Re: Crankshaft Grinding
[Re: EchoSixMike]
#1672067
09/16/14 12:29 PM
09/16/14 12:29 PM
Posts: 4,799 ILL
MLR426
ILL
Ken,
I'm 1 hour straight east of St Louis, Odin, IL I'm trying to find out where people get there cranks ground around the country.
Thanks MLR 426 Martin Wimberly
[Re: MLR426]
#1672069
09/16/14 03:05 PM
09/16/14 03:05 PM
Posts: 43,301 Bend,OR USA
Cab_Burge
Marine Crankshafts, mild to wild on most any racing or stock cranks David is the owner, he worked for Sonny Bryant, Bryant Racing Crankshafts, for many years before opening his own shop. His work ethics and quality control are outstanding in my humble opinion I had a crankshaft that was hurt, Crower 4.25 stroke old top fuel crank with center counterweighrs and Mopar rod journal sizes. The motor broke number 1 rod and hurt that journal more than a little, I had him mag and then repair that journal as well as offset grind all the rod journals to 2.200 rod size and increase the stroke to 4.375 His shop is in Santa Ana, CA 714-549-2388
[Re: MLR426]
#1672070
09/16/14 03:09 PM
09/16/14 03:09 PM
Posts: 1,487 STL
cdstl
STL
Don Kulash was going to send mine to someone in Effingham 3 years ago. I think you stopped into Don's machine shop in Granite.
1972 Cuda 340 4 speed, 2001 Ram CTD 4x4 6 speed, 1970 Duster 408 4 speed, 1996 Ram 5.9 2x4 auto, 1965 Coronet 500
[Re: Cab_Burge]
#1672072
09/16/14 04:05 PM
09/16/14 04:05 PM
Posts: 4,799 ILL
MLR426
ILL
Yes I agree and I have done business with them for years and sold many crank grinding wheels to them. Top notch business for sure.
MLR426
[Re: MLR426]
#1672075
09/16/14 05:08 PM
09/16/14 05:08 PM
Posts: 11,728 Portage,michigan
B3422W5
Portage,michigan
Performance crankshaft in Detroit does exceptional crank work. Adney Brown is the owner. Does a lot of engine masters stuff as well
[Re: MLR426]
#1672076
09/17/14 08:58 AM
09/17/14 08:58 AM
Posts: 494 IL
EchoSixMike
IL
Ken,
Calumet Lift Truck Services Co - Engine Rebuild Center, South Holland IL (708) 339-2150
S/F....Ken M
[Re: MLR426]
#1672077
09/17/14 09:42 AM
09/17/14 09:42 AM
Challenger 1
Cincinnati, Ohio
This is who I have repair my bryant cranks. web pageThis place has been in business around here forever, although I don't recommend them. web page There's another shop I used for my street cars here in Delhi Ohio, suburb of Cincy. I can't think of his name as he flys under the radar. Matter of fact I'm pretty sure all the local shops around here use him to grind there cranks, maybe even Don's.
[Re: Challenger 1]
#1672078
09/18/14 12:02 PM
09/18/14 12:02 PM
Posts: 4,799 ILL
MLR426
ILL
Thanks guys keep them coming.
Yes Gary the guys at Bryant do very good work and they also supply many top fuel teams and Winberg Crank Denver supplies fuel teams as well.
MLR426
[Re: 5spdcuda]
#1672080
09/19/14 10:35 AM
09/19/14 10:35 AM
Posts: 4,799 ILL
MLR426
ILL
I use Mark Schaefer at Belleville Automotive. Mark has lots of circle track experience as well as drag,street and stock applications. I am not sure if Mullins in Mt.Olive does cranks, but I know a lot of circle track people use their machine shop services. Sorry I can't make it to the reunion this year Martin, schedule conflict. Your efforts are genuinely appreciated.
But Hugh you knew about the date a year in advance Cancel and come out. Mark is a bit of an irrogrant butt head and Chad Mullins doesn't do cranks.
MLR426
[Re: MLR426]
#1672081
09/19/14 12:16 PM
09/19/14 12:16 PM
Posts: 12,675 Columbia, CT
moper
Columbia, CT
Rick "Smiley" Smilnac - Crankshafts Incorporated - Berlin CT
