From stock to not. #1670444
09/12/14 11:40 PM
09/12/14 11:40 PM
Pa. U.S.A.
moparborn Offline OP
Pa. U.S.A.
Finally after collecting up all the parts I needed for the past 2+ years I swapped all the parts over.
A lot of wiring done,a little more to do.
A few misc details to do,some tweaking and tuning.
Yes I know the filters do not match,they will.
I do have to trim away some hood bracing but no skin cutting needed.
Re: From stock to not. [Re: moparborn] #1670445
09/13/14 12:00 AM
09/13/14 12:00 AM
Grand Prairie,Texas
stumpy Offline
stumpy  Offline
Grand Prairie,Texas
With matching blue filters that will be some serious eye candy.
Re: From stock to not. [Re: moparborn] #1670446
09/13/14 09:04 AM
09/13/14 09:04 AM
Greenville, PA
redraptor Offline
redraptor  Offline
Greenville, PA
Holy crap that's wild lookin'! Do you need to run 2 MSD boxes?
Re: From stock to not. [Re: redraptor] #1670447
09/13/14 11:39 AM
09/13/14 11:39 AM
Truckville, the capital of NY
85_Ram_4speed Offline
What intake is that? Is it a tunnel ram?
How do you like it on the street and how doe it compare to what you had on it before?
Looks menacing with the filter setup on there.
Outcast Dodge guy.
Re: From stock to not. [Re: moparborn] #1670448
09/13/14 01:15 PM
09/13/14 01:15 PM
SoCal
MuuMuu101 Offline
I got lucky at Woodward!
MuuMuu101  Offline
SoCal
All you need now is one turbo per carb...
Re: From stock to not. [Re: MuuMuu101] #1670449
09/13/14 01:49 PM
09/13/14 01:49 PM
Pa. U.S.A.
Pa. U.S.A.
The first msd crapped out (first time I ever had one go bad).
Yes it is a Weiand tunnelram but not a hi ram.
Twin turbos would be awsome.
Have not driven it at this time,still small ends to tie up but considering it was near stock (but did run well), I am sure it will be much better.
Re: From stock to not. [Re: moparborn] #1670450
09/21/14 11:15 PM
09/21/14 11:15 PM
Pa. U.S.A.
Pa. U.S.A.
Made a short maiden voyage in the truck.
What a difference.
A few more tweaks and mods to do but sounds and runs great.
