Pics of Cal Tracs on small tire Cuda's #1671780
09/16/14 12:06 AM
09/16/14 12:06 AM
N. Of Detroit, Mi
733404spdCuda Offline OP
N. Of Detroit, Mi
Well I just installed a nice stroker small block (520 hp) in my Cuda and thinking of installing a Cal Track set up.. I plan on running a 275 Drag Radial, the car will see a lot of street use and I like the current ride height, maybe an inch and a half higher in the rear
My concern is the stance so I'm looking for pics of Cuda's running Cal tracks with a small tire.
Re: Pics of Cal Tracs on small tire Cuda's [Re: 733404spdCuda] #1671781
09/16/14 01:16 AM
09/16/14 01:16 AM
Taxes & Virus's R-US, NY
Dragula Offline
Dragula  Offline
Well, I don't want to shoot your idea down on your stance, but Mopars like a bit of rake to make them hook and I can prove it...
We have a 69 a-body with a hemi and a 10x29.5 slick on it. Obviously bigger than a 275, but the point is the same. We had to raise it to almost level due to the oil pan sheering off the drain bolt the other week. This was not good for the 60ft as it went to heck on our 20 year old slicks.
Zoom forward two weeks. We had a new pan made with a kick out that was a lot shorter and held even more oil...Dropped the front down a bunch. If I had to guess, the car has 5" of rake to it....Now it does wheelies!
Either way here are my Cuda's and their stances...
Sold this one...Had 275's on it...Hated them. Probably needed more rake as the 275's were shorter than the slicks it used to run, and the 1.58 60ft was done torching them all the way to second gear.
My 70 with big tires and Caltrac's and mono's..hooks in a car wash, almost. so far a 1.48 60ft.
Re: Pics of Cal Tracs on small tire Cuda's [Re: Dragula] #1671782
09/16/14 01:43 AM
09/16/14 01:43 AM
MR_P_BODY Offline
MR_P_BODY  Offline
And I would bet that it hooked better was because you
gave the front end more travel.. not the rake angle
Re: Pics of Cal Tracs on small tire Cuda's [Re: 733404spdCuda] #1671783
09/16/14 02:11 AM
09/16/14 02:11 AM
Puyallup, WA
StealthWedge67 Offline
Puyallup, WA
Are you considering the whole setup? If you're just bolting the bars onto existing springs, you won't change anything. When you put preload into them, you might raise up a hair, but I've never really noticed a difference. If you go to Calvert's split mono springs, they offer them in -1"; 0 and +1" versions, so you can get the stance you want out of them.
Re: Pics of Cal Tracs on small tire Cuda's [Re: 733404spdCuda] #1671784
09/16/14 10:13 AM
09/16/14 10:13 AM
an8sec70cuda Offline
Here's mine w/ a 295-65 radial. I have 275-60s on it now, but don't have any pics of it.
CHIP
'06 GMC 2500HD LBZ Duramax
Re: Pics of Cal Tracs on small tire Cuda's [Re: an8sec70cuda] #1671785
09/16/14 10:14 AM
09/16/14 10:14 AM
Another. These are with stock ride height monoleaf springs from Calvert.
CHIP
Re: Pics of Cal Tracs on small tire Cuda's [Re: StealthWedge67] #1671786
09/16/14 10:45 AM
09/16/14 10:45 AM
northern,Ohio,USA
Clanton Offline
Clanton  Offline
northern,Ohio,USA
I got my Cals direct from Calvert and they said I could keep my multi leaf springs if I liked my ride height and the bars would work as they should.I have not been down track yet tho.
Re: Pics of Cal Tracs on small tire Cuda's [Re: Clanton] #1671787
09/16/14 02:19 PM
09/16/14 02:19 PM
Motor City
6PKRTSE Offline
6PKRTSE  Offline
Motor City
Not a Cuda but still an E Body. Here is my Challenger with a -1" lower than stock ride height. No drivetrain, glass or interior in it currently so it is still sitting up a little high.
1963 Belvedere 440 Max Wedge Tribute
1970 Charger R/T S.E. 440 Six Pack
1970 Challenger R/T, 528 Hemi
1970 Charger 500 S.E. 440 4 BBL
1970 Plymouth Road Runner 383
1974 Chrysler New Yorker 440
1996 2500 RAM 488 V-10 4X4
2004 3500 Dually Cummins 4x4
2012 Challenger R/T Classic.
Re: Pics of Cal Tracs on small tire Cuda's [Re: MR_P_BODY] #1671788
09/16/14 02:41 PM
09/16/14 02:41 PM
Dragula Offline
Dragula  Offline
No doubt...They need travel up front to get the weight transfered. So many people only look at the rear of the car. Most will tell you that you need at least 5" of front travel to make it work. I have done it with less, but 5" seems to be the number up front.
Another area people over look is the travel...Always making sure front and rear's your not bottoming the shocks themselves. I had this on the rear of my Cuda...Made a new hole for the upper rear shocks so they show more of the rod exposed while full weight is on it and it instantly responded the next time out.
Stock suspension can work very well with some attention to detail.
Re: Pics of Cal Tracs on small tire Cuda's [Re: 733404spdCuda] #1671789
09/16/14 11:38 PM
09/16/14 11:38 PM
St. Louis, MO
Blues_Cuda Offline
Blues_Cuda  Offline
St. Louis, MO
That is a very sharp 'Cuda you have.
Here is a picture of my wife's Barracuda with Caltracs with stock ride height monoleafs and a 295/65 tire on an 8" rim.
Re: Pics of Cal Tracs on small tire Cuda's [Re: Blues_Cuda] #1671790
09/16/14 11:45 PM
09/16/14 11:45 PM
St. Louis, MO
Blues_Cuda Offline
Blues_Cuda  Offline
St. Louis, MO
...same car with 28/10.5 ET Streets and 28" Hoosier front tires. Rear tires look rather small in conjunction with the B-body rear.
An 8" rear wheel with the same 4.5" offset as the Magnum 500s. Some day I'll concentrate on looking for the matching Monocoque wheels for the rear.
Re: Pics of Cal Tracs on small tire Cuda's [Re: Blues_Cuda] #1671791
09/17/14 02:32 PM
09/17/14 02:32 PM
N. Of Detroit, Mi
N. Of Detroit, Mi
Guys
Thanks for all the pics and advice, some beautiful E-Bodies!
I think I'm going with the stock ride height mono leaf
Cant wait until next years Monster Mopar Weekend at Norwalk, should have the Cuda dialed in by then
