Found a not so "factory" cup holder for my truck.......
#1671232
09/15/14 01:52 PM
09/15/14 01:52 PM
Posts: 8,087 Elk Grove, Calif.
bigblock340power
Elk Grove, Calif.
Took it out of a '78-9 Dodge crew cab truck. It bolted directly to the front of the seat using two strange looking "slip on for the cup holder" bolts. The bolts will screw directly into the center buddy seat storage box metal, then the cup holder assembly slips right on them. The unit (cup holder) never touches the carpet. Very sturdy unit. It was blue, so I prepped it, and shot it in semi-white/parchment color. Question: should I use it, or leave it alone? I can always take it out if I get tired of it some time. After which, you'd never know it was in there. Here's two pics (I should get pics of the attaching bolts too I guess). ![](http://i51.photobucket.com/albums/f355/duster416/Cupholder003_zps47d2f5ed.jpg) ![](http://i51.photobucket.com/albums/f355/duster416/Cupholder001_zpsd9c7d8ac.jpg) Ok, here's the bolts ![](http://i51.photobucket.com/albums/f355/duster416/Cupholderattachingbolts_zpsed1291e7.jpg)
Re: Found a "factory" cup holder for my truck..............
[Re: adventurer]
#1671235
09/16/14 12:06 AM
09/16/14 12:06 AM
bigblock340power
Elk Grove, Calif.
Thats cool never seen one, does it say Chrysler on it? If I found 1 I'd use it. Looks great in there with those parchment seats.
Yeah, it's factory. I guess what the heck! I'll install it. If someone is using the buddy seat, all I have to do is pop it off the two mounting studs, and store it in the back of the seats. It's got a metal inner shell that the plastic is bradded to. It's even got a little cubby area in front for napkins, maps, or ?.
[Re: bigblock340power]
#1671238
09/16/14 07:04 AM
09/16/14 07:04 AM
Posts: 3,266 Pyeongtaek, South Korea
69HemiGTX
Sweet! Do you think that would work with a regular bench seat? I'll have to keep my eyes peeled for one in the future.
OIF V and OEF X veteran and proud of it!
[Re: dynotune440]
#1671239
09/16/14 07:24 AM
09/16/14 07:24 AM
bigblock340power
Elk Grove, Calif.
Mopar part number, inquiring minds wanna know..
I guess I spoke to soon. After all the inquiries, I really took a good look at the inside of the unit. I had to get a flashlight and look way up inside to see any ID. Sorry folks, it's a Ford unit. But I did pull it from a Dodge truck! Sure looked like it belonged in there, and fooled me. Same color interior and everything! So! Now that we know who made it, the question still stands. Should I use it, or not? I guess I could make up some kind of home made cup holder to put in instead of this. At least it would be made not by ma Mopar, but a Mopar fanatic! ![](/ubbthreads/images/graemlins/laugh2.gif)
[Re: adventurer]
#1671241
09/16/14 01:06 PM
09/16/14 01:06 PM
bigblock340power
Elk Grove, Calif.
I'd still use it. No one will know the difference but us here on the truck section
But these are the opinions that mean the most to me !!!
[Re: dynotune440]
#1671245
09/17/14 01:02 AM
09/17/14 01:02 AM
bigblock340power
Elk Grove, Calif.
As long as there is not a Ford blue oval on it I would use it.
Nah, any Ford ID is tucked way up inside the unit. Unseen till you turn it over. Even then you really have to look for it. ![](/ubbthreads/images/graemlins/scope.gif)
[Re: poorboy]
#1671247
09/18/14 11:18 AM
09/18/14 11:18 AM
Posts: 1,357 central Florida
VL21
central Florida
Poking around in a u pull it one day I spotted a factory looking, in dash cup holder in a D150 ... The PO had taken what appeared to be a 1st gen Dakota slide out cup holder, and cut an opening in the dash, IIRC near (maybe above?) the glove box, and installed it into the dash. Looked OK, and appeared to work OK, but I think what made it work was that it was a non air truck, AC trucks have duct work in that area. Kind of a long reach for the driver ... ![](/ubbthreads/images/graemlins/shruggy.gif)
It takes gasoline to interest me.
