Found a not so "factory" cup holder for my truck....... #1671232
09/15/14 01:52 PM
09/15/14 01:52 PM
Elk Grove, Calif.
bigblock340power Offline OP
Elk Grove, Calif.
Took it out of a '78-9 Dodge crew cab truck. It bolted directly to the front of the seat using two strange looking "slip on for the cup holder" bolts. The bolts will screw directly into the center buddy seat storage box metal, then the cup holder assembly slips right on them. The unit (cup holder) never touches the carpet. Very sturdy unit. It was blue, so I prepped it, and shot it in semi-white/parchment color. Question: should I use it, or leave it alone? I can always take it out if I get tired of it some time. After which, you'd never know it was in there.
Here's two pics (I should get pics of the attaching bolts too I guess).
Ok, here's the bolts
Re: Found a "factory" cup holder for my truck.............. [Re: bigblock340power] #1671233
09/15/14 06:13 PM
09/15/14 06:13 PM
Crockett ,TX
9
98RAM1500 Offline
98RAM1500  Offline
Crockett ,TX
hell id use it , I always wished they had cup holders for the 93-earlier trucks I been looking for some kind of cupholder for my 84 when it gets finished bout the only thing I can find is the unit LMC truck has that uses the seat belt to help hold it firmly to the bench seat with console storage.
Re: Found a "factory" cup holder for my truck.............. [Re: 98RAM1500] #1671234
09/15/14 09:49 PM
09/15/14 09:49 PM
It's beer:30 somewhere
adventurer Offline
adventurer  Offline
Thats cool never seen one, does it say Chrysler on it? If I found 1 I'd use it. Looks great in there with those parchment seats.
77 Dodge Adventurer SE 440 2wd SWB
78 Dodge Adventurer SE 440 2wd Utiline
90 Dodge D150 SWB 2wd 318fi 4speed
60 Desoto Adventurer 2dr
67 Dodge Dart Gt Conv. 273 4bbl
04 PT Cruiser GT Turbo
14 Ram R/T
"Life's to short to drink cheap beer."
Re: Found a "factory" cup holder for my truck.............. [Re: adventurer] #1671235
09/16/14 12:06 AM
09/16/14 12:06 AM
Elk Grove, Calif.
Elk Grove, Calif.
Yeah, it's factory. I guess what the heck! I'll install it. If someone is using the buddy seat, all I have to do is pop it off the two mounting studs, and store it in the back of the seats. It's got a metal inner shell that the plastic is bradded to. It's even got a little cubby area in front for napkins, maps, or ?.
Re: Found a "factory" cup holder for my truck.............. [Re: bigblock340power] #1671236
09/16/14 01:13 AM
09/16/14 01:13 AM
CA, Proprietor; The "PALOMINO"...
dynotune440 Offline
dynotune440  Offline
Mopar part number, inquiring minds wanna know..
Dinuba, California, Home of the PALOMINO ranch and 440 truck farm, where dodge trucks have a home. Have Four 1979 dodge PALOMINO trucks now.
Re: Found a "factory" cup holder for my truck.............. [Re: dynotune440] #1671237
09/16/14 02:42 AM
09/16/14 02:42 AM
fredericksburg virginia
mopwrd340 Offline
mopwrd340  Offline
I have seen them in 90s ford trucks i have one that i cut down to fit in my dakota.
Re: Found a "factory" cup holder for my truck.............. [Re: bigblock340power] #1671238
09/16/14 07:04 AM
09/16/14 07:04 AM
Pyeongtaek, South Korea
69HemiGTX Offline
69HemiGTX  Offline
Sweet! Do you think that would work with a regular bench seat? I'll have to keep my eyes peeled for one in the future.
OIF V and OEF X veteran and proud of it!
Re: Found a "factory" cup holder for my truck.............. [Re: dynotune440] #1671239
09/16/14 07:24 AM
09/16/14 07:24 AM
Elk Grove, Calif.
Elk Grove, Calif.
