:29 PM
ILL
MLR426 Offline OP
MLR426  Offline OP
ILL
Ken,
I'm 1 hour straight east of St Louis, Odin, IL
I'm trying to find out where people get there cranks ground around the country.
Thanks MLR 426 Martin Wimberly
Re: Crankshaft Grinding [Re: MLR426] #1672068
09/16/14 02:05 PM
09/16/14 02:05 PM
dogdays Offline
dogdays  Offline
In Phoenix there's a guy advertising custom crank grinding called Kadrie's Kranks. I've spoken to him a couple of times about some odd jobs, never actually did any business with the guy. Anyone else ever visit or buy?
R.
Re: Crankshaft Grinding [Re: MLR426] #1672069
09/16/14 03:05 PM
09/16/14 03:05 PM
Marine Crankshafts, mild to wild on most any racing or stock cranks David is the owner, he worked for Sonny Bryant, Bryant Racing Crankshafts, for many years before opening his own shop. His work ethics and quality control are outstanding in my humble opinion I had a crankshaft that was hurt, Crower 4.25 stroke old top fuel crank with center counterweighrs and Mopar rod journal sizes. The motor broke number 1 rod and hurt that journal more than a little, I had him mag and then repair that journal as well as offset grind all the rod journals to 2.200 rod size and increase the stroke to 4.375 His shop is in Santa Ana, CA 714-549-2388
Re: Crankshaft Grinding [Re: MLR426] #1672070
09/16/14 03:09 PM
09/16/14 03:09 PM
STL
cdstl Offline
cdstl  Offline
STL
Don Kulash was going to send mine to someone in Effingham 3 years ago. I think you stopped into Don's machine shop in Granite.
1972 Cuda 340 4 speed, 2001 Ram CTD 4x4 6 speed, 1970 Duster 408 4 speed, 1996 Ram 5.9 2x4 auto, 1965 Coronet 500
Re: Crankshaft Grinding [Re: MLR426] #1672071
09/16/14 03:38 PM
09/16/14 03:38 PM
Pennsylvania
W
WingedSixBBL Offline
W
Pennsylvania
Re: Crankshaft Grinding [Re: Cab_Burge] #1672072
09/16/14 04:05 PM
09/16/14 04:05 PM
ILL
MLR426 Offline OP
MLR426  Offline OP
ILL
Yes I agree and I have done business with them for years and sold many crank grinding wheels to them. Top notch business for sure.
MLR426
Re: Crankshaft Grinding [Re: cdstl] #1672073
09/16/14 04:08 PM
09/16/14 04:08 PM
ILL
MLR426 Offline OP
MLR426  Offline OP
ILL
Yes Chuck I have been to Don's shop since he moved and the shop in Effingham is Effingham Regrinders and I use them, Dean and Art are great people. They are 45 miles north of me. Reminder my Mopar Family Reunion Picnic is Saturday the 20th come on out.
MLR426
Re: Crankshaft Grinding [Re: WingedSixBBL] #1672074
09/16/14 04:11 PM
09/16/14 04:11 PM
ILL
MLR426 Offline OP
MLR426  Offline OP
ILL
http://rcgcncblocks.com/
yes, I've heard of them as well in Warriors Mark, Pa
MLR426
Re: Crankshaft Grinding [Re: MLR426] #1672075
09/16/14 05:08 PM
09/16/14 05:08 PM
Portage,michigan
B3422W5 Offline
B3422W5  Offline
Portage,michigan
Performance crankshaft in Detroit does exceptional crank work. Adney Brown is the owner. Does a lot of engine masters stuff as well
Best so far, low 10.30’s 1/4
1.41 best 60 foot
6.56 at 104.17
Re: Crankshaft Grinding [Re: MLR426] #1672076
09/17/14 08:58 AM
09/17/14 08:58 AM
IL
E
EchoSixMike Offline
EchoSixMike  Offline
E
IL
Ken,
Calumet Lift Truck Services Co - Engine Rebuild Center, South Holland IL (708) 339-2150
S/F....Ken M
Re: Crankshaft Grinding [Re: MLR426] #1672077
09/17/14 09:42 AM
09/17/14 09:42 AM
Cincinnati, Ohio
Challenger 1 Offline
Cincinnati, Ohio
This is who I have repair my bryant cranks. web page
This place has been in business around here forever, although I don't recommend them.
web page
There's another shop I used for my street cars here in Delhi Ohio, suburb of Cincy. I can't think of his name as he flys under the radar. Matter of fact I'm pretty sure all the local shops around here use him to grind there cranks, maybe even Don's.
Re: Crankshaft Grinding [Re: Challenger 1] #1672078
09/18/14 12:02 PM
09/18/14 12:02 PM
ILL
MLR426 Offline OP
MLR426  Offline OP
ILL
Thanks guys keep them coming.
Yes Gary the guys at Bryant do very good work and they also supply many top fuel teams and Winberg Crank Denver supplies fuel teams as well.
MLR426
Re: Crankshaft Grinding [Re: MLR426] #1672079
09/18/14 06:55 PM
09/18/14 06:55 PM
S. Il. U.S.A.
5spdcuda Offline
5spdcuda  Offline
S. Il. U.S.A.
I use Mark Schaefer at Belleville Automotive. Mark has lots of circle track experience as well as drag,street and stock applications. I am not sure if Mullins in Mt.Olive does cranks, but I know a lot of circle track people use their machine shop services. Sorry I can't make it to the reunion this year Martin, schedule conflict. Your efforts are genuinely appreciated.
Re: Crankshaft Grinding [Re: 5spdcuda] #1672080
09/19/14 10:35 AM
09/19/14 10:35 AM
ILL
MLR426 Offline OP
MLR426  Offline OP
ILL
But Hugh you knew about the date a year in advance Cancel and come out. Mark is a bit of an irrogrant butt head and Chad Mullins doesn't do cranks.
MLR426
Re: Crankshaft Grinding [Re: MLR426] #1672081
09/19/14 12:16 PM
09/19/14 12:16 PM
Columbia, CT
moper Offline
moper  Offline
Columbia, CT
Rick "Smiley" Smilnac - Crankshafts Incorporated - Berlin CT
Re: Crankshaft Grinding [Re: moper] #1672082
09/22/14 05:03 PM
09/22/14 05:03 PM
ILL
MLR426 Offline OP
MLR426  Offline OP
ILL
Thank you and I need more people to get involved with this lead producing idear
MLR426
Re: Crankshaft Grinding [Re: MLR426] #1672083
09/22/14 05:26 PM
09/22/14 05:26 PM
Medford OR
FrankenScamp Offline
Medford OR
Around here all the machine shops send their crank grinding to Keller Motor Supply.
John Keller has been in business for quite some time and has a great reputation.
Re: Crankshaft Grinding [Re: FrankenScamp] #1672084
09/22/14 07:52 PM
09/22/14 07:52 PM
Joplin, Mo
rt66jim Offline
rt66jim  Offline
Joplin, Mo
Is Crankshaft Specialist in Memphis any good?
Page 1 of 3 1 2 3