I guess I spoke to soon. After all the inquiries, I really took a good look at the inside of the unit. I had to get a flashlight and look way up inside to see any ID. Sorry folks, it's a Ford unit. But I did pull it from a Dodge truck! Sure looked like it belonged in there, and fooled me. Same color interior and everything! So! Now that we know who made it, the question still stands. Should I use it, or not? I guess I could make up some kind of home made cup holder to put in instead of this. At least it would be made not by ma Mopar, but a Mopar fanatic!
Re: Found a "factory" cup holder for my truck.............. [Re: bigblock340power] #1671240
09/16/14 09:02 AM
09/16/14 09:02 AM
adventurer Offline
adventurer  Offline
I'd still use it. No one will know the difference but us here on the truck section
14 Ram R/T
Re: Found a "factory" cup holder for my truck.............. [Re: adventurer] #1671241
09/16/14 01:06 PM
09/16/14 01:06 PM
Elk Grove, Calif.
Elk Grove, Calif.
But these are the opinions that mean the most to me !!!
Re: Found a "factory" cup holder for my truck.............. [Re: adventurer] #1671242
09/16/14 02:20 PM
09/16/14 02:20 PM
Buford, GA
I_bleed_MOPAR Online content
I_bleed_MOPAR  Online Content
Buford, GA
Looks good and if you like it, what else matters? Personally, I think it's great that it fits so well and I would use it in mine if I needed one.
Tim
'71 Charger 383/727
'17 Challenger SXT (Wifeys car wink )
Re: Found a "factory" cup holder for my truck.............. [Re: I_bleed_MOPAR] #1671243
09/16/14 03:09 PM
09/16/14 03:09 PM
dogdays Offline
dogdays  Offline
Use it.
Can't count how many times the doggone cup has tipped over!
R.
Re: Found a "factory" cup holder for my truck.............. [Re: dogdays] #1671244
09/17/14 12:14 AM
09/17/14 12:14 AM
dynotune440 Offline
dynotune440  Offline
As long as there is not a Ford blue oval on it I would use it.
Re: Found a "factory" cup holder for my truck.............. [Re: dynotune440] #1671245
09/17/14 01:02 AM
09/17/14 01:02 AM
Elk Grove, Calif.
Elk Grove, Calif.
Nah, any Ford ID is tucked way up inside the unit. Unseen till you turn it over. Even then you really have to look for it.
Re: Found a "factory" cup holder for my truck.............. [Re: bigblock340power] #1671246
09/17/14 01:26 AM
09/17/14 01:26 AM
Freeport IL USA
poorboy Offline
poorboy  Offline
Freeport IL USA
Personally, I would make my own! But then again, I always make my own cup holders anyway, mostly because I haven't found anything that works very well. Several of the modern vehicles have decent cup holders, but few adapt well to older Mopars. I wouldn't be afraid of using a cup holder from any other manufacturer if it fits and works. Gene
Re: Found a "factory" cup holder for my truck.............. [Re: poorboy] #1671247
09/18/14 11:18 AM
09/18/14 11:18 AM
central Florida
VL21 Offline
VL21  Offline
central Florida
Poking around in a u pull it one day I spotted a factory looking, in dash cup holder in a D150 ...
The PO had taken what appeared to be a 1st gen Dakota slide out cup holder, and cut an opening in the dash, IIRC near (maybe above?) the glove box, and installed it into the dash.
Looked OK, and appeared to work OK, but I think what made it work was that it was a non air truck, AC trucks have duct work in that area.
Kind of a long reach for the driver ...
It takes gasoline to interest me.
Re: Found a "factory" cup holder for my truck.............. [Re: VL21] #1671248
09/28/14 04:59 PM
09/28/14 04:59 PM
Germany, Berlin
muskote Offline
muskote  Offline
Germany, Berlin
classic consoles
Have their consoles in two cars now and I´m very happy with them.
The bench version in the D100 and the tunnel version in the 73 Dart (last pic)
Don´t wanna miss them any more. As a coffee junkie I love em.
Many colors available, solid stuff. Costs a few bucks, but I´m fully happy with what I´ve got..
